Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
A NEW generation of oil, for ALL GM cars
I came across this today....
Every 2011 General Motors car rolls off the assembly line with the engine filled with a new generation of oil. Other automakers, such as Ford Motor Co. and the Chrysler Group, are also beginning the switch to new oil, known by its industry grading as GF-5 or SN, or, in GM’s case, Dexos1. The grade identifies oil that’s designed to help engines run more efficiently and better protect them from wear. Those are key properties as automakers wring more horsepower out of smaller engines and make greater use of heat-producing turbochargers and superchargers. The protection properties of the new oil also have the potential environmental benefit of increasing the mileage interval between recommended oil changes. What is not clear yet is just how much more the new oil will cost. Tests make the differenceThe Dexos1 and GF-5 oils hit the market on Oct. 1. They replace the GF-4 standard from the International Lubricant Standardization and Approval Committee, which has members from GM, Ford, Chrysler and the Japan Automobile Manufacturers Association. The American Petroleum Institute uses the SN designation for the new oil. “GF-5 and Dexos1 oils have a more robust formulation that should give you better contributions to fuel economy, cleanliness and fuel emissions,” said Mark Ferner, manager of the lubricants technology group at Shell. The main difference between Dexos1, which is a GM-licensed brand, and GF-5 oils is testing, Ferner said. To be certified as GF-5, the oil needs to pass a variety of chemistry and engine tests set by the American Petroleum Institute. But GM’s testing for Dexos1 uses some tests mandated by the ACEA, the European automobile manufacturers association, in place of the American Petroleum Institute tests. For example, Dexos1 oil has to pass Mercedes-Benz’s sludge and fuel-economy tests and Opel’s test for the ability to work under foaming conditions, known as aeration. GF-5-certified oils that do not undergo the same tests are subjected to the American Petroleum Institute’s equivalent to be certified. GF-5 oil can be found in both conventional and synthetic formulations but Dexos1 can only be found as a synthetic, according to Shell, maker of the Pennzoil and Quaker State brands. In some cases, oil companies already have formulas that meet or exceed the Dexos1 and GF-5 specifications. For example, Shell’s Pennzoil Platinum and Quaker State Ultimate Durability synthetics exceed both standards. Driven by tighter regulations Government regulations that call for lower exhaust emissions and higher fuel economy are the drivers behind the new generation of engine oil. GM’s powertrain fuel and lubrication engineers began working on Dexos1 in 2006. The goal was to set an oil specification that met the requirements of all GM vehicles and powertrains globally. GM also developed the Dexos2 oil specification for light-duty diesel engines. It was launched in Europe earlier this year. Dexos1 is designed to work with the engine-oil-life monitor in GM cars to increase the mileage between oil changes. “Dexos puts us in a position to try and optimize the drain intervals,” said Eric Johnson, a GM fuel and lubrication engineer who worked on the development of Dexos. GM does not specify a mileage life for Dexos1. It recommends that drivers change the engine oil when the oil-monitor system recommends, as oil life depends on driving conditions. However, Ford says it’s possible to go as long as 10,000 miles between oil changes with GF-5 oil. This is possible because Ford has made major improvements in the materials and technologies it uses in its engines, a spokesman said. Among the changes: greater use of aluminum for engine structural components and increasing the size of oil pans. Ford also uses an oil-life-monitoring system, which tells owners when it’s time for an oil change. “We have made improvements to our engines and want to use the best oil we can,” spokesman Richard Truett said. Good for new and old cars Dexos1 and GF-5 oils can be used in older cars. Owners still need to consult their owner’s manual to choose oil with the recommended viscosity. Consumers will find some bottles of oil with both the Dexos1 and GF-5 certification, said Ferner of Shell. He added that consumers will not notice an immediate difference after changing to a Dexos1 or GF-5 oil. Instead, the benefits are oil that better protects and cleans the engine over time. But beware if you’re tempted to use conventional oil in an engine that calls for the new specification. GM says not using Dexos1 oil may cause engine damage that would void the powertrain warranty. Go to www.gmdexos.com for more information on GM’s Dexos oils, and see www.gf-5.com for information on GR-5 oil.
![]() Drives: 2011 2LT - 73 Corvette 454 Join Date: Sep 2010
GF-5
DEXOS AHHHH!!!!! This oil thing is driving me nuts ![]() So when I get to 3K for an oil change what should I do?
I am the Stig
Drives: Black w/ IOM stripe 1SS Join Date: Jan 2010
Amsoil 0w30 it's a life changer.
2010 Camaro - 1SS, Black w/ Orange stripes
AwesomeBillDawesonville
Drives: CGM 2SS/RS =) Join Date: May 2009
Sir Nuke knows too much...
Thanks for the info
Order placed on 1/13/11 - Purchased 2/22/11 2SS/RS CGM |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
I've told you guys to google Dexos for a while now. It's a GM spec not an industry spec. Many of today's synthetics can't meet it.
#6 |
Whipped
and where can we pick this up #3?
#7 |
Mike "Meage"
Drives: Aqua Blue 2010 Camaro 2LT RS Join Date: Sep 2009
man why do the 2011 get all this cool stuff?!?! HUD, Onstar App, Oil...whats next they get to actually transform?!?!?!?!?!
#8 | |
as stated in the artical I found, there are quit a few available on the shelves, and if you don't find them...buy your oil at the dealer if it makes you feel better. as far as documention goes, if you look in the back of your owners manual, there is a schedule for you to fill in the back when you or the dealers changes your oil/filter. and if you want, keep ALL your reciepts and put the in a book. BINGO!! it goes ABOVE AND BEYOND regular API oil specs
#9 |
![]() ![]() ![]() ![]() ![]() Drives: White M6 1LT RS Join Date: Mar 2010
Does Mobil 1 meet this standard?
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
#11 |
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
I think it's more to do with the industry moving toward global production. An engine plant that builds engines for all over the world, probably a good thing to have one spec oil. Build the engine anywhere, ship it anywhere. Crest will probably come out with a global spec toothpaste soon. Will your teeth fall out if you use last year's spec Crest? No. But from a production standpoint, ship the same stuff everywere in the world = efficiency. |
#13 |
![]() Drives: 2002 Camaro Z28, 2011 SS/RS Join Date: Oct 2010
So correct me if i am wrong.
Am i to assume that Dex is just a "certification"? Thus i can buy 5w30 weight oil still, i just have to make sure it has a "dex" label or certification on it? |
#14 |
No, it is not an SS
Drives: SIM 2LT/RS Join Date: Jun 2010
| Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
| Need Opinion on Oil Change | 68blk/yel396 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 22 | 06-22-2009 11:02 AM |
| "The car of the future may turn out to be no car at all." | Scotsman | General Automotive + Other Cars Discussion | 2 | 11-03-2007 12:22 AM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
