![]() Drives: 2011 SS CGM Join Date: Jan 2010
outside temp gauge accurate?
This morning on the way to work they said it was twenty one below zero, my gauge reads minus fourteen?
n116
Drives: 2010 2SS YELLOW TRANSFORMER AUTO Join Date: Mar 2010
You poor guys. Here in west Texas we have only seen one day at +18 degree. Gauge right or wrong, too cold to live where you do. Try not to freeze to death.
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 67 Camaro Convertible Join Date: Jun 2009
A difference of 7 deg's can be explained by where "their" thermometer is located. On a hill, in a valley, at an airport, a few miles from your exact location? My house is always off a few degrees then what they say on TV or radio. By the way, I was 8 below 0 at my house this morning.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, SunroofPlaced order at dealer 4/24/09 1100 - 4/28/09 2000 - 5/01/09 2500 - 5/05/09 3000 - 5/05/09 3300 - 5/30/09 3400 - 6/05/09 3800 - 6/18/09 4000 - 6/18/09 4B00 - 6/18/09 4200 - 6/22/09 5000 - 7/01/09 6000 - 7/01/09 It's Home!! 0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less |
![]() Drives: 2010 Camaro 2LT RS Black on Black Join Date: May 2010
That's actually a read-out of your bank account balance after buying a 2SS!
George Carlin had a hilarious bit about the "official" temperature and how the weatherman is always telling us the temperature at the airport -- "the one place in the city where NO ONE LIVES!"
"If at first you don't succeed, conceal all evidence you tried in the first place."
Drives: 2011 IBM Camaro LS Join Date: Aug 2010
Yes, as stated, temperature variances within a city can be quite dramatic. I believe the temp gauge is very accurate. But there are other factors to consider too. Such as direct sunlight. Amount of vehicles around you etc... So take the weatherman and your gauge as a general guide, not absolute truth.
#6 |
![]() Drives: 2010 CGM 2SS/RS Join Date: May 2010
When weather station measure temp. they do it very accurately. The sensor is 15 feet above the ground. Since air is heated from the ground up, it makes sure that it isn't getting false readings by being too close to the ground. It is also in the shade so it is the actual temp and not the heat index temp. All of the temps that you see posted in cars and on bank signs is close but not the real temp.
Mods so far: 20% tint, Solo Mach X Exhaust, Custom Hockey Stick Stripes from MPD1, RevXtreme Catch Can, 6.2L emblems from Emblempros, Stealth turn signal bulbs, Skip Shift Eliminator from Apex-Speed, MPD1 Spoiler, custom painted Sparks SS emblems by MPD, MPD Force 5 hood, custom painted ZL1 bumper by MPD, MPD smooth rear panel, C.A.I. intake to seal with hood, ARH 1 7'8" headers with Hi-flow cats, ceramic brake pads, Factory Reproductions Style 41 black ZL1 wheels, Painted calipers to match stripes, ADM ZL1 scoop, showstopper markers, Norris custom cam, Tuned by Mike Norris 464 HP, 425 TQ.
#7 |
![]() ![]() ![]() Drives: 2010 Black 2SS RS A6 Inferno Join Date: Nov 2009
I dont really trust it. Its probably close
[SIGPIC][/SIGPIC]2010 Camaro Black 2SS/RS A6 Inferno Interior Polished Rims, Sunroof
Born 11/19/09 mods: 20% tints Borla Atak cat-bak Roto-Fab intake amber footwell, dome, and trunk lighting(AAC) Decepticon Gas door Led Taillights (technostalgia) |
#8 |
![]() Drives: IOM 2SS/RS Join Date: Jul 2009
I think it reads a little high. One thing I found out while doing some monitoring with my Diablo Trinity is that the tuner is always 1.5 to 2 degrees cooler than what the cars display reads. Don't know why. I would think that the car is feeding the tuner the same info as what it displays. Doesn't make sense to me but the tuner is closer to ambient air temp.
ADM race intake, Dynatech lt headers w/hi-flo cats, Jannetty Racing dyno tune, VMax CNC ported TB, MGW short throw shifter, Elite Engineering catch can
#9 |
On a side note, my DIC displays the message about icy road conditions when the temp display reads 37 degrees. What temp are you guys getting the message?
#10 |
When the temp display drops to 37 degs. on all our cars, you get the icy conditions message on the DIC screen. (It lasts for about 10 secs.) If the temp goes above 37 then back down to 37, you get it again, or if you shut the car off and restart.
#11 |
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
its CLOSE ENOUGH! either way, is it HOT or COLD outside.....Don't you already KNOW its hot or cold out?? after all, you WALKED to your car, right??......or were you transported into it? LOL
#12 | |
2002 Camaro SS- BTR Stage 3, 799 Heads, Bolt on's Tuned by John at Broadview Automotive.. 420hp and 400tq
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
My temp gage is pretty accurate ecept when it it wet out or after I wash the car.
Then it reads ten deg. lower for some reason.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Mine is consistently about 4 degrees F too high. My 09 Silverado however is always right on the money. The Camaro engineer needs to talk to the Silverado engineer.
| Oil Temp gauge - low oil temp! | andyscozz | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 8 | 05-11-2010 10:20 AM |
| Water temp gauge | cowboy1948 | 5th Gen Camaro SS LS LT General Discussions | 0 | 10-23-2009 09:09 PM |
| Outdoor Temp gauge - stuck on 68 degrees | SGOS252382 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 10-02-2009 09:30 AM |
| What is the 4th gauge in a MN6 2SS? (not a tranny temp, like an auto) | MajikMD | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 7 | 07-18-2009 08:55 AM |
| SECOND GEN WATER TEMP GAUGE INACCURATE | 79ZRAG | 1st & 2nd Generation Camaros | 9 | 05-30-2009 06:13 PM |
