Old 01-02-2011, 02:50 PM   #1
RnRKimaro
Hell's Belle
RnRKimaro's Avatar
Drives: 2010 Camaro 2LT/RS, 04 C5 Corvette
Unhappy help w/ spotting on all windows
Before I bring my camaro to the dealer I wanted to ask if anyone has any advice for getting a zillion tiny water looking type spots off all of my windows. I tried a few things to remove it and nothing is helping. It actually looks like it is inside the glass itself. Makes night driving very difficult. I appreciate any advice in removing and I hope it's not in the glass itself!
Thanks,
~K~
RnRKimaro is offline   Reply With Quote
Old 01-02-2011, 02:58 PM   #2
midnighter
Drives: nothing
If the spotting is indeed on the outer surface, I have removed spots by spraying the glass with glass cleaner or dish soap water. You need to keep the surface of the glass wet with either of these cleaners and use #0000 steel wool to rub the glass as this takes off anything stuck to the glass without scratching it. Do not rub the car's paint, rubber trims along the windows, nor any mirrors with the steel wool for it will scratch them. Only use the steel wool on the outside of your windows. This works good on chrome plated steel bumpers and chrome plated steel wheels. Don't use on chrome plated aluminum wheels, they scratch.
Old 01-02-2011, 05:50 PM   #3
Russell James
Russell James's Avatar
Sometimes water spots on glass that won't wash off can be from acid rain. A clay bar and the clay lube can do a good job of removing it if it is acid rain spotting.
I lived in New Jersey for a couple years a while ago and remember fixing several cars using a clay bar with bad acid rain etching on the glass.
Old 01-03-2011, 09:16 AM   #4
DangerZL1
Drives: 2023 Black ZL1 Auto
You can also use a glass polish to remove the spots and any surface contaminants. I would shy away from 0000 steel wool and use polish instead. The polish I use reminds me of Brasso and it is probably simlilar. I've found that a variety of different waxes used on the top of the car can wash down and get on the car glass, especially the front and rear windows, causing spotting and wiper chatter. The polish eliminates the problem with a little effort.
DangerZL1 is offline   Reply With Quote
Old 01-03-2011, 05:30 PM   #5
KKJ
KKJ's Avatar
Drives: 2011 Camaro 2SS/RS
Try vinegar
KKJ is offline   Reply With Quote
Old 01-04-2011, 06:09 PM   #6
RnRKimaro
Hell's Belle
RnRKimaro's Avatar
Thanks everyone!!!
Old 01-08-2011, 08:17 AM   #7
2011ss/rs
2011ss/rs's Avatar
Drives: 11 ss/rs RJT w/Black Cherry stripes
Thanks,
~K~
I am having the same isues on my cars also I tried the vinegar and it did work on some but not all and I am still searching for the cure myself.
Good luck
2011ss/rs is offline   Reply With Quote
Old 01-08-2011, 08:21 AM   #8
SSLarry
Drives: 2SS LS3
Good luck
If its on the glass, then its on the paint. If not removed within an hour of the rainfall ( or sprinkler spray, or whatever caused it), it will begin to etch the finish. A good coat of wax will help resist.
2010 CGM 2SS LS3, born: 4/10
SSLarry is offline   Reply With Quote
Old 01-08-2011, 08:28 AM   #9
GATORJAK
GATORJAK's Avatar
Drives: 2010 Camaro 2SS/RS
CLAY BAR!
GATORJAK is offline   Reply With Quote
Old 01-08-2011, 08:32 AM   #10
rydahog
rydahog's Avatar
Drives: camaro ss
bon ami...and a semi soft brush..lots or water flowing
rydahog is offline   Reply With Quote
Old 01-08-2011, 03:39 PM   #11
Icefsh
Icefsh's Avatar
Drives: CGM 2LT/RS M6
Wifes sunroof always had water spots. Used all types of glass cleaner but on luck. Detailed her suv and used clay bar on it and I was surprised by no more water spots.
Icefsh is offline   Reply With Quote
Old 01-08-2011, 03:47 PM   #12
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
vinegar works well. Hope it works out. Keep us posted
CAMARO
Old 01-08-2011, 03:52 PM   #13
se7en
Drives: 10 Procharged SS
Originally Posted by KKJ View Post
Try vinegar
se7en is offline   Reply With Quote
Old 01-09-2011, 08:02 AM   #14
2011ss/rs
2011ss/rs's Avatar
Thanks I will give it a try
spots, windows
Alarm Question - My Windows got shot :( Rainbowfly Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 03-19-2016 06:29 PM
Leaking Windows INTIMIDAT3R Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-19-2010 11:58 AM
Barton Shifter Vibration Disappears w/ windows down autobotaz V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 09-02-2010 03:03 PM
Windows Phone 7 Series UCF w00t Off-topic Discussions 4 02-15-2010 07:15 PM
Express up windows scrming Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 15 08-13-2009 11:01 AM
