Old 10-02-2010, 04:27 PM   #1
NewGen
NewGen's Avatar
Drives: 2013 Camaro ZL1
Send a message via AIM to NewGen Send a message via MSN to NewGen
Arrow Maggie or Whipple
Im goin the S/C route and trying to decide between the Maggie and the Whipple... my goal is 500-550 at the wheels maybe a little more.
This is goin to be for the L99.
So ppl with these set-up can you give me sum info?
All advice and opinions are much appreciated
Thanx in advance
Young Man wanting Big Power
NewGen is offline   Reply With Quote
Old 10-02-2010, 08:29 PM   #2
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
I have the 1900 maggie on a ls3,with longtubes and exhuast 9inch rear with 3.64 gear and heavy 22 inch wheels,all this robs power it makes 500rwhp with the stock airbox and filter.The 1900 spools quick and im getting 26 mpg.If i can help you out give me a call,we also sell the maggies.
Hendrix-Engineering is offline   Reply With Quote
Old 10-02-2010, 08:31 PM   #3
NewGen
NewGen's Avatar
im wantin to put 22's on mine also
Old 10-02-2010, 08:32 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
If you want 500 - 550 you will need a cam w/ the maggie. Whipple should do the trick though...
Old 10-02-2010, 08:36 PM   #5
NewGen
NewGen's Avatar
Thanx...do you kno if the VVT specific cams for the L99 are expensive?
Old 10-02-2010, 08:36 PM   #6
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
why not consider edelbrock and kb? they also are nice units...edelbrock has some good design with some serious torque...from #,s i have seen no sc has the torque out the box as a edelbrock...i have the kb and would put it up against any sc out there...but just wanted to throw that these 2 sc are worth mentioning.. i am dyno 560rwhp with 519rwtq..with no lts...approx 7lbs boost.. you should be in the 500rwhp range with any sc on a l99...lts will get you another 20-30 hp and help your sc breathe a little easier
mikepage0007 is offline   Reply With Quote
Old 10-02-2010, 08:38 PM   #7
NewGen
NewGen's Avatar
I am not considering the Edel bcuz it delete DOD and how do you like the KB?
Price wise?
Old 10-02-2010, 08:46 PM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
The cam is not much more expensive, but it's what you do w/ lifters and such that drives the price up. Pulling heads etc.
Should be an extra $3,500 for swapping lifters and the whole enchalada...
Old 10-02-2010, 09:05 PM   #9
NewGen
NewGen's Avatar
If i was to do a cam i would jus do da cam dat doesnt mess up the lifters on the car instead of dropn the 3500...
do you know the numbers i can obtain from maggie stock and whipple stock?
Old 10-02-2010, 09:09 PM   #10
1 bad azz ls3
1 bad azz ls3's Avatar
Drives: 2010 camaro ss
if you want big # go with the whipple
1 bad azz ls3 is offline   Reply With Quote
Old 10-02-2010, 09:15 PM   #11
NewGen
NewGen's Avatar
thanx...thats wat im lookn at...is that wat you went with? if so i kno the numbers are goin to b diff bcuz u have an LS3 and ill b doin this on an L99
Old 10-02-2010, 09:17 PM   #12
600hp-lpe
Drives: 2010
There are a few people with L99's that have collapsed the stock lifters. I would recommend swapping the cam and lifters...
600hp-lpe is offline   Reply With Quote
Old 10-02-2010, 09:22 PM   #13
NewGen
NewGen's Avatar
thanx for the heads up
Old 10-02-2010, 09:26 PM   #14
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Plenty of numbers from the maggie and the VVT cam will get you over the 500 mark w/ the L99 right in line w/ the numbers you want.
If you do a cam get rid of the lifters... however they do make a mild, lifter friendly VVT cam.
The lifters w/ the stock cam also run this risk...
Sitting on the fence about Whipple or Maggie Clj73 Forced Induction - V8 27 09-01-2010 12:00 AM
My photo album of Maggie photos. Nine Ball Forced Induction - V8 19 08-26-2010 03:09 PM
Top Mount Decision- TVS2300, KB, Whipple thekid96 Forced Induction - V8 106 03-03-2010 11:37 AM
Compare..Edelbrock, Harrop, KB, Maggie, Whipple, GM(LS9) old motorhead Forced Induction - V8 12 02-21-2010 02:33 PM
too many options...vortech, procharger, whipple, maggie, KB? general23cmp Forced Induction - V8 31 10-30-2009 03:07 PM
