Old 01-17-2011, 03:25 PM   #1
G.E.
G.E.'s Avatar
Drives: black on black twenty ten ss/rs
Subwoofer keeps blowing for unknown reason...
I've had a subwoofer installed in my trunk. I blew a type r in 2 weeks and a P2 in 2 hours. My audio guy has checked everything. He's installed many systems over the years and the only thing he can guess is that my stock boston acoustics system is sending the wrong signals (highs and lows and all that) and it's confusing the woofer to where it doesn't know what to do. Anyone else have this problem?
I GOT MINE! Where's yours? :(
G.E. is offline   Reply With Quote
Old 01-17-2011, 04:36 PM   #2
Shredder
Shredder's Avatar
Drives: 2011 RJT 2LT
Send a message via AIM to Shredder
That's not possible to blow it "because it doesn't know what to do". The crossover sends only low frequencies to the sub and sub amp. You are probably over driving the amp, and that distortion is cooking your subs. What amp is driving this sub?
Shredder
Shredder is offline   Reply With Quote
Old 01-17-2011, 07:21 PM   #3
Eric Baker
Drives: Black/Black 2SS/RS 6M
Yeah it's not the signal the amp is getting, something's not set right or the enclosure isn't built correctly.
I have 2 Type-R's and Ive beat the hell out of them overpowering them and all, and they still work flawlessly after ~7 years.
Eric Baker is offline   Reply With Quote
Old 01-17-2011, 07:25 PM   #4
mrray13
Drives: 2010 1LT RS Rally Yellow
What amp? Are the subs and amp impedance matched? My guess, gain/boost are both too high, you are overdriving the sub and popping it.
mrray13 is offline   Reply With Quote
Old 01-18-2011, 01:19 AM   #5
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
you are blowing subs... its been a long while since I blew up any subs, but exceptionally distorted signal, WAY too much power, no subsonic filter set, exceeding mechanical limits of the sub (too much power/vented enclosure), hmm... subs are shockingly forgiving when it comes to too much/too little power as well as dirty/clipped signal.
What are the chances that your amp its self has a fault and your throwing straight DC current into your VC's whenever the amp shorts?
Ordered - 4/17/2010
Delivered - 5/29/2010
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Topdown is offline   Reply With Quote
Old 01-18-2011, 01:25 AM   #6
shevyman
Drives: 2010 Camaro SS IOM
you know i am with many on this. but i think you have the wrong settings. your gain is to high and maybe the impedance is not matched.
only reason i say that is cause back in the day i blew out two fosgate 15' subs within an hour. my amp had plenty power i was new to the whole thing and i would always turn up the gain and not set my fregrency. so check that stuff out.
if those are down and set right then i would say you have a bad amp
shevyman is offline   Reply With Quote
Old 01-18-2011, 08:15 PM   #7
G.E.
G.E.'s Avatar
i have an Alpine M500 amp. i blew a 12" alpine type r in 2 weeks and then just recently i blew a rockford fosgate P2 in 2 hours.
Old 01-19-2011, 02:46 PM   #8
shevyman
well again that amp is fine for both those subs. what you need to check is what ohms you have the sub at and what ohms the amp is. if they are not matched that could cause damage.
now another thing like posted earlier is if you have your gain up to high or the frequency is not set right you could be distorting the subs and that is causing the subs coil to fry. so i would check all that. or if possible post up here the settings on the amp.
just checked the features on the amp, its 2-4 ohm stable so as long as you run the sub at 2-4 ohm you should be fine. only difference is 2 ohm is more power then 4. so post here your settings and what kind of box you have and i might be able to help you.
Old 01-19-2011, 03:50 PM   #9
Eric Baker
Also if the subs are dual voice coil, if they are wired wrong, they could fry the coils as they would be working against each other.
Old 01-19-2011, 04:54 PM   #10
G.E.
G.E.'s Avatar
both are the 4 ohm version of the speaker and i had them paralleled wire to run at 2 ohms off the amp. i'm not sure what the amp was set at but i know it was rather low because from my understanding, the subs need a break in period before you really bump them.
the box is a custom built box.
also i'm not sure the coils are the problem, as in i dont think they are frying.
what's happening is (i guess the cone?) is coming unglued. but i could be wrong on all that.
Old 01-19-2011, 05:03 PM   #11
NVMYSS
NVMYSS's Avatar
You can also blow the sub if you cause the amplifier to clip
NVMYSS is offline   Reply With Quote
Old 01-19-2011, 05:04 PM   #12
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
This is what I would think as well.Try taking an O'scope measurement from the output,or a DC multimeter measurement.
1100 - 10/22/2008
3000 - 05/27/2009
3300 - 06/06/2009
3800 - 06/29/2009
4B00 - 06/29/2009
Warehouse 13 survivor
Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my
mind.
Nexus6 is offline   Reply With Quote
Old 01-19-2011, 08:27 PM   #13
Eric Baker
If they are separating/coming unglued, that's a first I've ever heard of that happening, and I've installed 100's of subs in my 10+ years in the business. Only time I've ever seen a surround separate was a really old sub where the glue dried out, or a defect in manufacturing, and all combined I've only seen a handfull.
Old 01-19-2011, 11:04 PM   #14
shevyman
the amp will only run at a 2 or 4 ohm depending on how you wire the subs. if you ran them at a 2 ohm then the amp will run 2 ohms.
now i am confused as to what you are saying. the center cone is separating? we will need some pics. also is there any way you can describe what your sub is doing that you are saying it is blown
rear differential blowing up MARINE1991 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 05-14-2012 12:47 PM
Cheap solution for Subwoofer Enclosure icetre Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 03-01-2011 08:12 AM
Another reason wikipedia is not a good source Apex Paul Off-topic Discussions 6 12-28-2010 10:05 AM
Audio Upgrade Subwoofer VJCamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 17 08-14-2009 09:09 AM
Besides price/cost, Is there a good reason not to get a V8? ZombieEatsYou 5th Gen Camaro SS LS LT General Discussions 83 03-10-2009 05:42 PM
