Old 10-20-2010, 09:50 PM   #1
NewGen
NewGen's Avatar
Drives: 2013 Camaro ZL1
Send a message via AIM to NewGen Send a message via MSN to NewGen
Question L99 Max Boost
Can someone tell me how much boost can a stock L99 handle with a TT kit
Young Man wanting Big Power
NewGen is offline   Reply With Quote
Old 10-20-2010, 09:58 PM   #2
Supercharged SS
Drives: 2010 Camaro
When it finally grenades, just remember to stay 1 psi less the second time and then you'll know how much boost she'll hold!
Old 10-20-2010, 10:01 PM   #3
NewGen
NewGen's Avatar
lol got jokes huh buddy
not tryna take it derr... if i blow dat motor... im not goin with anuda L99... jus get dad to build me up a 427 or 572 if itll fit and help him out as much as i can
Old 10-20-2010, 10:02 PM   #4
Supercharged SS
Drives: 2010 Camaro
Keep it under 10 and you'll be ok. That should get you over the 500 rwhp you want.
Old 10-20-2010, 10:08 PM   #5
NewGen
NewGen's Avatar
Im not goin ova 10 unless i put sum forged parts in da engine... im thinkin 8-9 lbs and a trans tune as well
Old 10-21-2010, 12:01 AM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
One of the shops kept increaseing the boost till it autoshortened the rods and I think it was at 17 PSI. I'm thinking he even took it out and beat on it at the increasing boost levels. After the autoshortening, he ONLY put another set of OEM rods in and ran it at low teens boost without a problem. That's not to say that i'd slap a SC on and pulley it up to 15 PSI but I think it shows the leaway we really have. As has been said a bazillion times before, it's all in the tune. Not sure if it was a LS3 or L99 though.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-21-2010, 12:25 AM   #7
NewGen
NewGen's Avatar
thats insane... i cant see myself pushin that much boost at all... bt hell if they can do it without problems more power to them...
Bt im good up to 10 for NOW
Old 10-21-2010, 12:31 AM   #8
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
I see that english is a foreign object here.
As far as boost on the L99 I think i remember the mention of not going over 9psi for extended periods of time with everything stock.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 10-21-2010, 12:35 AM   #9
NewGen
NewGen's Avatar
Thanx
Old 10-21-2010, 07:08 AM   #10
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
A 1/2 atmosphere of boost (7.5 psi) is a safe place to be.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 10-21-2010, 02:18 PM   #11
NewGen
NewGen's Avatar
Thanx
Old 10-21-2010, 02:34 PM   #12
Slowhawk
Drives: 1999 Trans Am
That is actually the correct answer. Each engine is different and tuning makes a big difference.
With Turbo's I'd have no problem running 10lbs with the temptation to run 12-14lbs.This is when precise tuning comes in.
Slowhawk is offline   Reply With Quote
Old 10-21-2010, 02:36 PM   #13
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
The higher the boost the bigger the boom !!!
You should be able to run forever with single digit boost if you don't lean out. When you start testing double digits you may have problems unless you have a great tuner (of which there are many on this site)
Old 10-21-2010, 02:41 PM   #14
NewGen
NewGen's Avatar
Yea i know the tuning has 2 be precise on that engine so hell...wen it gets done we'll see
bt im thinkin btween 7-9 lbs
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
When is a L99 no longer considered a L99 danhr 5th Gen Camaro SS LS LT General Discussions 24 04-05-2011 09:51 PM
Standard vs Automatic Racing HarrisraTx Dragstrip and Launch Techniques Discussion 74 10-29-2010 10:26 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
