Old 12-15-2010, 08:36 PM   #1
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
Question timing chain tensioner
is it necessary to change the timing chain tensioner when changing the cam?
thanks
paul
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 12-15-2010, 09:15 PM   #2
SC2150
If you have over 100k miles on the motor I would, otherwise your fine.
Old 12-15-2010, 09:30 PM   #3
sspaul
sspaul's Avatar
thanks i don't even had 12k on the motor.
my youtube
my facebook
750/641 rwhp/rwtq
Old 12-15-2010, 09:57 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
many people do swap out to the ls2 style chain dampner as the ls3 style have been know to blow apart
Old 12-16-2010, 08:22 AM   #5
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
The tensioner is fine for most appliations. Many times with most of the cams on the market, they require a three bolt late model timing sprocket. With a three bolt cam you can purchase a LS7 timing sprocket and reuse your OEM timing chain and tensioner setup (this is the most common solution for most Heads/Cam type applications.) If your seeking more power then it may in fact be a good idea to upgrade to a billet timing set such as JP engineerings which will eliminate the use of the OEM tensioner, and be much more durable.
Regards
IPS Brandon is offline   Reply With Quote
Old 12-16-2010, 01:01 PM   #6
sspaul
sspaul's Avatar
how much for the billet timing set?
my youtube
my facebook
750/641 rwhp/rwtq
Old 12-16-2010, 04:35 PM   #7
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
[QUOTE=sspaul;2641862]is it necessary to change the timing chain tensioner when changing the cam?
If staying with a single bolt cam and cam gear no change needed. However, if you are going with a 3 bolt cam dump the tensioner and use the GM dampner. Just like on the Vette ZR-1 that uses a 3 bolt cam. You can reuse the chain. Go to the Lingenfelter site and you will see what they sell and recommend and install in all their motors using 3 bolt cams. Many shops do not do this because of added labor to lower pan to change out the tensioner to the dampner. Do not cut any corners, do what GM does.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 12-17-2010, 12:41 PM   #8
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
[QUOTE=Sack Rat 2SS;2644451]
So what is the difference in the timing sprocket for the 3 bolt cam versus the single bolt that warrants the use of the ls2 style dampner? Besides the # of bolts, of course. I am going to be installing a 3 bolt cam after the holidays, so I want to be as educated as possible on this.....
2010 2SS..LS3..Procharger..4l80e..DSS 9"
1stGM is offline   Reply With Quote
Old 12-17-2010, 03:32 PM   #9
Sack Rat 2SS
The teeth on the 3 bolt cam gear are very slightly different. You have to look very hard to determine every 3rd or 4th tooth are different from gear on one bolt cam gear. The dampner goes with the 3 bolt cam gear, not the tensioner. The kit to do the job properly form LPE Engineering is only $70. I had to be shown this difference by my tuner. Check it out.
Silver 2SS/RS Man/6
GM 3.91 Rear Gears
Old 12-17-2010, 04:08 PM   #10
1stGM
1stGM's Avatar
thanks for the info. I purchased a 3 bolt cam kit that has the gear, but does not include the dampner. So, if I am understanding this correctly, I can use that cam gear, my factory chain and purchase the LS2 dampner and I will be good to go.....
Old 12-17-2010, 05:07 PM   #11
Sack Rat 2SS
1stGM - Sounds good. The dampner looks totally different from the tensioner. Are you doing yourself? Good Luck
Silver 2SS/RS Man/6
GM 3.91 Rear Gears
Old 12-17-2010, 06:53 PM   #12
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
I'm in the same boat as I ordered the three bolt gear but not the dampner. After a little searching from Grrrr8.net I found the part # is 12588670 (hope it comes with bolts). I'm gonna try to order it locally from a dealer tommorrow morning.
Irnwkrkev is offline   Reply With Quote
Old 12-18-2010, 09:00 AM   #13
Irnwkrkev
Irnwkrkev's Avatar
Got it ordered this morning from my local dealer for $36 and they said it includes bolts.
Old 12-19-2010, 05:51 PM   #14
1stGM
1stGM's Avatar
Thanks, and yes I will be doing this swap myself... no sweat.... Just doing a lot of reading for pointers....
Timing belt or timing chain? tradosaurus Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 37 08-10-2012 07:21 PM
Nicoderm Patch lakers171 Off-topic Discussions 28 11-13-2009 08:20 PM
Timing chain failures on LS3 vettes detroitboy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 04-12-2009 06:53 PM
So...the L76... Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 51 04-07-2008 01:21 PM
VVT on the new Camaro Casull Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 04-01-2007 01:55 PM
