Old 11-11-2010, 12:34 PM   #1
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
2011 Chevrolet Cruze ECO Achieves Segment-Leading 42 MPG Highway
New Chevrolet Cruze Eco Achieves Segment-Leading 42 MPG On The Highway
Hybrid-Like Fuel Economy Starts at $18,895; Goes on Sale in January
Link to Press Release
Link to Article at GMInsideNews
November 11, 2010
DETROIT – The official fuel economy numbers for the 2011 Chevrolet Cruze Eco are in and they’re good. Segment-leading good. It delivers an EPA-estimated 42 mpg on the highway (manual transmission models), with equally impressive city fuel economy of 28 mpg.
Cruze Eco’s highway fuel economy beats non-hybrid segment competitors – including 23 percent greater highway fuel economy than the Honda Civic – as well as the Ford Fiesta subcompact and many hybrid models. In fact, it’s better than Ford Fusion Hybrid, Nissan Altima Hybrid and Toyota Camry Hybrid.
“Chevrolet Cruze continues to redefine the compact segment, offering class-leading standard safety features, upscale amenities – as well as hybrid-like fuel economy without the price,” said Chuck Russell, vehicle line director. “The Cruze Eco is in a league of its own and will challenge perceptions of the efficiency available in a more affordable non-hybrid.”
The Cruze Eco carries an MSRP of $18,895 (including destination charge). It goes on sale in January.
To achieve its segment-leading fuel economy, Cruze’s engineers focused on aerodynamic performance, mass optimization and powertrain enhancements. The refinements in each area paid big dividends towards the car’s overall efficiency, while providing engineers with valuable information to help enhance the efficiency of future Chevrolet models.
“We left no stone unturned or piece of sheet metal un-weighed,” said Russell. “Our engineers were comprehensive and thorough when it came to evaluating and modifying the aspects of the car’s performance that contribute to fuel economy.”
Aero enhancements
Aerodynamic improvements over non-Eco manual-transmission models contributed approximately six mpg to the Cruze’s EPA-estimated 42 mpg highway fuel economy. Many were developed and refined in more than 500 hours of wind-tunnel testing of the Chevy Volt, which shares a core architecture with the Cruze. Examples include the upper grille, which has more “closeouts” to improve aerodynamics, a lower front air dam extension, a rear spoiler, a lowered ride height and underbody panels that smooth airflow beneath the car.
The Eco model also features an all-new technology in the compact segment: a lower front grille air shutter that closes at higher speeds to reduce aerodynamic drag and opens at lower speeds to optimize engine-cooling airflow. Another contributor to reduced drag is the use of ultra-low rolling resistance 17-inch Goodyear tires (used with lightweight wheels), which are also used on the Volt.
As a result of the aero enhancements, aerodynamic drag was reduced by 10 percent over a non-Eco model, with a coefficient of drag of 0.298. That places Cruze at the top of the class for mainstream compact cars.
Mass optimization
More than 42 changes were made on the Eco to reduce weight. It weighs in at 3,009 pounds (1,365 kg), compared to the 3,223 pounds (1,462 kg) of the Cruze 1LT. The diet program for the Cruze challenged engineers to look at all aspects of the vehicle’s construction, including hundreds of weld flanges on the vehicle. They were reduced 1 mm to 2 mm in length, which saved several pounds, while the sheet metal gauge thickness was reduced by about 0.1 mm in select components. This saved weight while preserving structural integrity.
Lighter wheels and tires are used on the Eco. They’re stylish, polished 17-inch alloy units with Goodyear tires that weigh only 36.5 pounds (16.6 kg) apiece. That’s 5.3 pounds (2.4 kg) less than the 16-inch wheel/tires of the Cruze 1LT for a complete savings to the vehicle of 21.2 pounds (9.6 kg).
Efficient powertrain
Cruze Eco is powered by power-dense Ecotec 1.4L turbocharged engine and a standard six-speed manual transmission. The transmission’s gearing is optimized for the model’s specific 17-inch wheel/tire combination and includes aggressive ratios for first and second gear coupled with a highly efficient, “taller” sixth-gear ratio for highway driving. That means engine rpm is reduced on the highway, which in turn reduces fuel consumption. A six-speed automatic transmission is available, with EPA-estimated fuel economy ratings of 26 city and 37 highway.
The Ecotec 1.4L turbo’s power ratings are 138 horsepower (103 kW) and 148 lb.-ft. of torque (200 Nm) between 1,850 rpm and 4,900 rpm. The wide rpm range for the maximum torque – a specific trait of turbocharged engines – helps the engine deliver a better driving experience and performance. The turbocharger is integrated within the exhaust manifold, for reduced weight and greater packaging flexibility.
The engine also features premium design elements that give it world-class smoothness and durability while also contributing to the Cruze Eco’s lower curb weight. They include a cast iron block with a hollow frame structure, hollow-cast camshafts and a plastic intake manifold.
2023 GMC Canyon Elevation
Old 11-11-2010, 12:40 PM   #2
Brokinarrow
Brokinarrow's Avatar
Drives: 2012 Honda NC700x
Wow, so same exact engine as the Cruze LTs, but just improved aerodynamics. Very nice!
Brokinarrow is offline   Reply With Quote
Old 11-11-2010, 01:32 PM   #3
Sax1031
Drives: 2000 Mustang GT
Sax1031 is offline   Reply With Quote
Old 11-11-2010, 01:38 PM   #4
Brokinarrow
Oh and also mass reduction and powertrain optimizations... so wait.... I wonder how much lighter the eco is vs the normal Cruze? If it's a couple hundred pounds..... wouldn't that mean the ECO model would potentially be QUICKER than the normal Cruze? (gasp!) Unless they messed with the gearing or something.... hmmm....
Old 11-11-2010, 01:48 PM   #5
FenwickHockey65
It's over 200 pounds lighter than a standard Cruze.
Old 11-11-2010, 01:51 PM   #6
DarthNacho08
SoCal C5 Family Member
DarthNacho08's Avatar
Drives: 1999 camaro
Send a message via AIM to DarthNacho08
I like your thinking
DarthNacho08 is offline   Reply With Quote
Old 11-11-2010, 02:24 PM   #7
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The Ford Focus with the ecoboost engine is supposed to get around 40 mpg highway
It also has low rolling resistance tires, though at the power levels of these cars that may not make a difference off the line. It would probably make a bit of a difference in handling though
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 11-11-2010, 02:44 PM   #8
Brokinarrow
Thank you sir!
Good point, so slap on some standard street tires and you get a potentially sportier Cruze May lose a couple MPG, but I wouldn't cry over them
Old 11-11-2010, 05:49 PM   #9
Morepwr
woohoo
Morepwr's Avatar
Drives: Silverado, 70cutlass, 57chevy&more
Pretty impressive numbers. I am seriously considering getting one as a daily driver.
I am not useless, I can still be used as a bad example!
Morepwr is offline   Reply With Quote
Old 11-11-2010, 05:55 PM   #10
Sevn86
Sevn86's Avatar
We had chevy reps. at my college today showing us all the new Chevy cars like the Equinox, the Camaro, the Cruze and the Malibu. The Cruze looked awesome!
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 11-11-2010, 10:14 PM   #11
TheCaptain
N7 Spectre
TheCaptain's Avatar
Can i say it again?
Chevy for the win! The Cruze looks awesome! I already got my own!
Old 11-12-2010, 11:52 AM   #12
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Thank you sir!
Exactly. Put on some tires with some grip and maybe a CAI and you could get some decent acceleration out of it. A cat back would add even more, but I'd have to wait till it comes out to decide if it would give it the bees-in-a-can vibe.
Also, I don't think the gearing would change acceleration. First and second gears would made more aggressive, 3/4/5 were left alone, and sixth was lengthened. You'd never touch sixth in a car like this anyway (or 5th even, most likely) so really all it does is make first and second a bit shorter, which would be good for 0-60 times.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 11-12-2010, 08:25 PM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Astounding!!!
Old 11-13-2010, 02:38 AM   #14
JJ#48Racing
Drives: 1998 Camaro SS
All your questions would have been answered if you had read the post.
JJ#48Racing is offline   Reply With Quote
MSRP or below, Dealers KILLER74Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 1316 09-10-2015 07:06 AM
YOUR WARRANTY INFORMATION Kwaz1335 5th Gen Camaro SS LS LT General Discussions 2 11-02-2009 06:23 PM
"So did you get the real Camaro or just a V6?" oldag92 5th Gen Camaro SS LS LT General Discussions 180 07-11-2009 02:07 AM
2009/2010 Chevrolet Cruze Mr. Wyndham General Automotive + Other Cars Discussion 53 08-25-2008 04:58 PM
