![]() Drives: 2015 ZL1, M6, Crystal red Join Date: Jul 2010
Traction Contol / Rev limiter???
Ok i've been doing searches and cant find anything so heres my ? Everytime i take off and lose traction and want to keep losing it the engine hits like a rev limiter, but its around 3500-4000? i have hit the TC button once to turn that off but still its shuts it down...l feel like a shudder when it does it.. now i'm thinkin if i really did want to do a good burnout i wouldnt be able to with this doing that? what am i missing cause ive seem some serious burnouts and its not at 3500 rpms!! thanks for any info.. cant wait to buy some new tires...lol...
![]() ![]() ![]() Drives: 2010 Camaro L99 Join Date: Oct 2009
hold that button down, 2 light,s will light up
Yes, just like the previous post. Press and Hold the button for about seven seconds and both traction control and stabilatrack are turned off.
![]() Drives: camaro Join Date: Jan 2011
does the same hold true for the v6 motors, for TC off
When one camaro just wont do, its time to call: The Green Horent
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
Yeh with traction control off it will still catch and almost feel as if the car just looses power. Got to do as above stated and turn both off!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
#6 |
![]() Drives: Yellow Join Date: Jun 2010
Iam scared to use launch control after I put the supercharger on will stock clutch & drive train take 550 RWHP????
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 camaro Join Date: Aug 2009
, that much hp will only spin tires..come back with that question after you have some tires that will hook at 550 rwhp
#8 |
dirtbag
Drives: 2010 camaro LS Join Date: Mar 2010
#9 |
![]() Drives: 2010 CAMARO 2SS/RS Aqua Blue L99 Join Date: Nov 2009
ya! you will never hook. You will just blow the tires off of the line., But once you get stickies and are able to hook you will know wich upgrades to make cause if you didn't break you will.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS, 2010 Mustang GT Join Date: May 2010
Hold down for 7-10 second to turn all off if not this is what happens:
How does it work? Like any good electronic stability system, the StabiliTrak is designed to make driving safer by helping the vehicle to stay on its path when going around corners. What happens is as a driver heads to fast into a corner, the tires can't grip the road and sends the vehicle either skidding or spinning out of control. Now the StabiliTrak system, using a complex set of sensors and a controller, sends a quick series of pumps to the individual brakes to help the vehicle pull out of the turn and stay straight on the road. The sensor can measure the difference between the angle of the steering wheel and the direction you are actually turning. Then, as defined by the situation, it uses precise for precision pressure on the right brakes to help the driver stay in the right direction. The entire process happens so quickly that the driver's won't really know that it is going on. They won't even recognize the need for a correction in the steering it happens so fast. If they do suddenly recognize that they are heading into the corner too fast and pounce on the brakes, the system will still be able to detect and deal with the uneven braking problem. |
#11 |
| raise rev limiter | jnm2003 | Tuning / Diagnostics -- engine and transmission | 7 | 07-29-2010 07:55 AM |
| Is there a rev limiter parameter for when the brake is depressed (2010 Camaro)? | 2010 Bumblebee | Tuning / Diagnostics -- engine and transmission | 12 | 05-07-2010 12:39 PM |
| REV Limiter Stinks. | attymf | 5th Gen Camaro SS LS LT General Discussions | 79 | 03-19-2010 10:20 PM |
| HELP!! Rev limiter kicked in at 4Krpm! | AlSuwaidi | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 8 | 01-28-2010 01:48 PM |
| rev limiter | oldfart1941 | 5th Gen Camaro SS LS LT General Discussions | 91 | 10-21-2009 10:20 AM |
