Old 02-02-2011, 08:57 AM   #1
Smoky10
Drives: 2010 Camaro 2SS
KB on a stock motor
I am thinking about installing a F/I cam and a KB 2.8L on my LS3, my question is that I've read where a bunch of guys can't really drive there cars very hard due to having F/I installed without having a forged bottom end. Is that the case or just people being overly careful?
Smoky10 is offline   Reply With Quote
Old 02-02-2011, 09:05 AM   #2
orange-prince
QATAR 2022
orange-prince's Avatar
Drives: black cts-V coupe a6
i want to know that as well
orange-prince is offline   Reply With Quote
Old 02-02-2011, 09:14 AM   #3
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
Your going to get 2 school of thought on this.
Keep the boost low and the timing pulled and the intake temps under control and your could be ok for a while.
Get carried away and it wont last long.
The differences are not just in the piston material but in the compression as well.
And even then you have two school of thoughts. Conservative/reliable vs on the edge. Shops who sell a lot of of SC's on stock engines will always argue one way about it.
GM didn't just boost its LS2 or Ls3 engine, it built a whole new engine for their sc offering.
CC Performance is offline   Reply With Quote
Old 02-02-2011, 09:26 AM   #4
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
u said for a while how long is that?
woodside783 is offline   Reply With Quote
Old 02-02-2011, 09:39 AM   #5
Smoky10
Oh ok, I was under the impression the LSA motor was just an LS3, but there are some internal differences?
I'm sure that depends solely on the block.
Old 02-02-2011, 10:02 AM   #6
T-RO 2SS
Drives: 2ss rs M6
It depends solely on the Drivers rigth FOOT and BRAIN connection.
T-RO 2SS is offline   Reply With Quote
Old 02-02-2011, 10:20 AM   #7
IPSjeff
Drives: 2009 ZR1
If you are going to make sub 650rwhp (Which the KB will) and you don't plan on tracking the car twice a week it will last quite awhile IMO. That being said, a solid tune, frequent fluid checks/changes, and a bit of common sense in terms of how hard you drive the car how often will certainly extend things quite a bit.
For example, we have a client's Procharged + Cam + Headers SS that made over 650rwhp more than a year ago. He drives the car HARD. Tracks it often. Broke the Tranny. Broke the driveshaft. Broke the Diff. Ran it on slicks/skinny's and DR's on the street. I watched him hot-lap it on a private rental day like he was TRYING to break something lol.
To this day the engine is bone-stock and with Meth and twin-pump fuel system it made almost 700rwhp. I wouldn't expect this to happen every single time but it is working for him
Jeff
IPSjeff is offline   Reply With Quote
Old 02-02-2011, 10:37 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Dragoneye made a Sticky in the Z28 Section with LSA specs', but to answer your question: yes - there are many desirable enhancements with LSA. Some quick ones are: forged crank, PM rods, upgraded hyper' pistons (not forged like LS9, but better than LS3), piston oil squirters, larger head bolts, upgraded roto-cast heads, additional layered head gaskets. These are just a few additional features of LSA. They've been run into the ground without failure. While I'd prefer to see more of LS9's forged components come over, LSA is certainly nothing to sneeze at. That baby should handle 600 RWHP without a problem (so long as the fuel and ignition systems are tuned accordingly). LSA also has a dual-mode fuel system, too, unlike LS3.
Jeff
That's saying something about the tuning!!!
'20 ZL1 Black "Fury"
Old 02-02-2011, 12:10 PM   #9
CC Performance
No the block is fine actually. When you build an engine for forced induction there are quite a few differences than when you build it for n/a.
Besides component material the bearing gaps are different and of course the compression.
No one can predict when an engine will fail but you can know when your pushing things beyond what they were built for.
I've said it before and I'll say it again. Doing it is one thing, getting it to live for a long time is another. Then you have things like intake air temps that need to be controlled as well to add to the equation as well as the quality of the gas you just put in.
The cast piston used in these engines does not like to be treated unkindly either and when you get "pinging" under boost your doing damage as well.
There are a lot of things to consider to a reliable build, I like to take a conservative approach as it never hurt anyone to play it safe. Dancing with the devil will get you burned if your not very careful and I don't know to many people that can afford to throw money away.
Old 02-02-2011, 12:18 PM   #10
Smoky10
Thank ya'll for the answers, that's what I needed to hear.
Old 02-02-2011, 01:17 PM   #11
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
Putting a SC on a stock motor is similar to, say, replacing your car stereo amp with a new Kick Ass 2000 Watt amp. Sounds/works good at lower levels, but will blow up the speakers when you crank it up.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 02-02-2011, 03:55 PM   #12
JANNETTYRACING
JANNETTYRACING's Avatar
A 2.8 is considered a large blower for large HP numbers and in this case I would suggest A forged bottom End for the ultimate in reliability at over 650 RWHP.
Not that you can't install it and run it at 6 PSI for 100,000 miles but why run a big blower at 1/4 its ability.
You an choose a smaller blower at lower cost and do that.
We need to know what your goals are to make accurate recommendations.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-02-2011, 10:39 PM   #13
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
running 2.8 kb w 3 3/4 pulley with cam kit -lpe fuel pump- @ 9.2 boost -89%duty cycle on kb 60lb injectors @wot...654 rwhp...i,ll post when it breaks...only time will tell..plan on 1/4 mile running about 3-4 times a year..
mikepage0007 is offline   Reply With Quote
Old 02-03-2011, 06:53 AM   #14
Smoky10
How long have you had it on your car? What else have you broken so far? And how hard do you drive on normal basis?
3rd Gen Camaro Street Stock build thread (dialup beware) zlathim 3rd Generation Camaros 9 12-06-2018 11:30 AM
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Anyone have 9psi on stock motor? Paul4137 Forced Induction - V8 8 04-08-2011 07:47 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
LT V6 Motor is blown! With only 9,000 miles on the clock...need help! DarkneSS 5th Gen Camaro SS LS LT General Discussions 143 10-30-2010 09:15 AM
