Old 01-10-2011, 02:16 PM   #1
bnsmith78
Drives: 2011 IOM SS Corsa/CAI
Want to add Headers/Tubes - Re-Tune?
I have a CAI, Corsa Exhaust and Street tune (2011 SS ). I guess it's time to add the headers. What will I gain etc? Sound? Difference between long and short? Do I need a re-tune? Who installs? Thanks....
bnsmith78 is offline   Reply With Quote
Old 01-10-2011, 02:21 PM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
its going to be a big difference in sound and power. you need a re-tune to get the best results. my local shop did a re-tune on my car for 200
Old 01-10-2011, 02:29 PM   #3
bnsmith78
What is the difference between long and short? How much will it cost? Thanks man...
Old 01-10-2011, 02:41 PM   #4
bnsmith78
After reading here, I think I would do the long tubes. But what about flow-cats? I guess you would do both? How much? Will it match up with my Corsa exhaust?
Old 01-10-2011, 02:52 PM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
There are so many threads on this subject. Use the search button and you'll find more than you want.
Build Journal
Old 01-10-2011, 02:59 PM   #6
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Def go with long tubes. I have the fm cat back with SW Headers and at the time I had a k/n cai.. With a good tune. I had made 410 rwhp.
kevin1106 is offline   Reply With Quote
Old 01-10-2011, 03:27 PM   #7
bnsmith78
How much? do headers and tubes come together? What about flow cats? thank you!
Old 01-10-2011, 05:51 PM   #8
2010SSRSM6
2010SSRSM6's Avatar
I have BBK LT's, High flow cat's CAI on my car. Before it was tuned it was 412/412 up from 378/378 on the same dyno on the same day.
It's getting tuned tomorrow, but I won't have access to the BBK dyno for a while to see how it works after the tune.
You can do the install yourself in about 2 hours. I'm not sure about other brands, but the BBK LT's come with high flow cats. Depending on what size headers your wanting to go with (1 3/4", 1 7/8", 2", etc.) there are a ton of different brands to go with.
There is a HUGE sound difference switching out the headers to LT's. Keep that in mind before you go that way. If you don't want loud, don't go LT. Keep the factory exhaust manifold and just add either a cat back system and high flow cat's or an axle back system for a more agressive tone.
Just my .02
Good luck with your choice.
Old 01-11-2011, 01:41 AM   #9
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
I was in same situation a few months ago and went the Stainless Works LT route. Got it groupbuy with highflow cats. LTs and High flow cats bolted right up to my Solo Mach XL exhaust. Its not loud at all when cruising, but sounds like a muscle car. Open her up and WOW!!!!!!!!!! I have a few vids of sound from in cabin and behind car. I have a vid of cruising in cabin with radio on pretty low and you can barely hear the headers just to give you an ideas of exhaust volume.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 01-11-2011, 01:49 AM   #10
Ivan @ Southwest Speed
Let us know if we can help you out!
We have several options and feature Ceramic Coated Doug Thorleys for under $650 shipped.
Too much hp/$ in those units and ready to ship today.
Best of luck in your quest!
Old 01-17-2011, 06:09 PM   #11
kevin1106
kevin1106's Avatar
Yes they come together. I believe i paid about 2,000 for everything. Did the install myself... I didn't use cats, but I did buy them. I went with the off road pipes. It's your choice on cats, you can use the stock ones or go with hi flow ones. I got the hi flow. But I'm only putting them on the car when I have to pass emissions.
DO NOT give specific order/vin info on the site if getting a tune! TAG UR IT Tuning / Diagnostics -- engine and transmission 60 07-14-2011 02:47 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
HP Tune question Darth_Emma Tuning / Diagnostics -- engine and transmission 40 06-15-2010 10:42 AM
Undetectable Tunes - What You Should Know kelley@vectormotorsports V8 Bolt-Ons & Tunes 159 09-18-2009 03:18 PM
