dirtbag
Drives: 2010 camaro LS Join Date: Mar 2010
anyone that is intrested in doing cam regrinds
i have been talking to crow cams in aus. he said that they have done some regrinds and are planning on coming out with a set of cams next year some time, but he sent me this to try to help. he also told me that the cams are the same in the llt (im not sure how he knows that but w/e)
******* CROW CAMS SELECT PROGRAM ******* 16 COLBERT RD CAMPBELLFIELD 3061 phone (03) 9357 0469 fax (03) 9357 0001 WWW.Crowcams.com.au MODEL TYPE ---------------------------CROW COMPUTER CARD---------------------------- | PART NUMBER 1446RH Date 16-DEC-10 | | Cam type: Hydraulic Roller type Profile | | ----------------------------------------------------------------------| | Advance Ground on Cam: 2 Lobe separation: 110 | | .050 VALVE TIMING | | Inlet opens: 3 BTDC Closes: 39 ABDC .050 Duration: 222 | | Exhaust Opens: 43 BBDC Closes: -1 ATDC .050 Duration: 222 | | ADVERTISED VALVE TIMING | | Inlet opens: 28 BTDC Closes: 64 ABDC ADV Duration: 271 | | Exhaust Opens: 68 BBDC Closes: 24 ATDC ADV Duration: 272 | | Inlet lobe lift at TDC on the over lap: | | ----------------------------------------------------------------------| | Valve lift Inlet: .2968 Inlet Rocker Ratio: 1.00 | | Valve lift Exhaust: .2968 Exhaust Rocker Ratio: 1.00 | | | | ----------------------------------------------------------------------| | RECOMENDED VALVE TRAIN COMPONENTS Kit Number: | | Valve Springs: Spring height: Collets: | | Retainers: Pushrod: Lifters: | | H/D Timing Set: | | ----------------------------------------------------------------------| POST CODE ATTENTION...ATTENTION At this time Crow Cams does not keep in stock billets for this model car but as demand increases we may add them to our extensive range of billets in the mean time this cam can be reground to this Profile depending on profile the cam may have to be HARD FACED (WELDED) ALL ENGINES To ensure your camshaft is the correct model for your application place new cam next to old cam and check the following points Do the lobes all point the same way Are the holes or grooves in bearing journals the same Is the distributor gear the same size and angle and position on camshaft. Is the fuel pump lobe in the same place on the camshaft |
Whats a Millwright?
Drives: 2LT/RS SIM, 05 Wht Denali Join Date: Feb 2010
At least it is a sign of hope. Kinda wanted to preserve and keep my stock cams when i got new ones. Really dont want to use mine as the perfomance set. But then......not sure why i would want to go back stock once i have it done.
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09 Join Date: Aug 2009
having FUN now 13.66@101
Yeah, we do it all the time for the dies.
Whats a Millwright?
Cast can be welded. Just requires some extra effort and time to prep and cool. Got to have the equipment to do it or you won't be pleased with the results.
#6 |
dirtbag
just got this in a email from crow cams......the wheels are turning...
To regrind a set would cost $350 aus(+ $250 if we supply 2nd hand cams for grinding) The cost of the new cams is not finalised yet so l cant give you a price yet Martin |
#7 |
Retired
#8 |
Retired
Ima wait in the peanut gallery on this one.
#9 |
I was thinking along the lines of welding a draw die for sheet metal stamping dies, for a re-cut of a change to product.
#10 |
dirtbag
#11 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
With a traditional hyd roller push-rod motor the hardness is not as big of an issue as an overhead cam application is.
We do regrinds all the time with them since no additional material needs to be added. I always keeppopular V8 grinds in stock and it is only a 3-5 day turnaround for any custom profile. Gotta watch and see on this for the LLT......could be promising! |
#12 | |
dirtbag
| Cam basics | CamaroSpike23 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 76 | 11-25-2015 12:42 PM |
| Vector Motorsports Stage 2.5 cam kit installed! pics and video | topgun1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 38 | 12-18-2010 11:28 PM |
| Finally--VMS Stage 2.5 cam Dynojet results, nice gains! | topgun1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 32 | 11-25-2010 10:55 AM |
| VVT Cam Specials! | yyz28 | Engine Internals | 17 | 10-19-2010 12:29 AM |
| L99 TVS 1900 + Cam Dyno #'s ARE IN | pharmd | Forced Induction - V8 | 35 | 09-07-2009 05:36 AM |
