Old 11-11-2010, 02:27 PM   #1
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
Rear GM GFX Install Question
The upper edge of the GFX has numerous double sided tape points. The instructions use the phrase "wet out" start and the center and working your way around applying x amount of pressure.
Are they really meaning to use water and a bit or soap (like applying vinyl graphics) for a wet application, or is "wet out" just a phrase to describe the technique of hand pressure working your way to the edge
f5journal is offline   Reply With Quote
Old 11-13-2010, 01:35 PM   #2
wrbear
Banned
Drives: 2010, 2SS, IOM/CGM Stripes, 4/24/10
No don't apply water. Clean the area with a dawn dish soap and water to remove any wax etc. Peel and stick starting from the center working your way out. I taped the ends of the tape to the outside of the piece to make sure I didn't bury the tabs behind the piece. Apply pressure to bond the piece I taped it down for a day to make sure it bonded. Hope this helps!
wrbear is offline   Reply With Quote
Old 11-15-2010, 09:11 AM   #3
f5journal
f5journal's Avatar
Thanks...I kinda figured that out, but doesn't hurt to ask
Old 11-15-2010, 11:29 AM   #4
MR. FBDY
FBDY or no Body
MR. FBDY's Avatar
Drives: 2010 CGM ZL1 clone/13 Silverado HD
Wet-out just refers to applying pressure along the 3M tape as you pull the stand of tape out. You do not use any water to apply the GFX.
"Camaro Mike" of NY
CGM/M6/ZL1clone/GFX/Hurst/SLP/K&N/BMR/Niche
Happily cruizin 7/31/09
MR. FBDY is offline   Reply With Quote
Old 11-15-2010, 06:39 PM   #5
KnightRider
KnightRider's Avatar
Drives: Black 2SS/RS M6
Do you need to remove the entire rear bumper cover to install the GFX?
KnightRider is offline   Reply With Quote
Old 11-16-2010, 09:11 AM   #6
f5journal
f5journal's Avatar
yes..it has to come off to remove the diffuser and crush/shock absorber unit
Old 11-21-2010, 11:47 PM   #7
KnightRider
Thanks!
Just removed the diffuser today, those tabs on the top are so difficult to slap off, ended up using a heat gun to soften them up a little then they came out no problem.
rear speaker install (pictures) Shadowjack Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 11-03-2010 06:44 PM
NEW GFX front and Rear diffuser****SOLD**** Z2869 Exterior Parts & Accessories 15 09-21-2010 04:52 PM
Gfx exhaust compatible with stock rear fascia? Enzo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 08-06-2010 04:26 PM
Side and rear GFX only? Jimbabwe Cosmetics and Lighting Modification Discussions 8 07-09-2010 01:53 AM
