Old 11-27-2010, 03:23 AM   #1
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Garage Heater needed! any suggestions?
Winter is coming and I got a ton of things I want to do to my car. I have a 2400 square foot garage, insulated metal building. Natural gas already ran to it. Anyone have any suggestions on a gas heater? where to get one? I dont like to work on the car in a coat...And I want to be able to live out there every night.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 11-27-2010, 04:07 AM   #2
Supercharged SS
Drives: 2010 Camaro
Grainger. Get the ones that hang from the ceiling. I heat all my garages this way. Very easy to install. Not sure on the btu for that particular size but it'll be on the site. I'm assuming that you have high ceilings. The building code in CT requires a certain height plus with this you don't want them to close to your head!
Old 11-27-2010, 04:18 AM   #3
Orange Krate
Not just any car!
Orange Krate's Avatar
Drives: Orange Krate DOB - 11/22/2010
Originally Posted by Supercharged SS View Post
Grainger.
+1 Grainger rocks! It is like the real man's (and woman's) hardware and supply store. I love their warehouses. There is one a block from my work. I am working on a project with Grainger too. Good people.
Here's a link: http://www.grainger.com/Grainger/gas...ecatalog/N-8z5
Simi Valley, CA
email: jimeads@pacbell.net
Orange Krate is offline   Reply With Quote
Old 11-27-2010, 05:18 AM   #4
2010 SS RS
2010 SS RS's Avatar
bingo...perfect...I did not even think about them...just know HD and lowes dont have em...and I was having a mind blank...
14 ceilings concrete floor and R30 insulation pack...They will have the size calcs for me I am sure....Thanks guys...
Old 11-27-2010, 06:50 AM   #5
Big Brunsy
Drives: 2010 supercharged LS3
well for the ultimate heating you should have thought ahead and put floor heat in b4 you poured your cement. Grainger has about everything a guy could think of. I think our cataloug at work has like 6000 pages of stuff in it.
In my 2.5 stall insulated garage I just run a medium sized natural gas heater that hangs on the wall, and that works alright. For REALLY cold days I also have an LB white heater hanging from the cealing that is fed by a 100lb propane cylinder.
Big Brunsy is offline   Reply With Quote
Old 11-27-2010, 08:08 AM   #6
afireinside
Firefighter/Medic
Drives: 2010 Camaro 1SS LS3 IOM, 2008 Z71
how do you buy from grainger online? Im not part of a group I wnt a heater for home but cant finish the account sign up
Mods: LSR Sway Bars, LSR Short throw shifter, MPD1 spoiler, Heritage Grille, 5% Limo tint
afireinside is offline   Reply With Quote
Old 11-27-2010, 08:17 AM   #7
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
My gagarge is 24'x26'. I have a Modine Hot Dawg. Runs on natural gas and hangs from the ceiling. About the size of a small a/c unit and direct vents straight out. I leave it at 45 degs all the time, and jack it up to 60-65 when I'm out there.....great investment, can't imagine my garage without heat.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 11-27-2010, 08:55 AM   #8
BOOGIE
BOOGIE's Avatar
Drives: Camaro Vert & Avalanche
Good info!! I just started a 25x40 now and was wondering the same thing
BOOGIE is offline   Reply With Quote
Old 11-27-2010, 09:15 AM   #9
hotrodhoodrat
hotrodhoodratz
hotrodhoodrat's Avatar
Drives: 68' & 70' Pontiac's /2004 D. Dakota
Hay Boogie,
could you post what you had to go through to start your Shop (from beginning to end ?), I'm thinking of doing a shop in the back of my property & use my 2car/Garage to park my vert (only), but I need to look at what I should do and what I need to have to start mine.
Maybe do a new a new post Boogie ?, if you like to ?
Sorry guys, plz don't be mad @ me for me jacking this post..... , great info !
The all new Convertible !, Welcome to the Fleet !
hotrodhoodrat is offline   Reply With Quote
Old 11-27-2010, 09:16 AM   #10
chain777
Drives: Slow
Like mentioned earlier, if you're just building a garage, radiant hydronic floor heating is the way to go. You rough in the pex tubing in the concrete slab.
Then attach to the controls and a heat source. It's more expensive than other methods, especially if you need a hot water heat source, but it's also going to save you money down the road in operating expense because it's more efficient.
But the real reason to go this way is comfort. Once you experience this, you'll want it everywhere. No noise, no fluctating tempertures, and because of the radiant effect, the heat's where you need it instead of on the ceiling.
chain777 is offline   Reply With Quote
Old 11-27-2010, 09:21 AM   #11
trm0002
VIN #2G1FT1EW6A9100074
trm0002's Avatar
Drives: 2010 CAMARO 2SS/RS RJT VIN 00074
Send a message via AIM to trm0002
Only one place to get a REAL garage heater from my friend- ready to order one myself...
Obviously you'll need a bigger size but I've found they're the cheapest on the web for Reznor.
http://rockwellequipment.com/shop/pr...products_id=14
trm0002 is offline   Reply With Quote
Old 11-27-2010, 09:53 AM   #12
Blue Bandit
blue bandit
Drives: 2018 2SS
Menards has Garage heaters 30,000 btu heats 1000sq ft for $136 and a 45,000 BTU for $448
Blue Bandit is offline   Reply With Quote
Old 11-27-2010, 10:12 AM   #13
BOOGIE
BOOGIE's Avatar
Hay Boogie,
I got a building permit then ordered the building the place that I got the building from got me a guy to do the slab and erect the building and that's as far as I got.
Old 11-27-2010, 10:33 AM   #14
motorhead
twenty-five year heating and cooling pro here. I have a condensing gas furnace in my garage.
It's a lot more efficient than a Unit heater plus I have A/C on mine which you can't do with a Unit heater from Grainger. Radiant heat is okay as long as you plan on heating the garage all the time. It takes a long time for the slap to heat up plus if you don't maintain some heat it could freeze up unless you use antifreeze. I like being able to turn my heat off in the garage when I'm not using it and having it quickly heat up when I do. You can't do this with radiant heat.
For 2,400 Sq/ft where you live without knowing all the specifics on the building and not knowing what max temp you want to maintain I would say as a rough est. you need about 100mbh of output.
Garage HELP Jarhead 5th Gen Camaro SS LS LT General Discussions 0 02-02-2010 09:31 AM
Preventing and Cleaning Garage to Protect Camaro? Patfan1987 5th Gen Camaro SS LS LT General Discussions 17 01-31-2010 10:14 AM
Headin down to San Antonio .. Suggestions needed!! Snuggles USA - Texas 10 11-11-2009 11:13 PM
B&B Suggestions Needed Batman0837 Off-topic Discussions 0 11-05-2009 07:42 PM
Suggestions needed to help me from exploding with joy! SSOOCH 5th Gen Camaro SS LS LT General Discussions 25 06-20-2009 11:44 AM
