Old 01-11-2009, 11:26 AM   #1
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
GM Reveals Cadillac Converj Concept
DETROIT – General Motors unveiled a further glimpse at the potential of electric propulsion today, this time in the form of luxury transportation, with the Cadillac Converj Concept. The Cadillac Converj was developed as a well-appointed grand touring coupe with a bold design and a host of interactive technology.
The four-passenger Converj concept is intended to show how GM’s revolutionary electric propulsion technology – called Voltec – can power a luxury coupe with a typically Cadillac “no compromises” design. The technology enables up to 40 miles of gas- and emissions-free electric driving with extended-range capability of hundreds of miles.
Bob Lutz, GM's vice chairman of Global Product Development, said the Converj concept has production substance. “It’s a logical extension of our plan to reinvent the automobile,” he said. “It clearly shows what a Cadillac electric vehicle could look like, and clearly indicates that global luxury customers can have a car that has both strong design and electric propulsion with a total range of hundreds of anxiety-free miles.”
Cadillac’s extended-range electric vehicle (E-REV) concept has a new body style that is an evolution of the brand’s traditional Art and Science design theme. An aggressive, forward-leaning arc profile is the foundation for the sporting stance. And more than a Cadillac in form, Converj is also intended to be a Cadillac in substance, with the premium materials, technology and driving dynamics that are hallmarks of the brand.
Voltec – innovative propulsion technology
The Cadillac Converj’s Voltec electric propulsion system is made up of a 16-kWh, T-shaped battery, an electric drive unit, and a four-cylinder engine-generator. It uses electricity as its primary source to drive the car.
A thermally managed battery pack contains more than 220 lithium-ion cells that provide the primary power to drive the Converj electrically up to 40 miles without using fuel or producing tailpipe emissions. The battery is integrated into the Converj’s chassis and stores electricity from the grid when the vehicle is plugged in. It takes less than three hours to recharge the battery at 240V, or about eight hours from a 120V outlet.
When the battery’s energy is low, the Converj seamlessly switches to extended-range mode. During this secondary level of operation, electricity needed to power the vehicle is created on-board by a flex-fuel-powered engine that operates much like a home generator to create electricity. The engine-generator ensures a constant supply of power for hundreds of miles until the car is refueled or plugged in to recharge the battery. This extended-range mode eliminates the range anxiety that comes with driving pure electric vehicles that offer no backup power when the battery charge is low.
Whether in electric or extended-range mode, the Converj is propelled all the time by an electric drive unit. It converts electrical energy from the battery or the engine-generator into mechanical energy to drive the front wheels. It also delivers 273 lb.-ft. (370 Nm) of instant torque, for a quick launch, and 120 kW of power. The top speed is 100 mph.
There is no compromise in vehicle performance in either mode of operation. To enhance the ride feel, the Converj also features GM’s Magnetic Ride Control; and for even greater efficiency, energy during braking is captured and stored in the battery.
Pure Cadillac design
There’s no mistaking the Converj for anything but a Cadillac, according to Lutz. “An aggressive, forward-leaning profile hints at a new, progressive theme and proportion in Cadillac’s design evolution,” he says. “The new proportion showcases a uniquely shaped, modern vision of a personal luxury 2+2.”
The overall shape is reinforced by a prominent, sweeping body line with large, 21-inch (front) and 22-inch (rear) wheels pushed to the edges of the body. The Converj exterior is painted a dark silver tri-coat that GM designers dubbed “Reaction.”
An all-glass roof incorporates solar panels that help offset power drain from the vehicle’s accessories. Additionally, several aerodynamic and design efficiencies were incorporated to enhance the driving range, including:
* A full under-vehicle cover (belly pan)
* Minimal grille openings that reduce drag at the front of the vehicle
* Low-profile rearview cameras replace conventional outside mirrors to reduce drag
* Wheels are shaped to push air outward for smoother body side airflow
The Converj also incorporates vertical headlamp and taillamp elements, with light pipe technology.
“Vertical lamps are Cadillac signatures and the Converj builds on the brand’s light pipe technology with bolder light emitting diode (LED) and high-intensity discharge elements front and rear,” said Clay Dean, global design director for Cadillac. “There is also a unique daylight light ‘spear’ at the top of the headlamps.”
Luxury meets technology inside
The Converj’s interior has advanced features and luxurious appointments blending efficiency and environmental consciousness. The 2+2 configuration is trimmed in contrasting Winter White synthetic suede – including the top of the instrument panel – and Midnight Black leather, with polished aluminum and wood grain accents. Renewable materials are used throughout such as wool-blend carpeting, a headliner made from silk, suede made from post-industrial content and more.
A technologically advanced driver center increases efficiency and reduces the draw on the battery. Features include:
* New, organic light-emitting diode technology used on reconfigurable instrument cluster
* Touch-screen navigation, climate, center-stack controls and audio systems
* Adjustable, overhead white ambient lighting
* Unique “power on” sequence featuring blue-lit console graphics
* Screen displays for features including regenerative braking, battery charge level and power output
* No inside rearview or outside mirrors; cameras provide surrounding images on a screen placed high on the instrument panel for a full, panoramic view
* Push-button ignition and power-folding front seats
More pictures...
2023 GMC Canyon Elevation
Old 01-11-2009, 11:43 AM   #2
kanys
kanys's Avatar
Drives: 2010 Camaro
Looks pretty nice! I'd like to see a little more on how they were able to replace the side mirrors with cameras.
kanys is offline   Reply With Quote
Old 01-11-2009, 12:00 PM   #3
Camaro Lives On
Force RECON
Drives: 2005 Saab 9-5 2.3T
Send a message via AIM to Camaro Lives On
HOLY CRAP!! That is awesome!! At least we now know it's possible to have a hybrid-electric car that doesnt look ANYTHING like a Prius.
Camaro Lives On is offline   Reply With Quote
Old 01-11-2009, 01:17 PM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Holy Hell!!
Old 01-11-2009, 01:30 PM   #5
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Sweet baby Jesus
Kyle2k is offline   Reply With Quote
Old 01-11-2009, 01:40 PM   #6
WAY2FAST
WAY2FAST's Avatar
Drives: 2010 CAMARO 2SS Red M6
Sweet!
WAY2FAST is offline   Reply With Quote
Old 01-11-2009, 02:16 PM   #7
TheCaptain
N7 Spectre
TheCaptain's Avatar
Uhhh... if someone finds my jaw, and my mind, i'd like it back please!
I wondered if Caddy was going to do a Volt-like car... guess i know now!
Edit: i got my mind back, and do i ever LOVE that interior! Sex in vehicular form!
Old 01-11-2009, 03:59 PM   #8
lil_chef
Banned
Drives: 2010 Mustang GT
I wish the CTS coupe looked more like this!
either way i would buy this in a heart beat because it is beautiful
lil_chef is offline   Reply With Quote
Old 01-11-2009, 04:58 PM   #9
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
i hope this comes out so it can be my first hybrid
headpunter is offline   Reply With Quote
Old 01-11-2009, 05:09 PM   #10
ArcAngel
ArcAngel's Avatar
Drives: 07 Black Cobalt SS/SC
Send a message via AIM to ArcAngel
totally HOT
Through HIM you believe in GOD, who raised HIM from the dead and Glorified him..
ArcAngel is offline   Reply With Quote
Old 01-11-2009, 05:11 PM   #11
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
I think they can still work on the interior.
I don't like the whole blue part. It makes it look like a child's toy.
Old 01-11-2009, 05:43 PM   #12
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
Does anyone have any more info about the CTS coupe? It was supposed to be debuted at Detroit according to a buncha sources. Any new news?
And yes, this coupe is SICK. I would get one . . . if it came out soon!
OUTATIME is offline   Reply With Quote
Old 01-11-2009, 09:59 PM   #13
FenwickHockey65
CTS Coupe is pretty much on hold indefinitely...nobody really knows when or where it'll come back.
Old 01-11-2009, 10:07 PM   #14
The_Blur
Moderator
The_Blur's Avatar
I just ruined another pair of pants looking at this car. This is the second pair this week!
warn 145:159 ban
Cadillac E-Flex Concept The_Blur General Automotive + Other Cars Discussion 8 01-11-2009 02:25 PM
4 SEMA CAMAROS finally unveiled by GM! (hi-res images & details) FenwickHockey65 Camaro Photos | Spyshots | Video | Media Gallery 237 11-03-2008 11:39 PM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 04:33 PM
CADILLAC IS BACK... Scotsman General Automotive + Other Cars Discussion 17 06-01-2008 01:36 AM
