Old 09-29-2010, 12:31 AM   #1
bnsmith78
Drives: 2011 IOM SS Corsa/CAI
Suspension? Help power etc???
I have a CAI, Corsa Catback and a tune. Will new suspension help with power etc??? I thought I heard that?
bnsmith78 is offline   Reply With Quote
Old 09-29-2010, 12:45 AM   #2
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Higher durometer bushings, after market trailing arms and toe links will help you control your power better, reducing or eliminating wheel hop and undesirable suspension flex or movement. The adjustable shock valving in most coilovers helps in the same regard, as does the somewhat stiffer spring rates typically present in modified suspensions. The feeling of control is something that has to be experienced, not described.
Meh
My 5th is offline   Reply With Quote
Old 09-29-2010, 06:26 AM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Suspension mods will not make more power but they can make your car faster by increasing traction and making better use of the power you already make.
Old 09-29-2010, 08:22 AM   #4
2quick
Drives: none
The right suspension will make the use of the power you have more efficient. You just want to find the right balance of what you want to do with the car and your budget. Some if not most go over the top for their needs in suspension items. just because the car has super car handling doesn't equate to the driver having the same.
2quick is offline   Reply With Quote
Old 09-29-2010, 11:01 AM   #5
JusticePete
Drives: Camaro Justice
The right suspension modifications will help you put down the power you make more efficiently.
The foundational suspension modification in a 5th Gen Camaro is found in the sub-frame bushes. Adding trailing arms and or toe link does NOT address the foundational instability of the OE sub-frame bushes. The twist in the sub-frame remains as does the undesirable rear-end-step-out and wheel hop. Only subframe inserts directly address the root cause -- a twisting sub-frame within the rubber and space of the OE sub-frame bushes.
You can see the voids and how the inserts will alter them in these two pictures.
The inserts minimise installation time and cost while delivering maximum benefits.
Every suspension company has some type of full sub-frame bush replacement or brace because it is the critical component and building block for all other suspension modifications. Pedders has the EP1201 and EP1201HD full replacement bushes plus the EP1200 inserts. Address the weakest link in your suspension first because all other modifications will perform better once you have installed sub-frame insert or full replacement sub-frame bushes.
Old 09-29-2010, 02:12 PM   #6
bnsmith78
Where do you get these? How much to install? Etc.....
Old 09-29-2010, 02:20 PM   #7
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Don't forget about brakes.
Suspension mods themselves won't make power, but it can make that power easier to handle.
Team STILLEN is offline   Reply With Quote
Old 09-29-2010, 04:54 PM   #8
JusticePete
You can order them from you Pedders Suspension Specialist, many GM Dealers and Pedders. There is a link in my signature below. Thank you for trusting your Camaro to Pedders.
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Amp Recommendations? CamaroDreams07 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 55 05-28-2010 11:37 AM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
