![]() Drives: 2010 Synergy Green Machine Join Date: Feb 2011
ColorShift Hook up Project
I just purchased a Synergy green non RS camaro and I have been looking at these lights for a long time. Is there a tutorial to connect the grille lights colorshift halos and fog lights like in the youtube video? but also Is there a way to connect the lights so thay you can also use the factory interior controls to control them also? And is there a way to seperate the lights for legal purposes I.e. "driving". I plan on sycing the footwell lighting with it to but if thats to much to expalin ill wait till later on.
Thx Happy to b part of the Camaro Family! |
I guess no one can help me ;;
Roll out!
Drives: 2010 ss/rs ls3 Join Date: Jan 2011
Im not sure what you are asking? so you want grille lights and the halo fog lights and uper halos,to run off one switch? as color change Iv seen all halos change at same time so yes on that but as all the lights power of same switch you run a chance to blow some fuses probbly.
On the interior controls to control ? do you mean the power from it or the dimmer part? you could probbly run a thing or two off it but might have to put a bigger fuse in, if you want the dimmer part of it you will need the power side going from the switch hope this helped Josh
"so you want grille lights and the halo fog lights and uper halos,to run off one switch?"
Run off the Switchs alrdy used in the car. The one that rotates and the dimmer but also be able to use the remote. |
MBRP Inc & GM project "Colorado Speed" | MBRP Tech | General Automotive + Other Cars Discussion | 40 | 10-08-2010 07:36 AM |
Ultimate Bolt-On Project or Racers Wet Dream | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 25 | 05-03-2010 09:06 PM |
Ultimate Bolt-On Project or Racers Wet Dream[ | Info@PeddersUSA.com | Dragstrip and Launch Techniques Discussion | 8 | 05-02-2010 02:06 PM |
Ultimate Bolt-On Project or Racers Wet Dream? | JusticePete | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 04-27-2010 04:01 PM |
Project American Heroes & Route 66 Exotic Coatings | rt66 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 1 | 10-06-2009 04:58 PM |
