Luke 14:23
Drives: 2016 Camaro Convertible 2SS Join Date: Jan 2010
Both Cigarette Lighter Outlets Quit Working
Both of my cigarette lighter outlets quit working...the one in front of the gear shifter and the other in the center compartment between the front seats. I use to have a radar detector plugged into one of them and a 12V DVD player in the other one and both outlets worked fine for several months and then just suddenly quit working. My radar detector and DVD player both still work fine in other sources. I've triple checked all the fuses, both under the hood in the fuse box and on the side of the dash and all fuses are good. Does anyone have any ideas as to why both of these outlets quit working? I'm completely bum fuzzled! Thanks in advance for your input.
DRIVE IT LIKE YOU STOLE IT!
![]() Drives: 2010 Camaro 2LT/RS Join Date: Sep 2010
If memory serves me, they run off a single 10amp fuse on the driver side dash. If the fuse is good, sounds like a dealer warranty issue. Who knows - maybe a bad wire. Best to have the dealer chase down electrical issues.
Luke 14:23
Thanks for the info gill. I'll check the fuse again. If it's okay I'll take 'er to the stealership.
Luke 14:23
I checked all the fuses and none of them are blowed. Very puzzling!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LT/RS M6 Join Date: Nov 2007
Actually they run on two separate fuses... here is my thread about it with pics...
http://www.camaro5.com/forums/showthread.php?t=64202 Doesn't make sense that they'd both blow at the same time though...
Trifecta tune, Vararam Intake, VMAX throttle body and manifold insulator, RxPerformance Catch Can, , MRT v1.0 and Louvers, Barton shifter, BMR strut tower brace, RED dome light and Plasma LED DRL's, fieldgoal00's Halo 1 harness, hood spears/side stripes, rain guards, custom bowtie, Team LLT badges, headlight and foglight covers, taillight and side marker covers, backup light covers, WeatherTech floormats
#6 |
Luke 14:23
I checked my fuses again and found they were both blowed. When I checked them the first time I thought they were okay but I guess the light wasn't bright enough for me to actually see the fuses very well. I replaced the fuses and all is well.
#7 |
Yay! You fixed them!
#8 |
Banned
Drives: 2011 Chevy Camaro Join Date: Sep 2010
A sureties and way quicker and easier way to check fuses is with a test light. That's why those little metal things are exposed on the backside of the fuses
#9 |
i did not read all posts. but i do not know where all the fuses are but thought i would ask. are you sure they are cigarette lighter plugs? cause i know in my tc one is and the other is a accessory.
so i am thinking they are both accessory and maybe the fuses for those are under the hood. Again did not read all post and also have no clue about any or all of the fuses since i have not had my car for just about a year and a half. |
#10 |
Luke 14:23
Check out sterlingnotes thread on this, it helped me a lot. tp://www.camaro5.com/forums/showthread.php?t=64202
| Tags |
| 12v outlets, cigarette lighter, lighter outlets |
| My accessory outlet (cigarette lighter) stopped working... | Sterling | Camaro DIY & HOW-TO instructions & discussions | 14 | 10-14-2019 01:34 AM |
| My AC has quit working | Angrybird 12 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 13 | 06-25-2010 08:40 AM |
| Gauges quit working | rlhjr34 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 06-16-2010 04:10 PM |
| Bluetooth Streaming Audio Quit Working | King_Rob | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 5 | 09-21-2009 06:07 PM |
| Temperature Gauge quit working today | TopFuelTim | 4th Generation Camaros | 1 | 04-13-2009 05:27 PM |
