Old 10-07-2010, 09:44 AM   #1
unb
Drives: 2010 black camaro 2ss
Tire Pressure
Howdy. My 2SS just had it's first servicing and all the tires came back at ~30psi instead of the 36psi they were. They also put a sticker on my windshield telling me to change my oil and get my tires rotated in 3,000 more miles. My low tire pressure lights keep coming on, and my Onstar email is saying I need to inflate my tires.
The manual says to check the tires on one page, and on another says to check the label attached to the vehicle. Where is this label?
I'm using stock tires. What pressures should the front and back be?
Thanks,
--unb
unb is offline   Reply With Quote
Old 10-07-2010, 09:47 AM   #2
ga0358
ga0358's Avatar
Drives: 2010 ABM LS
The change in the weather will cause your tire pressure to change-Look on the inside of the front door frame, there should be a label there displaying the correct tire pressures.
ga0358 is offline   Reply With Quote
Old 10-07-2010, 09:48 AM   #3
HDDAN
HDDAN's Avatar
Drives: 2010 Camaro 1SS 2007 HD FLSTC
36 front and 36 back. Your car holds 8 quarts of oil and has an oil life indicator in the drivers information center. You should have synthetic oil in your car. Change it when the change oil message appears. They are just trying to make money off of you.
HDDAN is offline   Reply With Quote
Old 10-07-2010, 09:49 AM   #4
Skyblu
Skyblu's Avatar
Drives: 2010 Aqua blue 2SS/RS M6
And you can't rotate the tires either, what idiots, find another servicer.
Skyblu is offline   Reply With Quote
Old 10-07-2010, 09:50 AM   #5
unb
Thanks! Appreciate it. I am unsure they are being venal and seedy. They might just have made a lot of mistakes.
--p
Old 10-07-2010, 10:01 AM   #6
mr. anderson
Drives: 2015 Camaro 2SS 1LE
well, not entirely true about the rotating of the tires. since these tires are not uni-directional they can be swapped side to side. just not front to back.
and I do agree about the place, I would check to make sure you received the right amount of oil. did you take it to the dealership?
mr. anderson is offline   Reply With Quote
Old 10-07-2010, 10:06 AM   #7
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
the tires are not uni directional.....they are directional tires.....the CAN NOT be rotated
gm2376 is offline   Reply With Quote
Old 10-07-2010, 10:09 AM   #8
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
Are you sure???? It doesn't say anywhere on the tire that they are directional. I think they can be swapped from side to side. Where did you get this information from?
2010 2-Tone is offline   Reply With Quote
Old 10-07-2010, 10:15 AM   #9
Skyblu
Skyblu's Avatar
exactly, thanks I thought I was loosing it!
Old 10-07-2010, 10:20 AM   #10
Duke
Duke's Avatar
Drives: 2010 Red SS/RS
The tires ARE NOT directional, they can be rotated side to side.
Duke is offline   Reply With Quote
Old 10-07-2010, 10:23 AM   #11
BlackLS
BlackLS's Avatar
Drives: 2010 Camaro LS
Check your owners manual if you have OEM equipement. Vehicle Care 9-63
BlackLS is offline   Reply With Quote
Old 10-07-2010, 10:25 AM   #12
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
On your windshield???
Old 10-07-2010, 10:27 AM   #13
2010 2-Tone
It might say it in the manual but it doesn't say it on the tires and tire makers must put that on the tires. Directional tires have an arrow on them showing they can only travel in one direction on the road surface. I am sticking to they can be swapped.
Old 10-07-2010, 10:29 AM   #14
Terryss
Drives: 2010 cyber gray metallic @ss
the tires are not ment in anyway to be rotated
Terryss is offline   Reply With Quote
Tire Pressure Questions nalinc23 Wheels and Tires Talk Sponsored by The Tire Rack 21 09-15-2010 02:18 PM
factory 20in wheels cold tire pressure? mike12345 Wheels and Tires Talk Sponsored by The Tire Rack 7 05-11-2010 01:58 AM
Tire pressure monitor CEL after tire change B.Buster Wheels and Tires Talk Sponsored by The Tire Rack 6 04-01-2010 09:45 PM
Help with tire pressure monitor bigkahuna4444 Wheels and Tires Talk Sponsored by The Tire Rack 0 10-29-2009 01:16 PM
Tire Pressure Problems Matster Canada 14 10-03-2009 07:11 AM
