Old 12-09-2010, 10:58 PM   #1
Memphis SS
Memphis SS's Avatar
Drives: 2017 SS A8 Hyper Blue/White Stripes
2011 Rear Spoiler issue
Just wanted to post a THANK YOU to the forum members that posted the information on how to fix the rear spoiler and chipping paint problem. I was keeping a eye on mine and noticed the other day that the clearcoat was scuffed. I removed the spoiler and noticed it was starting to get into the paint. I was able to buff it out and made a trip to Lowes for rubber washer, worked out great it raised it about 1/16 of a inche and took care of the problem. When I took the spoiler off the washers were coming apart that come from the factory. So to any 2011 owners GM did not fix the issue on the 2011 Camaros.
Again Thanks for posting the info here!!
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD
Memphis SS is offline   Reply With Quote
Old 12-10-2010, 07:51 AM   #2
Memphis SS
Memphis SS's Avatar
I posted a link to the thread on spoiler damage and the post by Russell James below that shows the parts need to do your own repair..
http://www.camaro5.com/forums/showth...89#post2320489
Old 12-10-2010, 09:50 AM   #3
Johnnyma45
Former Camaro Owner
Johnnyma45's Avatar
Drives: 2011 Dodge Charger R/T
I just took mine to the dealer, they repainted the deck lid and added spacers to the spoiler so it wouldn't happen again. Kinda sucks it still happens on the 2011s, I thought they fixed the issue with the 2010s.
6/9/10-3/30/11. RIP ROXY... :(
Johnnyma45 is offline   Reply With Quote
Old 12-10-2010, 09:54 AM   #4
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
I hope they did not use the foam like spacers or you are gonna have the same problem. I saw the kits they sent out to fix this to dealers and those washers are only a temporary fix. They will disintegrate and you will have the same problem. Just an FYI.
Old 12-10-2010, 11:20 AM   #5
Johnnyma45
Former Camaro Owner
Johnnyma45's Avatar
...um, not sure, I think they are actually. Back to worrying again, thanks alot! This from another Michigan man!
Old 12-10-2010, 02:32 PM   #6
BackinBlackSS/RS
Go Blue!!!!!
Sorry, didn't want to make you worry, but the spacers are crap. Keep an eye on it. GO BLUE!!
Old 12-10-2010, 05:19 PM   #7
Memphis SS
Memphis SS's Avatar
Might be worth taken it off and checking. You can get the solid rubber washers at lowes very cheap and it only takes about 20 mins to change. Maybe worth the time.
I'm glad I caught mine before it damaged the paint to point of not buffing out.
Old 12-12-2010, 04:09 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Just so everyone's aware -- if you bring it to the dealer, reference Service Bulletin #PI0319.
It's a new SB as of this month...so some dealership service departments may or may not be aware of this as an issue.
If they determine your problem to be the same problem described in the bulletin, they should cover it under warranty.
Old 12-12-2010, 04:50 PM   #9
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Service Information
Document ID: 2549392
#PI0319: Chipped Paint on Rear Compartment Lid at Spoiler Mounting Area - (Dec 2, 2010)
Subject:Chipped Paint on Rear Compartment Lid at Spoiler Mounting Area
Models:2010-2011 Chevrolet Camaro
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2549392&releaseDate=2010-12-02&name=Chipped+Paint+on+Rear+Compartment+Lid+at+S poiler+Mounting+Area&from=ns&bulletinNbr=PI0319#ss 1-2549392">Condition/Concern
Some customers may comment that the rear compartment lid mounted spoiler is making contact with the rear compartment lid. This contact condition may cause paint damage to the rear compartment lid.
This condition may caused by the spoiler gaskets and spacers having insufficient material thickness.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2549392&releaseDate=2010-12-02&name=Chipped+Paint+on+Rear+Compartment+Lid+at+S poiler+Mounting+Area&from=ns&bulletinNbr=PI0319#ss 2-2549392">Recommendation/Instructions
A spacer kit with revised gaskets and spacers has been made available to correct this condition. Use the following steps to remove the old gaskets and spacers from the spoiler and to install the new spacer kit onto the spoiler.
  1. <LI type=1>Remove the fasteners that attach the rear edge of the rear compartment lid carpet. Lower the rear edge of the carpet to access the center spoiler fasteners (it is not necessary to remove the complete carpet assembly).
    <LI type=1>Remove the four plugs on the rear outer corners of the rear compartment lid. <LI type=1>Loosen and remove the six spoiler fastening nuts. <LI type=1>Release the one center mounted spoiler retainer and remove the spoiler from the vehicle. <LI type=1>Place the spoiler assembly on a clean work cloth with no dirt or debris that may damage the paint finish on the spoiler.
    <LI type=1>Remove the foam rubber gaskets and spacers from the underside of the spoiler assembly. There are seven gaskets and six spacer strips. <LI type=1>Use a general purpose adhesive solvent to remove any rubber or adhesive residue left on the spoiler assembly.
    <LI type=1>Install the two short and four long spacers on the underside of the spoiler in the same position as the original spacers. Note: There are seven round gaskets in the kit. The six thicker gaskets go on the mounting studs, the one thin gasket goes on the retaining clip.
    <LI type=1>Install the six gaskets onto the spoiler assembly at the mounting stud locations.
    <LI type=1>Install the one retaining clip gasket. Important: It is important to perform the paint repair to prevent future corrosion concerns.
    <LI type=1>Repair any paint damage on the rear compartment lid. <LI type=1>Reinstall the spoiler assembly. <LI type=1>Apply GM MEDIUM-STRENGTH THREADLOCKER - BLUE #12345382 (in Canada, use 10953489) to the rear spoiler studs. <LI type=1>Install and tighten the six nuts to the rear spoiler studs. Tighten
    Tighten the nuts to 6 N·m (53 lb in).
    <LI type=1>Reinstall the four plugs on the rear outer corners of the rear compartment lid.
  2. Reinstall the fasteners that attach the rear edge of the rear compartment lid carpet. With the rear compartment lid carpet installed, check the emergency release handle for binding or sticking. If it is binding or sticking, refer to Corporate Bulletin Number 10-08-66-001.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2549392&releaseDate=2010-12-02&name=Chipped+Paint+on+Rear+Compartment+Lid+at+S poiler+Mounting+Area&from=ns&bulletinNbr=PI0319#ss 3-2549392">Parts Information
Part Number
Description
Qty
12345382
GM MEDIUM-STRENGTH THREADLOCKER -- BLUE #12345382
As Required
22785872
Spacer Kit - R/End Spoiler Support
1
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2549392&releaseDate=2010-12-02&name=Chipped+Paint+on+Rear+Compartment+Lid+at+S poiler+Mounting+Area&from=ns&bulletinNbr=PI0319#ss 4-2549392">Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
B9957*
Install Rear Compartment Lid Spoiler Gasket Kit
0.6 hr
* This is a unique labor operation for PI use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2010 General Motors. All rights reserved.
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 12-12-2010, 05:36 PM   #10
427Carl
427CARL
427Carl's Avatar
Drives: 2011 Camaro SS 6speed
Send a message via Yahoo to 427Carl
Wow they finally admitted!!! Thank God for a heads up from a member, I fixed mine as well... Didn't want re-paint......
427Carl is offline   Reply With Quote
Old 12-12-2010, 10:42 PM   #11
Jaime068
Treasure Coast Camaro 5
Jaime068's Avatar
Drives: 2010 Camaro 1LT/RS RJT
WAIT, so does this happen with EVERY '10 or '11 camaro????....I've never checked mine to see if it has chipped paint but will tomorrow morning.
Jaime068 is offline   Reply With Quote
Old 12-12-2010, 10:48 PM   #12
Mr. Wyndham
No. But there's enough cases to warrant a service bulletin.
Old 12-12-2010, 10:57 PM   #13
coolman
Guest
What I can't believe is that something like this didn't show up during the testing phase of the camaro. I've seen new cars on the lot with this problem. It makes one wonder if the paint on the testers were better somehow.
coolman is offline   Reply With Quote
Old 12-12-2010, 11:00 PM   #14
Mr. Wyndham
It could be a disconnect between the supplier of the spacers/gaskets and the original specs. Wouldn't be the first time a supplied part has been sub-par.
*/ *\ * FREE SHIPPING ON ALL 2011 CAMARO'S - PREFERRED PRICING FOR EVERYONE * / * \ * CamaroScotty Dealer Camaros for Sale 1 11-06-2010 11:27 PM
Anyone have this chin spoiler or this rear spoiler? gtothep123 Cosmetics and Lighting Modification Discussions 6 01-31-2010 09:16 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
