Old 01-15-2011, 11:52 AM   #1
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
slight noise after spring and sways installed
I have had my Pfadt Spings and Sway for about 2 weeks (400 miles) and I am very happy. Over the past week the temps have been very cold and I have noticed a slight noise when going over speed bumps and steep inclines. No noise under normal driving. Me thinks it could be the endlinks or sway bar bushing. The noise sounds like a screech or expansion. Anyone experience this? The noise was not present right after the install which leads me to think it might be an endlink or swaybar bushing.
Snake Slayer is offline   Reply With Quote
Old 01-16-2011, 04:58 PM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
From some of the other Threads that I read on this subject, I would check all nuts and bolts for proper torque. Also, check the grease fittings (if any) on the new sway bars that installed to make sure they were greased.
Old 01-16-2011, 05:58 PM   #3
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I have the same noise , not able to track it down yet but I think mine is also the front sway bar/bushings. I have BMR stuff.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 01-16-2011, 06:26 PM   #4
Rob@WretchedMS
Drives: His Wife Crazy
i would go through and check all the end link bolts, i'm sure pfadt will tll you the same thing tomorrow or tuesday when they get back to the forums
Also, check the springs, i've never installed a pfadt spring, but we've seen some eibachs with fitment issues that caused noises and needed to be moved to get the noise to stop.
Rob@WretchedMS is offline   Reply With Quote
Old 01-18-2011, 08:17 AM   #5
Snake Slayer
I am leaning toward an endlink issue as the noise only started recently and is only present when going over speed bumps.
Old 01-18-2011, 09:02 AM   #6
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
The one thing I noticed about your problem is that it is louder as the weather gets colder.If you did not time the bushings after the car was lowered this could also be another place to look, if all of the bolts and sway bar bushing/ links look good.
Bruce@raymondsperformance is offline   Reply With Quote
Old 01-27-2011, 10:33 PM   #7
Robbie1227
Drives: 2015 Camaro Z28/2016 Jeep Sahara
I had the exact same problem, speed bumps, inclines, driveways...
Its the end links.
Robbie1227 is offline   Reply With Quote
Old 07-02-2011, 04:18 AM   #8
FijiKid
FijiKid's Avatar
Drives: Cyber Grey Camaro SS
I think i have same issue. Please pm me andblet me know howvu resolved. Thank you.
Borla "S"type Cat Back / Hotchkis TVA2 Suspension Kit / Rotofab Intake / Tinted Windows / Headlight Armor Tailight Smoke / P13 DRLs w Harness / De-badged / Satin Black Power Coated Stock Wheels / Gloss Black Calipers / EPCO Custom Knob.
FijiKid is offline   Reply With Quote
Old 07-02-2011, 04:02 PM   #9
DHSS
DHSS's Avatar
Drives: Empty
I would like to be emailed about the fix for this issue as well. My installer has looked at my car twice and we cant find it and the sound is getting louder.
Thanks,
DH
DHSS is offline   Reply With Quote
Old 07-02-2011, 06:59 PM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Thanks,
DH
The big things to check are:
1) everything is torqued to spec
2) bushings are properly greased
Old 07-06-2011, 10:01 AM   #11
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Exactly. 99% of noise issues concerning sway bar installations is either from the end links loosening up or not enough grease on the sway bar.
BMR guy is offline   Reply With Quote
Old 07-06-2011, 11:19 AM   #12
JusticePete
Drives: Camaro Justice
i would go through and check all the end link bolts.
Time your bushes.
Double check all the nuts and bolts.
Grease the d-bushes.
Test drive for quiet ride
Old 07-06-2011, 12:52 PM   #13
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Well I hope the original poster has his issue resolved! As touched on previously in the thread, most noise issues coming from sway bars can usually be fixed with proper lubrication of the sway bar bushings and verifying that the sway bar brackets are properly torqued.
More likely noise issues arise from the endlinks than from the bars themselves. Make sure that the endlinks are properly torqued at the sway bar and control arm in the rear, and at the sway bar and strut housing in the front. If you're running OEM endlinks ensure that they are not bent and are still in good shape.
Old 07-06-2011, 01:12 PM   #14
Snake Slayer
Just an update I have 10K miles plus on this setup and I have no noise. Upon the suggestion from Pfadt I re torqued all of my end links and the noises went away.
Awaiting 2014 C7
Pfadt solid subframe mounts, diff bushings, sways and trailing arms installed! AdamCzap Suspension / Brakes / Chassis 14 01-04-2011 06:54 PM
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! Kris@BMCPerformance Suspension / Chassis / Brakes 20 01-15-2010 10:09 PM
Discussion of suspension tuning methodologies Tankrust Wheels and Tires Talk Sponsored by The Tire Rack 10 08-04-2009 07:39 PM
