Old 12-19-2010, 10:11 PM   #1
1977chevy
Drives: 2010 Camaro 2ss/rs
LOUD CLUNK NOISE IN THE REAR
IVE BEEN HEARING A LOUD CLUNK NOISE IN THE REAR OF THE CAR WHEN I HIT A BUMP IN THE ROAD, ANYONE ELSE HAD THIS ISSUE?
1977chevy is offline   Reply With Quote
Old 01-02-2013, 01:49 PM   #2
Bucci
Bucci
Bucci's Avatar
Drives: 2010 2SS M6
Bump = Clunk / Clang Noise
I have a Clunk / Clang noise coming from the back as well. It almost sounds like metal on metal clanging
Bucci
Bucci is offline   Reply With Quote
Old 01-02-2013, 02:09 PM   #3
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Probably exhaust. Even though it may sound as if it's in the rear. It doesn't mean it is.
Climb under, grab a pipe and push up then pull down. See if it's hitting the tunnel brace or the heat shield. You can also bang on it with a rubber mallet and see if you can hear anything.
Then check to make sure your battery, spare or inflator kit is properly secured.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 01-02-2013, 03:14 PM   #4
Dznts
Anabolic Connoisseur
Dznts's Avatar
does your car have aftermarket lowering coils?
Old 01-02-2013, 04:20 PM   #5
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
1. Spoiler nuts stuck in truck lid <- heard alot of people having this issue.
2. look in rear lower control arms for bolts to the suspension. <- I had this issue with my Camaro.
Moorepheus is offline   Reply With Quote
Old 01-02-2013, 08:58 PM   #6
Bucci
Bucci
Bucci's Avatar
Drives: 2010 2SS M6
I will get under and chech it out.... Cold outside right now but I will be able to get in a heated garage this weekend.
Thanks for the tip...
Bucci
Old 01-02-2013, 08:59 PM   #7
Bucci
Bucci
Bucci's Avatar
Drives: 2010 2SS M6
Nope no lowering coils. Yet...
Bucci
Old 01-02-2013, 09:01 PM   #8
Bucci
Bucci
Bucci's Avatar
Drives: 2010 2SS M6
Thanks a lot? I will check these as well.
Best,
Bucci
Very loud fan noise under hood with A/C Dentyneice Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 06-29-2010 03:59 PM
who has the best bushings? VRMMMM Suspension / Brakes / Chassis 10 05-07-2010 07:11 PM
Static noise from rear speakers at 2500RPMs etrigan Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 02-24-2010 09:56 PM
VERY LOUD POP FROM REAR END My new Camaro 5th Gen Camaro SS LS LT General Discussions 17 09-20-2009 02:23 AM
