Old 11-10-2010, 11:14 AM   #1
BriCo84
Drives: 2011 CGM 2LT w/RS
Remote start and seat heaters
Ok guys so I need help on this one. It is finally dropping below 70 here in miami @ nights (I know freezing right?) And so I thought I would give the remote start with the seat heaters a try. I setup the config on the instrument panel to remote start auto heat seats on.
But it doesn't work!
I have tried turning the car off with the seat heaters on and off, nothing works. The seat heaters do not turn on when I remote start. Can someone please enlighten me on how this works. Is there something wrong with my Camaro?
-Sent via my R2D2 using Tapatalk
BriCo84 is offline   Reply With Quote
Old 11-10-2010, 11:38 AM   #2
racrx451
racrx451's Avatar
Drives: 2010 white SS
hmmm... are you letting it run for awhile to actually see if they are on? it may not display it on the actual button. my avalanche used to automatically turn the seats on and turn the heat/ac on depending on what the temp was out. it was great. I didn't know the camaro had that option.. I guess I will have to check that out. thanx.
racrx451 is offline   Reply With Quote
Old 11-10-2010, 11:48 AM   #3
R6P
R6P's Avatar
Drives: 2010 Camaro
Outside temp has to be 50F or below in order for heated seat function to turn on during remote start. Also the seat heater indicator lamps on the HVAC control will not be on, but the heater will be on.
R6P is offline   Reply With Quote
Old 11-10-2010, 11:57 AM   #4
BriCo84
50 or below! That's crazy. I know the light wont be on but it will when I put the key in right? Just like the air?
Old 11-10-2010, 12:46 PM   #5
R6P
R6P's Avatar
Drives: 2010 Camaro
Actually... when you turn the igition "on" after remote starting the vehicle, the seats turn off. You will need to turn them back on for continued operation.
I'm just the messenger
Old 11-10-2010, 01:12 PM   #6
Jessika
Drives: Anything Blown
You guys are lucky to have the option...
They did not do it in the G8 and it was 3 degrees BELOW this morning... of course below being under 50
Jessika is offline   Reply With Quote
Seat heaters Jeremeymt Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 11-10-2010 04:16 PM
Fitting a baby seat in the back of the Camaro monstertodd 5th Gen Camaro SS LS LT General Discussions 14 07-06-2010 09:41 AM
333 Ways to get kicked out of Walmart (just funny- do not try this at home) Abygale Off-topic Discussions 47 04-28-2010 02:20 AM
Remote Start... johndawg Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 4 01-10-2010 06:43 PM
10% off custom fit heated seat kits (4 to choose from) @ PFYC.com Redshift Interior Parts & Accessories 0 10-02-2009 09:38 AM
