Old 10-20-2010, 10:38 AM   #1
bigwayne3000
Drives: 2011 Camaro LS
Adams detail spray and claybarring
I never claybarred before but have watched Junmans videos and it seems easy. MY question is, would 1 bottle of detail spray be enough for the entire car? I know you need to continuously saturate the clay and vehicle so it doesnt stick so it seems like a lot of spray gets used.
bigwayne3000 is offline   Reply With Quote
Old 10-20-2010, 10:41 AM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Don't use the good stuff for claying. Go pick yourself up Mother's clay bar kit at Walmart. It comes with a cheap detail spray which will work just fine for claying. I save my Adam's for when I'm using it for show.
To answer your question though, one bottle has always been enough for me. Leave the car wet after your Dawn wash, this will make less detail spray necessary because the car's already wet.
[B]
Old 10-20-2010, 10:42 AM   #3
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
Depending on the size of the bottle. I reg size bottle will last for several times doing the entire car.
2010 2-Tone is offline   Reply With Quote
Old 10-20-2010, 10:45 AM   #4
mnmdimas
mnmdimas's Avatar
Drives: 2010 Black/Black SS
It depends on how nasty your paint is. If it has a ton of dirt stuck into the paint then it may take more detail spray. If you can clean it up in just a few swipes then 1 bottle may be enough. I have never used the Mothers but I have used the Adams and Meguires, and the Adams is a much harder clay. The harder the clay the more the clay does the work for you with less pressure.
mnmdimas is offline   Reply With Quote
Old 10-20-2010, 11:14 AM   #5
camaro2ssblack
camaro2ssblack's Avatar
Drives: 2010 Camaro 2SS - Black on Black
It took me exactly one full bottle to clay my camaro...I dont spray it on as heavy as junkman, there is no need to waste all that product. I used about the same amount as Adam on his videos..
camaro2ssblack is offline   Reply With Quote
Old 10-20-2010, 05:39 PM   #6
lets_go_bills
lets_go_bills's Avatar
Drives: 2011 Camaro 2LT/RS CGM M6
I mix a solution of car wash (Z7) with water in a spray bottle and use that. Works great and is much more cost effective than using detail spray.
2011 Chevrolet Camaro 2LT/RS Cyber Gray Metallic
lets_go_bills is offline   Reply With Quote
Old 10-20-2010, 10:58 PM   #7
mnmdimas
mnmdimas's Avatar
Great idea
Old 10-21-2010, 12:09 AM   #8
SirBrad
The Captain
SirBrad's Avatar
Drives: 2010 2LT/RS SIM
This is exactly what I do. The wash is so concentrated that you only need to use a little bit.
SirBrad is offline   Reply With Quote
Old 10-21-2010, 12:19 AM   #9
Uncle Harvey
Uncle Harvey's Avatar
Drives: 2011 2SS RS
I used a whole bottle to do mine. I may have wasted some. But I wanted to be sure the paint was lubricated.
Uncle Harvey is offline   Reply With Quote
Old 10-21-2010, 12:27 AM   #10
Duper
Drives: 2011 Camaro 2SS / RS
Me too. Any quality car wash soap + water mix in a spray bottle will do.
Duper is offline   Reply With Quote
Old 10-21-2010, 12:33 AM   #11
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
A whole bottle is overkill... remember, you don't want to "saturate" the bar, you want enough to allow the bar to glide, but not so much that it isn't making contact with the paint.
Old 10-21-2010, 08:45 PM   #12
bigwayne3000
Thats true. Thanks. Come next fri I will hopefully be the owner of a new black LS and some Adam's products will be my 2nd purchase right after tinting my windows hah.
