Old 11-20-2010, 09:51 PM   #1
tcarro2001
Drives: 2010 Black 2LT/RS
Amp in gm mtx subs not working
I have the GM MTX 10" subs in the sealed enclosure. The sub works when it wants to, and I'm tired of it. I want to get a ******** connector and put an amp in wired to the subs.
I pulled the subs out and stamped on the back is .7ohms 100watts.
What are some amp specs that I need for these subs. The lowest impedance that I can find is 1ohm, and with these in parallel they will only be .35ohms.
What should I look for.
Thanks
tcarro2001 is offline   Reply With Quote
Old 11-24-2010, 08:46 AM   #2
06blownSS
06blownSS's Avatar
Drives: 2010 Camaro SS
Thanks
Never have I heard of a sub running at .7 ohms! thats ridiculous! I dont know of any amp that will handle that for long periods of time. This is why I never go factory for sound upgrades.
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
06blownSS is offline   Reply With Quote
Old 11-24-2010, 10:19 AM   #3
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
Wouldn't that part be under warranty?
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 11-24-2010, 03:37 PM   #4
tcarro2001
Yes it is under warranty, well it was. I hate to deal with taking it to the dealer for a half assed fix and have it happen again...
I took the wiring harness out of the car. Then took the subs out of the box and pulled the amp and all wiring from the box. I connected the subs in series which should give me approximately 1.4 ohms. I got the speakers back in with the box sealed back up and the speaker wires coming from it. I have ordered the ******** adaptor which I hope comes soon, and I got an amp that is 1 ohm stable. I will have it all hooked back up the way I want it once the adaptor comes in. I'm hoping it sounds as good as I'm thinking it will. I'll report back once I get it going.
Replacing stock BA amp storm83 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 11-18-2010 02:46 PM
2 mtx 10's and apline 500 watt amp sasquash1984 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 07-19-2009 10:52 PM
Adding an Amp to the BA system... ZZcamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 07-09-2009 11:52 AM
