Old 01-10-2011, 12:08 AM   #1
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Battery leak question
Sorry if this has been addressed or is a repost, but I have a question/concern with the battery in the trunk of my Camaro.
My previous "toy" was a street machine I built and kept for 16 years. One spring, I went to get the car out of the corner only to discover that the top of the battery was covered with the familiar residue of a slight leak that had developed. Sadly, it has cause hundreds, if not thousands of dollars damage under the hood of the car. The acid in the confines of the underhood air corroded everything that did not have a very stout finish. It wrecked the carb, spark plugs, relays, brake lines, etc. Everything cad plated was destroyed.:( Needless to say, it was the final year I stored it with the battery in.
So now I buy the car of my dreams and it has the battery in the trunk. Is anyone else concerned or have experience with finding their stock battery doing this inside the trunk pan? I have fixed old muscle cars and cringe at the thought of looking in the trunk in a few years to find out the rust demon was locked up in there festering away for years. Once it starts I know it never sleeps.
Has anyone else checked theirs? How much of a pain is the battery to get at? Would the concern be abolished with an Optima?
Any help is greatly appreciated.
chef-beavis is offline   Reply With Quote
Old 01-10-2011, 12:39 AM   #2
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
These are sealed.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 01-10-2011, 09:19 AM   #3
chef-beavis
Aren't they all?
Are you saying there's nothing on the top like caps? They completely sealed? I thought they all had to be able to vent. I'm certainly no expert, though, or I wouldn't have asked.
I guess I'll have to go exploring in my trunk this spring.
Thanks.
Old 01-10-2011, 11:17 AM   #4
pennor
pennor's Avatar
Drives: 2011 2LT - 73 Corvette 454
Yea, I've had concerns about this.
Yes, the factory battery is a sealed unit. I haven't shopped for a replacement battery and it will probably be 5 years before any of us really need to replace one. When I had to find a replacement for the battery in my Chevy Colorado I shopped every battery dealer in town to find one that would fit. Chevrolet seems to love to ignore standard size batteries in favor of odd ones that nobody carries. I ended up setteling for a non-sealed one because even the dealer didn't have the "stock" delco battery for a replacement.
Will this be an issue as our Camaro's age? I suspect it will. We'll end up with some after market battery that may or may not be sealed, and from then on I can see proglems developing with corrosion in the trunk floor pan.
pennor is offline   Reply With Quote
Old 01-10-2011, 11:38 AM   #5
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
The battery is a special battery designed for mounting in the trunk, They are used in some other brands of cars as well. They are not sealed they have a vent hose that runs out of the trunk under the car. They are very easy to get to, just like gaining access to a spare. They have the trunk pad and then the hard spare cover with a large nut to spin off. Mine is an SS so I'm not sure about the other models when you order a spare.
Replacement AC Delco batteries are around $200.
MMC is offline   Reply With Quote
Old 01-10-2011, 11:47 AM   #6
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Battery in the trunk, you can see the vent tube.
Old 01-10-2011, 04:38 PM   #7
chef-beavis
CRAP
That is what I feared. Those caps on the top are what "weeped" on my street machine. I guess I'll have to look once in awhile.
Would a gel battery eliminate the problem?
Old 01-10-2011, 08:17 PM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
They sell a pad that you can put under the battery that will absorb any acid leaks. Maybe put one of those under the battery if it helps you sleep at night. I have one on my '69 because it happened to me once. Cheap insurance.
-Mark.
Old 01-11-2011, 07:15 AM   #9
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Its pretty rare for a modern battery to start leaking. You'd probably have to have a overvoltage problem in your charging system that 'cooks' the electrolyte. I'd just inspect it occasionally and otherwise not worry about it.
Old 01-11-2011, 07:24 AM   #10
Camaro68
Camaro68's Avatar
-Mark.
You sir are right about that, had to do the same with my 68.
Old 01-11-2011, 07:43 AM   #11
chef-beavis
I'll check it when I get the car out
AND when I put it away each year, I guess. The pad would help but in the case of my Cutlass it was the acid air/environment created underhood that did the deed, not any actual contact with the acid.
Thanks for all the replies!
Old 01-11-2011, 10:24 PM   #12
Texhawk
Texhawk's Avatar
Drives: 69Camaro,87IROC,96 SS,Z06&Stingray
I would be concerned if GM was still using side terminal batteries with the terminal below the acid level, but I have not had any problems with top post batteries leaking.
Texhawk is offline   Reply With Quote
Old 11-18-2019, 05:35 PM   #13
RedRaven
RedRaven's Avatar
Drives: 2012 2SS M6 CRT
Trunk battery corrosion
My trunk at 7 1/2 years, 127800mi. Orig battery. Checking because it's been weak this week in the AM in the 40s (Florida). Topped off cell 1 &2 with distilled water. Still need to do my rear brakes in a couple of weeks, so when I do, I'll remove the battery and wet clean/neutralize, & see what I can do about the small rust bubbles.
2012 2SS M6 CRT
SOLD! - - 1983 Berlinetta, 305HO, Comp 235 cam, shorties
First real car: 1968 Malibu, '67 283, Canary yellow
RedRaven is offline   Reply With Quote
Old 11-19-2019, 10:29 AM   #14
G8One2
Drives: 2014 Camaro 2SS
It should have an agm battery that's sealed.
G8One2 is offline   Reply With Quote
BURNING QUESTION ABOUT INDEXING WINDOWS Matrix 5th Gen Camaro SS LS LT General Discussions 28 01-29-2011 01:27 PM
Schumacher SE-1-12S Automatic Battery Charger / Maintainer Installation PAUL SS Camaro DIY & HOW-TO instructions & discussions 3 11-28-2010 01:53 PM
Noob Needs Help with Battery Questions tjmac49 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 01-10-2010 04:10 PM
Battery question armando416 5th Gen Camaro SS LS LT General Discussions 2 01-02-2010 08:06 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
