Old 10-20-2010, 01:08 PM   #1
paslag
paslag's Avatar
Drives: 2010 Camaro 2SS/RS
Ls9 Cam
I'm installing an eforce sc and was loocking to replace my cam with the Ls9 cam #12605527. For less than 100$, I think it would be a good upgrade. But could anyone confirm it's a direct bolt-on, without the need to replace anything else like springs,push rod etc?
Thanks
2010 2ss/rs Ls3, E-force s/c, 3.25'' pulley,Kooks long tubes w/cats, magnaflow 2.5" cat back, Rotofab cai, 65 lbs inj, MSD bap, AEM water/meth, comp cam, 621whp,577 wtq on mustang dyno
paslag is offline   Reply With Quote
Old 10-20-2010, 01:19 PM   #2
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
Thanks
In theory.....you can swap it in and the only thing you would need is the 3 bolt adapter and the gasket set. While you are doing it though, you would be smart to upgrade to a better spring because of the supercharger. I priced everything needed to do it this was from Lingenfelter an it is about 425 bucks for everything.
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 10-20-2010, 01:46 PM   #3
paslag
paslag's Avatar
Do I need springs with a higher rate, or is it just because the oem are just not good enough?
Old 10-21-2010, 09:00 AM   #4
Jeff@Lingenfelter
Jeff@Lingenfelter's Avatar
Drives: 1966 Chevy II/1968 Camaro
Give us a call, and we can discuss everything you will need for this swap. It is very straightforward.
Jeff@Lingenfelter is offline   Reply With Quote
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
LS9 cam ? SinisterSS Forced Induction - V8 21 05-06-2011 04:23 PM
LS9 vs. Lingenfelter GT9 cam usmcjlp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 08-20-2010 02:01 AM
LS9 cam in a L99? lexlueger Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 07-21-2010 09:26 AM
