Drives: 1968 S.S. Big Block and 2010 SS Join Date: Aug 2010
I have been doing a lot of reading and still I can not make up my mind about what S/C I should buy. My L99 is bone stock right now and would like to run somewhere in the 10's or low 11's. I do not want to lose the way the car drives as a daliy driver so I must keep that in mine. I also don't want to have to do any internal work. But the Florida Heat and humidity is murder for trying to keep temperatures down. I have read that different units use different ways of combating heat problems. I don't care if I need to run a BAP or the price just want to get the right unit and no troubles. I would one day like to add headers, free flowing cats and exhaust and if possible a CAI. Does anyone run these times with a L99 and drive it on the street every day? Can anyone suggest a S/C for my needs? Thanks for your help
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RY 2SS with Custom Stripes Join Date: Mar 2009
You are not going to be able to run in the 10's with just a s/c. You will have to spend some money to get anywhere close to the 10's. Just saying.
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
John,
You will need the SC and a good torque converter and a trans build. Then with the right tires we can get you in the 10's. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
If you want a supercharger that does not generate alot of heat then I would look at the Kenne Bell 2.8 or Whipple 2.9. With supporting mods like custom dyno tuning, Long tube Headers, CAI, the correct fuel system, tires, and suspension that car could easily do 10's and would drive not only good as stock but better than stock.
![]() ![]() ![]() ![]() Drives: ZL1 Camaro Join Date: Feb 2009
I run low 11's all day (looking for 10's in Ocotber/November), I have twin turbos, stall converter, meth, BaP, DR's and a tune...I drive it everyday (10-12k miles per year) and I live in hot/humid Florida.....
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS & 2008 C6 Join Date: Mar 2008
If you want a supercharger forthe heat, the Whipple`s IAT`s are lower than anybody elses blower.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s! Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list.. |
#7 |
![]() Drives: 2010 2SS/RS IOM L99 Join Date: Jul 2010
#8 |
![]() ![]() ![]() Drives: 2010 Camaro Auto Join Date: Mar 2010
#9 |
I am running a magnuson 2300 in Florida. During cruise conditions my intake air temps are two to three degrees above ambient, even when the ambient is in the 90's. During stop and go driving when ambient is in the 90's, the iat is usually about seven to ten above ambient even idling for a long traffic light. Now WOT is another story. On a 92 degree ambient day I logged an iat of 133 degrees at 115 MPH.
#10 |
Get a top mount with a chiller. Lowest IAT's with charge air going through A/C. Don't know if anyone has one for the Camaro yet, but if IAT's are that important, wait for one. Just my .02
#11 |
Just waiting for a doner car to finish the chiller....have it 90% ready for market, just need a final test car.
#12 |
![]() Drives: 2010 SS Black Join Date: Jul 2009
running a maggie 2300, live much farther south then you and temps are even hotter.. my intake manifold air temps while running have never gone over 135. and when running at 3000 rpm drop to 105deg. i know that after a long ride i have been able to put my hand on the top of the maggie, and yet it is hot it's not burning
2SS- M6 - 849 RWHP, 757 RWTQ - YSI -Supercharger - Comp Cams Stage 3 Blower Cam -54-471-11 - (In-239/624 - Ex 255/624)
MTI - CAI - Meth Injection Systems using 50/50 mix - Kooks 1 7/8" Headers with 3" catted X-Pipe - Kooks muflers to tips - LSR Short Throw Shifter - NGK TR6 Spark Plugs - 160 degree thermostat - LSR Sway Bars (Front & Rear) - BMR Subframe Connectors bolt-on - DSS - lingenfelter 9" w/ 4.10P - PFADT coilover front/back - BMR Spherical Toe rods / Trailing arms - Posi lock - |
#13 |
IAT can be read by plugging into the OBD with a interface device.
#14 | ||
Read this thread: http://www.camaro5.com/forums/showthread.php?t=102326
| Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 273 | 08-15-2023 05:44 PM |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 93 | 08-30-2021 06:56 PM |
| Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 09:33 PM |
| List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 03:11 AM |
| 5th Gen Camaro LS3 info from Chevy Hi-Po...READ | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 295 | 03-07-2008 11:06 AM |
