![]() Drives: '11 1SS LS3 and '90 240sx hatch. Join Date: Jul 2010
How much is the rear diff fluid change?
I just want to get an average on what people are paying for the first service. Thanks
![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2010
Even if you use GM oil its less than $25.00 with the additive they say you don't need because its in the oil. easy to do yourself plus you get to know your car
#3 | |
![]() Drives: 2010 1SS/LS3 Summit White Camaro Join Date: Dec 2010
knows 2 facts about ducks
Pull your baby into the garage so the rear tires just make it onto the concrete. The little lip from driveway to garage gives you enough height to get in there. The rear differential is the big ball looking thing square in the center of the rear axle.
#6 |
![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Nov 2009
i dont think ive ever had the rear diff changed i have 17xxx miles how often does it need to be changed
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
#7 |
Manual recommends changing it at 1,500
#8 |
![]() Drives: 2011 Camaro 2SS LS3 M6 White Join Date: Nov 2010
#9 |
![]() Drives: '98 Camaro Z28, '06 Z06 Join Date: Feb 2011
You should change it once after the car is broke in. It lets you get the metal shavings out.
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Its listed under "New Vehicle Break In". It lists do's and don'ts for the first 1,500 miles. The very last one is to replace the rear axle lubricant at the end of the break in period. |
#11 | |
#12 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
16 dollars with like enviromental levys. Cheap... DIY for sure.
#13 |
So Cal Camaro5 Race Team
Drives: '10 SS/RS, '06 HHR, '70 El Camino Join Date: Sep 2009
is there an advantage to going to a Royal Purple for this
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels |
#14 |
I have no life
People are saying it's smoother...
Personally, for my first Diff Fluid change, I'm going with the GM recommended. I might go into something else later on... Hearing Amsoil and Royal Purple are good oils for this. My first engine oil change was with mobil1, but now I've gone to using Castrol Edge.
| When to do transmission fluid change | raider8654 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 12 | 01-18-2011 09:45 PM |
| Rear Diff | imstr8upg | USA - Northwest / Pacific Northwest | 7 | 01-06-2011 12:33 AM |
| Rear Diff Fluid and my Dealer | Rocklage | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 19 | 12-23-2010 12:56 PM |
| first differential fluid change | Dentyneice | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 14 | 05-08-2010 09:28 PM |
| Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 09:48 PM |
