Old 11-08-2010, 12:27 AM   #1
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
New aftermarket LS3 heads.
Trick Flow LS3/L92
Price: $2500-2700 (est)
Available: Beginning of March, 2011
*255 cc
*2.100 intake valve, 1.600 exhaust
*69cc chambers
*4.00" minimum bore
*12 degree Valve angle
*Must run LS7 Rockers
*Can run ls3 or ls7 style intake, specify when ordering head
Advertised out of the box cnc Flow Numbers
Lift Intake Exhaust
.100 72 62
.200 159 117
.300 234 179
.400 292 224
.500 333 240
.600 357 252
http://www.ls1tech.com/forums/genera...rick-flow.html
PRC / Texas Speed CNC LS3
Price: $2399 (est)
Available: Early 2011
*All new PRC Castings and CNC Port Design
*LS3 Square intake Port
*Thick Deck
*Will bolt up to any current blower system
http://www.ls1tech.com/forums/genera...-ls3-bore.html
http://www.camaro5.com/forums/showthread.php?t=83194
Mast Motorsports Black Label LS3
Price: $2599 bare,
$2999 assembled with .650 lift beehive springs, stainless valves, and billet aluminum rocker stands.
Available: Now
*256cc
*2.165 intake valve, 1.600 exhaust
*69cc chamber
*11 degree valve angle
*Regular or 6 bolt LSX Bolt pattern
*4.000-4.070 bore
*Uses LS3 offset rockers/valvetrain
Advertised Flow Data w/4.000" Bore Plate
Lift Intake Exhaust
.100 74 61
.200 146 119
.300 222 188
.400 282 219
.500 330 236
.600 360 251
.700 372 260
http://www.ls1tech.com/forums/genera...der-heads.html
Would like to see some real world numbers/comparisons with ported LS3 heads on stock cube motors sometime in the future. The future is looking bright for the LS3
Ovenmitt is offline   Reply With Quote
Old 11-08-2010, 12:47 AM   #2
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
We need these heads badly for FI users because of the deck problem under boost lifting the heads with the stock casting. The only question I have is with the intake mounting. Will any PD supercharger bolt up to these heads? If not then I think we may have an issue.
Old 11-08-2010, 01:37 AM   #3
Ovenmitt
The TFS heads require a special lower intake plate for the roots blowers to fit. I imagine the afr head is similar. Aftermarket or not the heads will lift regardless unless you change to a 6 bolt casting (aftermarket block)
Old 11-08-2010, 01:59 AM   #4
VADER SS L99
I wonder what impact the special plate will have on Whipple, KB, and Edelbrock owners. I think we need more info on this subject.
You are totally correct on the lifting but you can have more insurance with a thick decked aftermarket casting like AFR or TFS vs the factory casting. Besides I can almost garrantee that it will be offered in a 6 bolt design. Every other TFS head above 235cc is offered in a 6 bolt design. The LS3 factory head probably has the worst reputation for lifting vs the other LS factory heads because of its deck thickness.
Old 11-09-2010, 06:06 PM   #5
Jason 98 TA
Drives: Camaro
We are working on our PRC LS3/L99 style aftermarket castings as well. They will bolt up to all the blowers & will have thicker decks for boost applications!!
Jason 98 TA is offline   Reply With Quote
Old 11-09-2010, 06:43 PM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
hmmmmm..... the estimated release date on the trick flows is january 1st, 2011.....\
which means they will be released in 2014...
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 11-10-2010, 12:06 AM   #7
Ovenmitt
Competition is good for business
Old 11-10-2010, 02:04 AM   #8
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
How long will before the release of your heads Jason I will be ordering your vvt cam and would like to have the heads to go with it.
Busy_Boi is offline   Reply With Quote
Old 11-10-2010, 07:07 AM   #9
danhr
BAMF SS
danhr's Avatar
quick note:
the Trick flow heads will have an 11* valve angle, opposed to the factory 15* valve angle.
This will help airflow and will help out with piston to valve clearance, as will the smaller intake valve
Stock Longblock
Old 11-10-2010, 09:18 PM   #10
Ovenmitt
I'll try to keep this post updated with relevant info as it becomes available.
Old 11-11-2010, 08:47 AM   #11
danhr
BAMF SS
danhr's Avatar
TFS HEADS
correction: 12* valve angle
estimated price: 2500-2700 (THIS IS AN ESTIMATED PRICE, BUT THAT'S THEIR GOaL)
Release date: Not Jan. 1, it is the first quarter of 2011
Current status: They are still dyno testing the heads
The said flow numbers are obviously cnc'ed numbers, they are not as-cast
They will be offer different runner sizes down the road
You will have a choice of either wanting to run the ls3 or ls7 intake when ordering (there are two different sets of heads)
Intake valves are NOT hollow stem
Stock Longblock
Old 11-11-2010, 09:36 AM   #12
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
So danhr, are these Trick flow heads worth waiting for? You seem to have a lot of knowledge on heads/cams. I am trying to decide if porting the stock LS3 heads is worth the money, or should I go with aftermarket heads. What do you think of the Mast black label heads? I have the G6X3 cam and full exhaust/tune/4.10's.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 11-11-2010, 10:02 AM   #13
danhr
BAMF SS
danhr's Avatar
Kind of a trick question. They are for the "more hardcore" so to speak......
The trick flow heads, flow really well, but they dont flow much more than a $1200 set of ported stock heads, at least not enough to justify the ~1300 price difference imho.
If you are buying these (Trick Flow) heads, you are buying more than just flow numbers, you are buying the "extras" like the thicker deck, valve angle, smaller intake valve (yet retaining the same intake flow numbers), etc. etc. etc.
IMHO, in your particular case, you might benefit from waiting for these heads, as you have the G6x3 cam. These heads will allow you to mill more to bump your compression up, without running into piston to valve clearance issues and having to flycut your pistons, with their already smaller than stock combustion chamber and 12* valve angle, and smaller intake valve. How much will you be able to mill? Unsure at this point.
Stock Longblock
Old 11-11-2010, 12:11 PM   #14
AG454
AG454's Avatar
Thanks for the info, what are you planning for your car?
Ported Heads & Options for LS3 calbert1999 Tuning / Diagnostics -- engine and transmission 32 02-24-2011 06:18 PM
not sure wht i want, please help streetsteve 5th Gen Camaro SS LS LT General Discussions 11 11-30-2009 09:58 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
