View Poll Results: side marker with turn signals
yes i would consider buying 14 66.67%
no i would not buy 5 23.81%
brighter turn signal when side marker on 3 14.29%
turn signal brightness is ok with side marker on 2 9.52%
Multiple Choice Poll. Voters: 21. You may not vote on this poll
Old 11-18-2010, 10:39 PM   #1
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
make side markers work as blinkers/turn signals, test
UPDATED, UPDATED, UPDATE WITH 2 LED STRIPS 11-19-10
ok i just installed 2 strips, WOW, so much better. check out the new video
hello guys, well i have seen many car/suv with a blinker between the door and front fender. i have always liked the way it looked, so i thought about putting one there. Well as i was driving on the hwy last night i thought it would be cool if both side marker could blink. well i went to autozone and pepboys this morning to see what i could come up with. i found the same bulb that is used in the side marker and i found a couple of different style sockets. the video and pics are with the original bulb installed and a 2nd bulb for the blinkers, i have only done the front marker at this time. tomorrow i will be doing the rear markers. i am also going to experiment with putting LED strips in them to make them brighter when the side marker light is on, it looks good when the side marker is off but when its on, i think it need to be a little brighter. let me know what yall think.
UPDATED TO REFLECT LED'S INSTEAD OF BULBS.
SOOOO, i would like to ask if anyone would be interested in these? here is my thoughts if this is something yall would like. i would buy the markers new and install the leds, i would ship them to you and you would ship your old markers back. i would make a video on how to put them in, the front snap out in 2-3 minutes including pulling the front fender lining. the 2 wires would tap into the front blinker wires. they are very easy to get to from the engine compartment. it took me 10 minutes to put the front one in after i modified in and wired.
now if there is an interest in these then i would have to become a sponsor,
again if there is interest, i priced the marker and leds with all the wires taps and tyraps that i would include.
price up front 270.00 for all four, return your markers and i will refund $140.00. the total would be $130.00 to have blinker/side markers. THIS IS FOR ALL 4, 2 FRONT AND 2 REAR.
let me know what yall think. i just an idea brewing in my little warped mind.
lupe
NEW VIDEO WITH LED'S, videos with bulbs removed.
overhaulengines is offline   Reply With Quote
Old 11-18-2010, 10:56 PM   #2
Soundwave
Soundwave's Avatar
Drives: Camaro SS(2)/RS
I think I'm missing the point in paying $120 to drill an extra hole and put an extra $2 bulb in the side marker when you could just rewire the bulb that's already there to work with the blinkers.
Soundwave is offline   Reply With Quote
Old 11-18-2010, 11:28 PM   #3
overhaulengines
yes you could do that, but then you wont have side marker lights at night, well you wont ever have side marker lights, only blinkers, they would only come on when the blinkers are on. thats the point,
lupe
Old 11-18-2010, 11:42 PM   #4
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
hell of an idea. i'm running my AAC led side markers, i would love to be able to get those to blink and be running lights as well.
Alain is offline   Reply With Quote
Old 11-19-2010, 06:45 AM   #5
Soundwave
Soundwave's Avatar
What? You would wire it so the side marker would have constant power, but cut out when the blinker is activated...you know, kinda how your brake lights work, they stay on at night, but blink on and off when they need to.
Face palm yourself.
He asked for opinions.
Old 11-19-2010, 07:44 AM   #6
overhaulengines
Face palm yourself.
hello, i dont know if you know this, but blinkers(brake lights)have 2 elements inside them and 3 wires going to them. 2 are power and 1 is ground. 1 powers the running light element in the bulb and the other powers the 2nd element in the same bulb when you push the brakes, those bulbs are also larger as a result. the side marker lights only have one element as they are pretty small. if the light is already on (at night) and you tap into it from the blinker wire, its not going to get any brighter when you turn on the turn signal because it already have 12v going to it, not only that, but what about back feed? you would now have to run a diode to keep power from back feeding to the blinker circuit when the side markers are on at night and the turn signal is not. that this why a separate light/element is needed. i looked for a small bulb with 2 elements but no luck. thanks for you input.
lupe
Old 11-19-2010, 09:58 AM   #7
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
I like it... would like to see someone post pics with LEDs... where did you get the turn signals for the mirrors?
FL1CK is offline   Reply With Quote
Old 11-19-2010, 10:27 AM   #8
The Stig
knows 2 facts about ducks
The Stig's Avatar
Click to view my build thread
Old 11-19-2010, 10:54 AM   #9
overhaulengines
hello, i just installed a 3 led strip in there, im going to post a video ina bit, im now thinking about putting 2 led strips, each strip would have 6 leds. i would eliminate the bulbs altogether, one strip out be blinkers and the other would be the running lights. thanks for yall input.
here is a link to my mirrors, did them myself with LED's
Flashing Side Mirror Mod
http://www.camaro5.com/forums/showthread.php?t=113157
lupe
Old 11-19-2010, 02:07 PM   #10
overhaulengines
UPDATED both blinkers and turn signal are LED's, WOW, so much better, let me know what yall think.
lupe
Old 11-19-2010, 03:18 PM   #11
copper3000
Troy
copper3000's Avatar
Drives: 2018 ZL1 Camaro
Sweet!
copper3000 is offline   Reply With Quote
Old 11-19-2010, 03:19 PM   #12
nice
Old 11-19-2010, 04:22 PM   #13
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
that is really cool. nice job.
Old 11-19-2010, 04:26 PM   #14
overhaulengines
thanks guys, if you have likes or dislikes, please let me know why. i just finished both front, probably wont be until monday before i do the rear markers.
thanks again
Lupe
Scrming's Air Intake Experiment - Part II scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 94 05-02-2010 04:56 AM
Blackout Side markers wanted Wheel Bug Exterior Parts & Accessories 1 08-13-2009 04:52 PM
Clear side markers slick rick Cosmetics and Lighting Modification Discussions 10 05-26-2009 09:53 PM
Another Camaro Magazine Test - Sorry... KJS 5th Gen Camaro SS LS LT General Discussions 40 04-21-2009 01:17 AM
