BMR Trailing Arms Grease
Hello,
I received a set of BMR trailing arms for my camaro and they look great. I wont be installing these until spring but on the instructions it says: Grease both fittings approximately 3-4 pumps or until you see the bushing just start to bulge. It does not specify the type of grease needed. I did not get the grease from BMR. I also read somewhere it said to use a synthetic grease, but most of these greases are synthetic these days. Does it need to be a silicone type or something else? Thanks. |
I guess not too many people have installed these.
CamaroFans.com
I've got a set in my truck to go on soon if that counts.
I'll be using whatever is in the pump in my tool box... IMO don't think it matters much... but I could be wrong...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Any multipurpose/ lithium grease will do ..You will need a grease gun.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
![]() ![]() Drives: 2010 SS RS Join Date: Apr 2009
Use synthetic grease for poly bushings. Thought instruction said it. I pre-greased them before install to ensure air pockets were purged. Packed the outer bushings well, too. I don't like squeaks. I can't find tacky Super Lube in any local shops so used amsoil. After installed and wheels down, greased fittings again.
#6 |
ive got a grease gun (well my uncle does) so thats not an issue. Just making sure if there was any specific synthetic grease needed.
#7 |
Suspension Specialist
Drives: 2011 Camaro Join Date: Aug 2010
Greasing any rotating poly bushing is critical for noise reduction.
mike dms |
#8 |
Drives: 2010 1SS Join Date: Jan 2010
If at all possible it needs to be a silicone-based grease. Petroleum based greases tend to deteriorate polyurethane bushings over time and should be avoided. We use a specially formulated silicone grease designed specifically for poly bushings. If you can't find silicone based lube, use synthetic marine grease. It's a little stickier and not so prone to washing out of the bushings...
#9 |
Hey BMR Guy are you guys ever going to make front end components??????????
#10 |
@ BMR guy. My bushing kit squeaks like a mofo, any remedy? Is it just the nature of the " beast"
#11 |
![]() Drives: 2023 ZL1 Join Date: Oct 2010
Synthetic marine grease will work and you can find it at Home Depot.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Race Car Join Date: Sep 2009
Any poly-urethane bushing will squeak if it is not lubricated properly. I would recommend going back and lubing all bushing sleeves and the bushing faces that make contact, doing that should take care of your issue. Also you will notice the cold weather will bring out the squeaks more often.
#13 |
Maybe the shop never greased the bushings
#14 |
| BMR Rear Trailing Arms, Tie Rods, Bushings, and More! | FREE Shipping!! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 19 | 11-13-2010 03:55 PM |
| BMR Launches New Product - 2010 Camaro Trailing Arms w/Spherical Bearings (TCA027) | BMR Suspension | Suspension / Brakes / Chassis | 4 | 05-28-2010 10:42 AM |
| Installed BMR toe bars, trailing arms and bushings this weekend... | IROCanSS | Suspension / Brakes / Chassis | 26 | 04-07-2010 04:00 PM |
| BMR Fabrication Launches New Product - 2010 Camaro Trailing Arms (TCA026) | BMR Suspension | Suspension / Chassis / Brakes | 89 | 03-05-2010 08:02 AM |
