![]() ![]() ![]() ![]() ![]() Drives: '10 Camaro 2SS/RS & Magnum R/T Join Date: Oct 2008
Forgive me if this has been covered but I cant find it anywhere in the searches Ive done.
My question is this! If you disconnected the battery, and everything is locked up how are you going to get inside with the key, cos the I'm thinking, without the battery the windows wont index down and allow you to enter the car. Or will it?? How are you going to open the trunk if there is no battery/ how do you get inside to fold the chairs to get at the battery if the windows wont index in the first place? Am I missing something here?
SIM Camaro 2010 V8-2SS/RS-A6!!+
![]() Drives: Old Join Date: Sep 2008
Should open and close, you just won't have the best seal without the indexing.
2G1FB1EV7A9100028
Drives: 2010 Jeep Wrangler Hemi Join Date: Mar 2009
Even if the windows don't crack the doors will still open, and you can get to the trunk through the rear seats and just pull the lever to release the trunk.
# 28 - Victory Red 1LT/RS (SOLD)
Wont you risk breaking the window if it doesnt drop down as you open the door?
![]() Drives: 2016 2SS Camaro Join Date: Oct 2009
why would it? I open my door with the window up all the time.
#6 |
![]() Drives: 2010 IOM SS/RS Join Date: Dec 2008
Without the indexing, it does open, but it's a very snug fit. I would be carefull opening and closing it if the indexing is turned off or not working.
#7 |
![]() ![]() ![]() ![]() Drives: 1SSRS RY L99 Join Date: Aug 2009
Great question! I think the upper edge would just slide over the seal, and like the other posts sad be a little stiff.
#8 |
Orange GM freak
At the end of the winter; you could open the trunk with the key. After you hook up the battery everything should work as normal.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
#10 |
#11 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
You open the door with the key pull the hood lever and put jumper cables on the posts under the hood used to jump off the car, and then use the remote to pop the trunk..
The window indexing is to keep from wearing out the window seals from repeated opening and closing of the door against the very close tolerance of the window seal..It won't hurt to ocassionally open it up without indexing the window...
The Bird is the word! Last edited by Angrybird 12; 12-12-2009 at 01:13 PM. |
#12 |
![]() ![]() ![]() Drives: BLACK 2SS/RS Join Date: Sep 2009
I agree with Skyman 08.....you are not going to hurt the window but could cause premature wear to the seals if done repeatably for extended periods.
#13 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Opening without indexing is not a problem. To close the door, push the top edge of glass, it should bend just a littel bit, that will allow it to tuck under the molding. And even if you don't do that, it should still close, but the glass could (not likely but could) catch the molding if you close it in the full up position.
Before indexing glass, we used to depend on the glass standing up under the seal when closed and relaxing (bending in toward the car when opened). This would still allow the glass to tuck up under the molding, but indexing glass improves on this a great deal. I think your owners manual may even detail this for you. This does not hurt the car at all. Trust me, I used to do door systems for GM.
#14 |
OK thanks guys. I really thought you could damage the window by pulling it without it down. This clears it up nicely!
| indexing time question | honeybucket99 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 6 | 12-01-2009 10:26 AM |
| Express up windows | scrming | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 15 | 08-13-2009 12:01 PM |
| window indexing for tinting | cm5217 | Cosmetics and Lighting Modification Discussions | 34 | 06-01-2009 07:38 PM |
| Windows dipped? | TheCaptain | Cosmetics and Lighting Modification Discussions | 37 | 03-04-2009 10:21 AM |
| Rear Quarter Window Question: Will it Roll Down? | Mungo | 5th Gen Camaro SS LS LT General Discussions | 63 | 08-28-2007 02:53 AM |
