Old 10-27-2010, 12:35 PM   #1
starscream
starscream's Avatar
Drives: camaro lt 2
my camaro has a problem!!!
hi guys!! why my camaro is so high??? the distance of the wheel is 11 cm....is too... your camaro seem more lower...I'm thinking of the springs eibach....sorry for the language..bye
starscream is offline   Reply With Quote
Old 10-27-2010, 12:46 PM   #2
starscream
starscream's Avatar
Drives: camaro lt 2
the wheels are bmw x6..
Old 10-27-2010, 01:40 PM   #3
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
This is a real good question....it's higher. I notice mine sits a tad higher than most, but nothing like this
f5journal is offline   Reply With Quote
Old 10-27-2010, 01:51 PM   #4
PB3
PB3's Avatar
Drives: 2010 CGM 2LT/RS/GFX/M6
That is weird. The wheels and tires look tiny.
"Reality is an illusion that occurs due to lack of alcohol" -W.C.Feilds
PB3 is offline   Reply With Quote
Old 10-27-2010, 01:56 PM   #5
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
What are the tire sizes?
You may have made the gap bigger by going with a smaller diameter tire than stock.
Stock = 28.66 inch height .......... 275 x .4 / 25.4 x 2 + 20 = 28.66.....275 times .4 divided by 25.4 times 2 plus 20 = 28.66
Skip the springs and save up for coil over shock, they are worth the wait!
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 10-27-2010, 01:58 PM   #6
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Those wheels are nice, did you use an adapter? what year X6?
Regarding the Gap, i think maybe the OD (Overall Diameter) is smaller than the original thats why you see that gap,
Whats the size of that tire?
christianmotox is offline   Reply With Quote
Old 10-27-2010, 02:17 PM   #7
starscream
starscream's Avatar
Drives: camaro lt 2
the extent of the rim has nothing to do with the height of the car....I had initially rims 19
and the distance not change...always 11cm... is too high can also be seen from the picture..... p.s. the wheels are 21x10 front and 21x11 rear..bmw x6 2010
Old 10-27-2010, 02:20 PM   #8
starscream
starscream's Avatar
Drives: camaro lt 2
uff!!!!!!!!!i want it like yours!!!!!
Old 10-27-2010, 02:24 PM   #9
christianmotox
Drives: ( . )( . )
The size of the rim has a lot to do with it but it will also depend on the tire's ratio.
Since you do not provide any sizes of the tires to properly calculate the OD, you would need to calculate the Before OD and the new OD.
If you had OEM 19" (P245/50ZR19 ) wheels and tires the OD was 28.6 inches.
And also i see that those wheels are wider than the tires, making the tire stretch and this will also cause the tire to appear smaller.
Old 10-27-2010, 03:27 PM   #10
starscream
starscream's Avatar
Drives: camaro lt 2
sorry it's hard to explain because I do not know the language well ....
no adapter... 5x120 offset... 245x40 275x35...I am convinced that my camaro is higher than normal....
Old 10-27-2010, 03:37 PM   #11
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Ciao Starscream what part of Italy are you from?
Old 10-27-2010, 03:41 PM   #12
starscream
starscream's Avatar
Drives: camaro lt 2
i'm living in a small country is ARBORIO between TORIN and MILAN.. why?? ciao!!!
Old 10-27-2010, 03:43 PM   #13
06blownSS
06blownSS's Avatar
Drives: 2010 Camaro SS
get the eibach's will lower your car 4-5 cm
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
06blownSS is offline   Reply With Quote
Old 10-27-2010, 03:46 PM   #14
Andro
NOICE!!! ™
Andro's Avatar
In two weeks I will be in Aviano/Pordenone within the region of Friuli Venezia Giulia. If you need any help with your car I'll be more then willing to help you out.
