![]() Drives: 2011 Black 2SS/RS Join Date: Aug 2010
22 inch rims and tires
I currently have a set of 22 inch rims and the following tires:
Front 255/30/R22/ and Rear 305/25/R22. I am new to this whole thing and had no idea the 22 inch rims and tire combo would leave me with such thin sidewalls. Is there anyway to get bigger tires with a thicker sidewall |
Tattooed K9
Drives: E63AMG Join Date: Jan 2011
How thin is the sidewall by chance? I am curious. Is it less than an inch of rubber there between the rim and the road?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 F150 RCSB Abyss FX4 Join Date: Aug 2009
I'm new to this stuff too.
Going by Nine Ball's chart, you could have gotten a little more sidewall with a 35 series up front and 30 in the rear. http://www.camaro5.com/forums/showthread.php?t=62838 |
^^Bingo. That chart is very useful.
[B]
Tattooed K9
Agree...I am taking it to heart for my upcoming wheel purchase.
#6 |
Go Harder Than Baltimore!
Drives: 2010 CGM Join Date: Jun 2010
I don't understand the whole tire size things at all, for front or rear, idk what any of the numbers mean. ugh
#7 | |
P275/40R20... The first number is the width of the tire in millimeters. The second number (40) is the height of the sidewall as a percentage of the tire's width, called the aspect ratio. So a 275mm wide tire with a sidewall aspect ratio of 40, would have a sidewall of 275*0.4=110mm. The last number is just the diameter of wheels you have, in inches, which is 20inches in this case. It's a little confusing at first, but once you get the hang of it, it's not so bad. Oh and don't worry too much about the P and R. The P just means passenger tire, the R just means radial construction. Nothing to do with size.
[B]
#8 | |
Troy
Well said!
![]() Quote:
#9 |
If it makes you feel any better, they look good.
Edelbrock E-Force
Stainless Works Lts Roto Fab CAI Magnaflow Street Cat-Back DOD Delete Forgestar F-14's and Pedders XA + PKG Custom grind cam from Cincy Speed ADM dual fuel pump ADM AF/Boost gauges FTI 3200 convertor Hurst shifter Cincy Speed Build and Tune 540rwhp |
#10 | |
| For sale: brand new 17 inch jeep wrangler rims and tires | acamaro | Wheels / Tires | 0 | 08-29-2010 03:33 PM |
| 20 inch rims and tires | ragincajun24 | Wheels / Tires | 3 | 08-12-2010 12:13 AM |
| Fs 20" inch polished ss rims with or without tires | Paul4137 | Wheels / Tires | 5 | 02-16-2010 07:08 AM |
| 18 inch ls/lt rims and tires | colorado pony | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 01-17-2010 06:09 PM |
