Old 01-17-2011, 03:42 AM   #1
ducq
ducq's Avatar
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM
Interior some light LED Failed :(
Interior *DOME* light LED failed
I recently bought 4 3-chip LED lamps. 2 for the license plate, 1 for the trunk and 1 for the interior light. Two days later it doesn't work. I had to swap it with the trunk light and put a stock one back into the trunk. I have the interior light set to the middle where the light turns on when the doors open and turn off when they close. Did this cause the failur? The bulb kinda has a burnt smell but I can't see anything on the outside. Did this lamp fail 1 out of a batch or will they continue to fail if I keep it set this way?
TSP 229/236 cam .Magnaflow Comp axleback .KOOKS LT w/ high flow cats .magnapack bullets. C.A.I. Vmax ported TB. Dyno tuned 452hp / 422tq.
ducq is offline   Reply With Quote
Old 01-17-2011, 04:43 AM   #2
mcotton
mcotton's Avatar
Drives: 2010 Camaro
ducq,
I bought my LED's about 5 months ago and have my interior light set to the middle where the light turns on when the doors open and turn off when they close as well, and I have had no problems. I also have the LED in the trunk and it has not caused me any issues. Looks like you may have gotten a bad light. I love my LED's and get many compliments as the blue glow looks awesome at night :-)
Mike
mcotton is offline   Reply With Quote
Old 01-17-2011, 04:49 AM   #3
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
I've had mine since the Fest last April... same setting, no problem.
Sterling is offline   Reply With Quote
Old 01-17-2011, 08:32 AM   #4
ducq
ducq's Avatar
Good to know, thanks. I'll have to send it back to aac.
Old 01-17-2011, 11:26 AM   #5
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
Definitely do send it back to AAC..thats odd
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
DIY - ABL using EL wire, and 3/16" tube camarorick Camaro DIY & HOW-TO instructions & discussions 502 02-25-2014 01:29 PM
Glove box light jbsrace1 Camaro DIY & HOW-TO instructions & discussions 66 06-03-2013 02:40 PM
Group Buy!!! LED Headlight and Tail Light HALOS, Only $99 Each!!! Wes@Flashtech Exterior Parts & Accessories 51 09-27-2010 08:19 PM
Light Wurkz Led After burner Taillights wishucould00 Cosmetics and Lighting Modification Discussions 18 03-19-2010 05:57 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 01:49 PM
