Old 01-22-2011, 12:45 AM   #1
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS "Fury"
Brake Dust on Rims..
Had a question for you guys. I have black painted rims, and the brake dust latches onto it pretty thick, giving wheels a dirty, dull finish. Every weekened when I was the car, I have to wash the rims.
This isnt such a big deal, but the brake dust just ruins my mf towels, and I'm using up my rags. I have tried spray on rim cleaner, but to be honest, I dont like the idea of spraying those nasty chemicals on my rims, cause I dont want the cleaner to damage them.
My question, has anyone ever tried say.. baby wipes on their rims? Pull one out, wipe down rims.. when wipe gets dirty, throw it away, get a new one. Their moist, so it shouldn't scratch the paint, and the dampness, in theory.. seems like it should be a good cleaner for brake dust. When done wiping them down, just spray rim with hose.. then buff clean rim with mf towel without ruining it...
Thats what I have in mind, I'm a little hesitant to go to the store , but the wipes, and just try it.. if for some reason it scratches/mars my rims, it'll be a sad night in my house. So, I was just wondering if anyone else had ever tried this before? Just curious.
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
SSFury is offline   Reply With Quote
Old 01-22-2011, 12:51 AM   #2
midnighter
Drives: nothing
I pre-rinse the wheels, apply car soap with a mitt, rinse, then dry. Wipes always scratch my wheels.
Old 01-22-2011, 03:54 AM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Well...you should be washing the wheels every time you wash the car anyway.. For the wheels I use Adam's All-Purpose cleaner (diluted) or Adam's Green Wheel Cleaner along with a soft boars hair brush. This is the proper way to wash wheels. When I'm washing the car, I first spray down the wheels, tires, and wheel wells, then hit the wheel wells and tires with APC and scrub with this brush, then rinse, then spray Green Wheel Cleaner on the wheels and agitate with this brush.
Either that, or have a separate wash mitt for your wheels and do the wheels last, after you have finished washing the car. What you don't want to do is dip the wheel wash mitt into your bucket before washing the paint.
[B]
Old 01-22-2011, 09:49 AM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
ArmorAll makes a protectant product for this. If you do a search for it you should find a few threads where guys have used it with great results.
Another option, tho a tad more expensive, is to do what I did and change the pads to Hawk Ceramics! It cuts down on 98% of the dust...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 01-22-2011, 10:05 AM   #5
jtzako
Drives: 2010 IBM Camaro SS
I use the armorall wheel protector spray. Once I wash and completely dry the wheels I spray that on liberally. It keeps stuff from sticking to the wheels and it ends up taking considerably longer for them to get dirty looking.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 01-22-2011, 12:39 PM   #6
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
After you get your wheels clean, wax them. Apply a good quality paste wax to them and the brake dust washes off a lot easier.
FrankT is offline   Reply With Quote
Old 01-22-2011, 02:33 PM   #7
SSFury
SSFury's Avatar
Good tips all. Thanks.
Old 01-22-2011, 02:48 PM   #8
gofast908z
gofast908z's Avatar
Drives: Camaro
If you're wheels are painted and clearcoated (likely), then you are right to worry about chemicals. But don't be afraid of proper ones. Since the wheels are likely cleared, you need to treat them as you would the paint on the car. So they need to be waxed or sealed (sealant is easier here) on a REGULAR basis. So, to avoid stripping the very protection you need to apply, you need a SAFE pH balanced wheel cleaner.
-P21S wheel gel
-Gloss-It wheel gel
-Sonax full effect
Any of these will do the job without damaging the wheels or striping protection from the wax or sealant used to protect the wheels.
Jeff
2008 Z06 - Heads/cam/intake/exhaust/tune
2005 Sierra STL ext cab -5.3L, Daily/Detail Rig
gofast908z is offline   Reply With Quote
Old 01-22-2011, 04:57 PM   #9
garcmol
garcmol's Avatar
Sonax & Daytona speed brush.
Old 01-22-2011, 06:39 PM   #10
Gene Culley
Drives: 2013 SS
Smile
As another mentioned, the Hawk Performance Ceramic pads will clear this up. If you're interested in the Hawk pads, let me know as I would be happy to help.
Gene Culley is offline   Reply With Quote
Old 02-20-2011, 10:12 AM   #11
O44DOG
Drives: 2010 SS
Brake dust is a problem. This is the only vehicle I've had that I don't downshift on a regular basis. I have never had a vehicle with brakes the are as good as the SS, so I like using them.
O44DOG is offline   Reply With Quote
Old 02-20-2011, 07:52 PM   #12
Rafsanjani
What now Bitches?
Rafsanjani's Avatar
Drives: 2013 SW ZL1
I have them specifically for my summer wheels that are painted white. Worth every penny. Then of course you will still need to clean them as recommended above but not nearly as often.
2013 SW ZL1
Rafsanjani is offline   Reply With Quote
Old 02-20-2011, 08:15 PM   #13
ballistic
LS1 to a LS2 to a LS3
ballistic's Avatar
Drives: 2011 Camaro 2SS/RS IBM
You should have a seperate wash mit like previosuly stated for your wheels. I can't imagine not washing them everytime I wash the car. I keep a seperate bucket and mit just for the wheels.
Chemical Guys makes a "Wheel Wax" that I apply every month. It keeps a lot of brake dust and other grime from sticking to the surface. It also makes it easier to clean them. There are other compaines that make similar products.
ballistic is offline   Reply With Quote
Old 02-21-2011, 11:02 AM   #14
eric@thompson
Drives: GMC Sierra
I use Adam's Brilliant Glaze on my wheels. It gives them that extra shine, and keeps the brake dust from sticking.
This thing will save your knuckles!
I'll throw in a FREE 16oz bottle of Adam's Green Wheel Cleaner with each purchase of Adam's Turbo Stick.
Email me:
eric@thompsonracing.us
eric@thompson is offline   Reply With Quote
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
**FREE Brake Pads with Sport Rotor Purchase ** Team STILLEN Suspension / Chassis / Brakes 19 11-08-2011 02:04 PM
Hawk, DBA & Goodridge Brake Upgrade Packages from JSC Speed JSC Speed Suspension / Chassis / Brakes 4 08-05-2010 02:29 PM
Brake Dust? 1940 Willys Coupe Camaro Photos | Spyshots | Video | Media Gallery 7 07-27-2010 09:02 AM
road and brake dust issues Jferrell88 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 8 04-23-2010 12:25 PM
