Old 11-04-2010, 03:43 PM   #1
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Getting DT Shortys installed...any advice?
I'm having DT short tubes installed next week at a local speed shop. (I know, but LTs are an issue for me right now). They asked if I wanted to use gaskets or RTV. They recommend RTV instead of gaskets. Claim they use it on their race cars, the owners 5th gen with long tubes a year ago, and it's the way to go. Any advice?
Old 11-04-2010, 04:04 PM   #2
montej23
montej23's Avatar
Drives: 2011 VR Camaro
I havent seen or heard to use anything else other than gaskets so i hope you get a response for this because i do not want to viod my warrenty and have to get a tune. So i am thinking about DT shorty's as well. Can you make a sound clip of them on?
montej23 is offline   Reply With Quote
Old 11-04-2010, 05:01 PM   #3
smokescreen
smokescreen's Avatar
Drives: 2011 2SS/RS
I followed the instructions and used the gasket when I put mine on this past weekend.
Patience is not a virtue, it is a waste of time.
smokescreen is offline   Reply With Quote
Old 11-04-2010, 05:02 PM   #4
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
Everything I've read so far says reuse the stock gaskets as they are really good.
xxlbeerz is offline   Reply With Quote
Old 11-04-2010, 05:32 PM   #5
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Yes. Have them re-use the stock metal gaskets.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 11-04-2010, 05:36 PM   #6
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I reused the stock ones also ... No problems - No Leaks
Don't forget to post a follow up and tell us what you think of them ...
Old 11-04-2010, 08:48 PM   #7
DMAX
DMAX's Avatar
Drives: 01 silverado 2010 2SS/RS Sim
[QUOTE=SlingShot;2515935]I reused the stock ones also ... No problems - No Leaks
Same here
DMAX is offline   Reply With Quote
Old 11-05-2010, 12:33 AM   #8
Ivan @ Southwest Speed
Do not use RTV....it will make a mess and leak over time.
The OEM's are good for 2-3 reuses and that's it. Aside from that, use them the way that GM created them and you'll be in great shape.
Let us know how they turn out for you and thank you for purchasing Doug Thorley!!!
Old 11-05-2010, 03:54 AM   #9
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Do you have a dyno baseline already? I'd be interested to know exactly what kinds of gains the shorties will give you with your setup.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 11-05-2010, 08:34 AM   #10
ZED SLED
ZED SLED's Avatar
Thanks for the responses everyone.Will definitely have them re-use the stock gaskets. No, I don't have a baseline. Would love to dyno but the closest one I know of is 2 1/2 hours from here at Redline. I'll just have to keep using the ole neck snap dyno.
Old 11-05-2010, 09:53 AM   #11
montej23
montej23's Avatar
how much did you get the DT shorties for?
Old 11-05-2010, 11:50 AM   #12
BowlingSS
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT
I re-used my on my LS1 but I did spray them with cooper spray. No leaks for years but I had LT's not shorties.
Bill
BowlingSS is offline   Reply With Quote
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 473 07-11-2025 10:07 PM
Racing Brake 2 pc Rotors Installed mtcwby Suspension / Brakes / Chassis 36 11-13-2010 06:07 PM
Check Engine light on after ARH and Pipeline CAI installed se7en Tuning / Diagnostics -- engine and transmission 17 03-10-2010 09:06 AM
Another Dealer Installed Stripe Problem 69er Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 07-13-2009 04:32 PM
Factory Striping vs. Dealer Installed RetroDude Cosmetics and Lighting Modification Discussions 1 04-23-2009 02:01 AM
