Old 11-22-2010, 02:12 AM   #1
jamnutz
jamnutz's Avatar
Drives: 02 Formula/2010SS/many others
Fidanza dual disc clutch issues (slipping)
Has anyone had issues with the Fidanza clutches slipping. As soon as I put mine in, after driving it for some miles, I gave it a little gas & it just spun, I've called their tech support line about 20 times & they won't call me back.
Has anyone else had issues with their clutches? My clutch has never seen even close to WOT, and I probably haven't spun the motor more than 4k rpm's since the clutch was installed.
Warning to everyone, their tech support will not call you back, I'm stuck with a clutch that never held. I'm to the point that I'm just gonna pull it and put a monster in it.
If any fidanza dealers on here can contact them & ask them to get in touch with me on here that would be great, they might be able to save some face with me.
Right now I would not recommend purchasing one of their clutches as if you have issues, they will not return your calls, or email's. Basically I flushed $1200 down the drain, and now have to get another clutch, because I can't get in touch with someone who will help me, or even find how to swap it out for another one, or if there is some issue with the hydraulics & these clutches that I may be able to fix without replacing the clutch.
If anyone has any good deals on Monster Clutches, hit me up, good chance you will get my business, as they never will again.
2010 CGM 1SS/RS Kinda Modded?? http://www.youtube.com/watch?v=ZEetM7I-vv8.
2002 Firebird Formula Built motor, sprayed like a cat in heat.
1987 Buick Turbo-T 72MM Bumper Scrapin Black Beast!
1991 GMC Syclone Built motor, big turbo, meth
99 Z28, Futral built stock CI LS1, TFS 215 heads, Fast 102/NW102, NX fogger, full suspension including anti roll bar, custom Rossler 4L60 with hybrid Auto/Manual VB, AC, just your every day 9 second street car.http://www.youtube.com/watch?v=t4A141oh_jo
New Project 90 Fox Body, LS1 Swap X-275 Race car. Shootin for the 4's.
jamnutz is offline   Reply With Quote
Old 11-22-2010, 06:42 AM   #2
Slowhawk
Drives: 1999 Trans Am
I had that problem before with that clutch. For duals we run Mcleods rst/rxt's.
Slowhawk is offline   Reply With Quote
Old 11-22-2010, 01:37 PM   #3
jamnutz
jamnutz's Avatar
Did they do anything to warranty it?
Old 11-22-2010, 01:51 PM   #4
Slim2SS
Black Thunder
Drives: 2010 Camaro 2SS/RS
I also had the findazzi clucth and it sucks. Took mine out and put in a ZR-1 clucth from Jennety and couldnt be happier. I only had a 1000 miles on mine and when it came out it looked like burnt toast!! Try calling ted jennety he might be able to help you with the warrenty issue.
JRE 416 9:1 Forged Stroker Package
Edlebrock E-Force Super Charger
JRE Blower Cam package
Cooling Mist Water/Meth
3.25 blower pulley
FAST 65 lb. hr. injectors
JRE Edelbrock fuel system upgrade
GM ZR-1 Clutch
Roto Fab CAI
Kooks Headers Jet Hot Coated
Kooks High Flow Cats
3" Magnaflow Stainless Steel Exhaust
Barton Short Throw Shifter
JRE Dyno Tune
Slim2SS is offline   Reply With Quote
Old 11-22-2010, 10:24 PM   #5
jamnutz
jamnutz's Avatar
Thanks man, I'll see if I can get in touch with him today.
I searched about 3-4 forums to see if people were having trouble with that clutch like I was, and couldn't find any people bitching about them, but I guess no one is complaining like I am. I'm really looking to pulling that tranny for the 4th time this year. :(
Old 11-22-2010, 10:54 PM   #6
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
Search Fidanza sucks in google... they do seem to have a lot of issues, mostly with their service.
xxlbeerz is offline   Reply With Quote
Old 11-22-2010, 11:19 PM   #7
jamnutz
jamnutz's Avatar
Good call man, never thought of that, got 149,000 hits.
Old 11-23-2010, 08:26 AM   #8
jamnutz
jamnutz's Avatar
Well, when I was looking for a new clutch the only people that had it in stock was Summit, I just called them, they are going to give me a full refund on the clutch. So I'll get my $1200 back for the clutch, then spend about 800 on a monster. I'm not even going dual disc this time.
The warranty guy at summit said that he had never heard of this problem with these clutches, so I told him to google Fidanza Sucks, and to check this thread to see that other people had problems. When he searched Fidanza sucks, he was like DAMN, go ahead & send it back for a full refund.
Old 11-23-2010, 08:54 AM   #9
SC2150
Usually improper air gap when setting up.....have had good luck with them in the past, but set-up is tricky. Monster is excelent.
Old 11-23-2010, 02:45 PM   #10
Slim2SS
Black Thunder
I am not disagreeing with your statement but mine was installed and set up by Jennety Racing and I am sure he knows how to set them up. I suffered with that clucth in my car for a thousand miles trying to break it in and get it to seat and it never did. The ZR-1 clucth Jennnety replaced it with was spot on from the very first drive of the car.
Only telling what happened to me and not arguing anybodys point of view!!
3.25 blower pulley
GM ZR-1 Clutch
Roto Fab CAI
JRE Dyno Tune
Old 11-23-2010, 11:55 PM   #11
jamnutz
jamnutz's Avatar
Mine was setup by my buddy who besides being an ASE & GM master Tech also builds hot rods out of his house as his second job. Doubt it was a setup issue. He does everything by the book. He doesn't just throw stuff in, he will read every bit of documentation and if he has to set it up with a micrometer, he will set it up to a T. He probably does more GM clutches in a week than most performance shops do in 3-4 month's.
Old 11-24-2010, 09:22 AM   #12
Slowhawk
Monster is a great clutch. Use them alot but if you already dumped $1200 willingly I would go Mcleod RXT. About the same price,very light peddle and handle a big amount of power.
Old 11-24-2010, 05:10 PM   #13
xxlbeerz
xxlbeerz's Avatar
Wow, Summit will do a refund on an installed clutch for you?
Old 11-24-2010, 10:09 PM   #14
jamnutz
jamnutz's Avatar
Cool man, I'll look into it, I've watched you post for the last 8 years or so on Tech, so I know you know what you are talking about, I am running a little over 700 RWHP on the kit, but the Fidanza never even saw 3/4 throttle, so it never even saw any real power & I never hit the kit with that clutch.
I just feel burnt after the fidanza thing & wasn't planning on going back with a dual disc, but I'll keep researching, I won't really be able to order anything until at least black friday, or even Monday. So still have time to make my decision. With a single disc, I can deal with clutch chatter, no problem, I can not deal with slipping. I'm trying to get this thing into the 9's & I'm almost there doing most of the modding out of the house & my buddies shop on a stock short/heads.
It just really sucks, I'm supposed to be spending my free time building my LS1 powered Fox Race car, not continually pulling the trans on the 5th gen. First the broken main shaft in the trans, now the clutch issue. I work away from home, if I wouldn't have spent so much time on the damn 5th gen, the Fox would have been fired up already. :(
Late Model Racecraft's NEW Twin Disc Clutch!! Late Model Racecraft V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 25 07-12-2009 04:46 AM
Fidanza clutch and flywheel coming soon SoloSK71 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 06-29-2009 03:49 PM
Clutch issues race29 3rd Generation Camaros 2 04-06-2009 04:36 PM
Clutch issues? o2camaross V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 11-11-2008 02:16 PM
Dual clutch transmission (DCT)? Bruno Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 03-08-2008 04:47 PM
