Old 02-06-2011, 07:46 PM   #1
mpiper
mpiper's Avatar
Drives: 2011 Black 1LT RS
Touch up paint - compounding help?
I need some advice. I touched up two small chips in the paint. One turned out perfect, but the one on the side of the door is raised above the level of the paint.
My first thought is to get an orbital polisher and try to polish it smooth and even with the paint.
Is this the best way to do this? If so, what type polisher and polish/compound should I use?
The only compounding I've ever done was around 10 years ago and it was the type you put on like wax but rub in, then wipe it off and wax. So I really want to make sure I'm getting advice before I start this.
mpiper is offline   Reply With Quote
Old 02-06-2011, 10:29 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I'd recommend ordering the "blob remover" from Langka. This is specifically designed to do what you need. Although you really should've had it available while you were painting, not sure how well it's gonna work after it's been dried for a while.
I'd still try Langka before anything else.
[B]
Old 02-06-2011, 10:57 PM   #3
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
It will work.. It just takes a lot more elbow grease.
2LTRS is offline   Reply With Quote
Old 02-06-2011, 11:03 PM   #4
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
I saw 2LTRS video on this. Looks easy enough to use.
The 2 oz. deal is only 19.95. Well worth the price.
http://www.langka.com/blob-eliminator-p-31.html
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 02-07-2011, 12:05 AM   #5
mpiper
mpiper's Avatar
I'm watching one by Ryan right now. This seems Awesome! I had never heard of this. You guys are a life saver!
gm touch up spray paint mike25 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 19 03-29-2013 11:07 PM
IOM Touch up paint? Susantroy1 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 13 03-14-2011 12:06 AM
Advice for touch up paint Urthman General Automotive + Other Cars Discussion 10 03-29-2010 09:00 AM
touch up paint and chip warranty coverage? (pics) traip93 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 14 08-21-2009 10:49 PM
Sanding touch up paint? Rikarus Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 08-19-2009 10:35 PM
