Old 02-17-2011, 12:15 PM   #1
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
G80 Clunking in left turns ONLY.
Pretty simple. Clutch in, turn tight to the left and I get a clunking that's light and sounds like the locker is trying to compensate or slip. Heard about a similar issue with 5th gens (non G80 but it's an identical symptom) and the TSB said it was a lubrication/break in issue.
Think this could be the case? Dry spots on the gears causing slippage and the resulting clunk?
Zabo is offline   Reply With Quote
Old 02-22-2011, 07:10 PM   #2
robby
Drives: 02 B4C 6M
My 02 B4C has done that from new......drove two others just to satisfy myself it was the nature of the beast.
I ordered the car, new, and it only has about 5500 miles now......the sound has never worsened.
I did add the G.M. posi additive just because it has a friction modifier in it.....normally the stuff is only used in clutch type rear ends.
I kinda do it to myself on left turns by shifting to second mid-turn......those moments where the rear end is unloaded is when I hear it, uh, chatter or clank lightly for lack of a better term.
I'd recommend not fretting over it.....just enjoy the car.
BTW, I was reading your story about aquiring the bird.....congrats and sounds like a great find.
Rob
robby is offline   Reply With Quote
Old 02-22-2011, 07:22 PM   #3
Zabo
Gunning for Sixth
Zabo's Avatar
Well an update to this, turns out it's a combination of normal posi noise and the fact that both rear wheel bearings are shot. Up on a lift I got 10* deflection out of both wheels. Needless to say those bearings are done after sitting on the car for 10 years.
8 or so of those probably not even moving wearing a flat spot in the bearing itself.
Dome light blinks with left turn signal ssdavidw Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-10-2010 03:16 PM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 05:58 PM
Fall Cruise - Sunday October 18th Zeeman28a Canada 46 10-21-2009 09:11 PM
Reverse: Left or Right RMGee 5th Gen Camaro SS LS LT General Discussions 18 09-18-2009 09:45 AM
The Camaro took the spotlight: left the Corvettes/Viper in it's shadow... Splitter 5th Gen Camaro SS LS LT General Discussions 8 04-25-2009 11:23 PM
