Old 03-19-2010, 01:35 PM   #1
Urthman
Future Camaro Owner
Drives: 2010 Jeep Wrangler Sahara 4dr
Question Advice for touch up paint
I recently received a nickel sized chip in the hood of my G8 GT. I'm picking up touch up paint today and plan on taking care of it tomorrow. Thing is...I've never used touch up paint before.
My plan is to wash it, touch it up, then move on to polishing, etc.
If it matters, my G8 is "White Hot".
Any advice?
Urthman is offline   Reply With Quote
Old 03-19-2010, 01:54 PM   #2
2000v6
Drives: 2003 m3, 2000 camaro v6, 2004 s4
I've got no idea
2000v6 is offline   Reply With Quote
Old 03-19-2010, 10:34 PM   #3
comiskeybum
Banned
Drives: 2010 Chevy Equinox LS
i dont think id trust myself with paint for a car
comiskeybum is offline   Reply With Quote
Old 03-20-2010, 07:17 AM   #4
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Any advice?
I found I was better at using the paint pens then I was the bottle and brush of paint. I got mine from www.paintscratch.com and the match is 100%
I recently fixed some scratches on my RJT and wow! I'm very impressed I got it that good.
Anyhow, to do it right, requires patience. Also the ability to stop at "good enough" Know that you will never get it good enough as the factory finish.
If the bare metal is exposed, and you have a bit of rust, you will need to sand it. I recommend using a fiberglass sanding pen. 3m makes a nice one. Then coat it with some primer, and leave it over night!
Remember patience? You will need to let your car look like crap for a couple of days.
When applying the paint, go very thin, and wait about 10 minutes between coats. I personally gave up on coating my touch up with clear coat, since it has a tendency to darken the paint, and no longer match.
Once you have gotten the scratch/chip to your liking or "good enough" leave it again overnight.
The following day you can then polish it. I've been very successful with quixx, and meguires scratchx for this.
It is recommended that you then leave it alone for 30 days before waxing it.
Also if you get the paint blobs, or mess up, having some goof off around helps as this stuff will remove the touch up paint when it is a few days old but not your factory paint.
Hope that helps.
skuttduck is offline   Reply With Quote
Old 03-22-2010, 03:02 PM   #5
Urthman
Future Camaro Owner
Thanks!
Old 03-22-2010, 03:23 PM   #6
ron10
Drives: 2010 2SS IOM L99
if you follow the instructions on the bottle,you should have no problem.it won't be perfect,but pretty close.
Old 03-22-2010, 04:09 PM   #7
Urthman
Future Camaro Owner
There are essentially no instructions on the bottle other than "shake well before applying".
Old 03-24-2010, 02:49 PM   #8
Ronn
Ronn's Avatar
Drives: 2010 Camaro
how did it turn out?
Ronn is offline   Reply With Quote
Old 03-24-2010, 05:06 PM   #9
Urthman
Future Camaro Owner
eh...it's livable for the moment. i'm going to clean her up and hit it again. the paint seemed to thin out quite a bit after a day or so. the spot isn't noticable from far away, but if you get up close and look for it it's easy to spot...along with a few others i touched up at the same time.
Old 03-29-2010, 08:49 AM   #10
Ronn
Ronn's Avatar
Drives: 2010 Camaro
I bet no one would even notice it unless you pointed it out... but then again its the whole fact that YOU know about it.
Old 03-29-2010, 09:00 AM   #11
skuttduck
skuttduck's Avatar
Which is why I stop at "good enough"
Paint your own stripes? blackZbandit Cosmetics and Lighting Modification Discussions 44 09-18-2011 10:22 AM
Adam's Polish & Car care Products Charlie@STILLEN Wash/Wax/Detailing and Cosmetic Maintenance Parts 50 04-01-2010 04:28 PM
All About the Clay Bar Process Junkman2008 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 0 01-11-2010 11:22 AM
Paint your mufflers! KJS Cosmetics and Lighting Modification Discussions 43 07-19-2009 09:20 PM
Help! Need advice on paint chip on roof of new Camaro. Mcbug Camaro Price | Ordering | Tracking | Dealers Discussions 5 06-24-2009 09:29 AM
