Old 02-20-2011, 11:28 AM   #1
gatorlover
gatorlover's Avatar
Drives: 2013 AGM 1SS/RS 1LE
oil drain bolt broke off!!!!
So in my inifinate wisdom I decided to change my oil myself today. I get the car up on stands and proceed to remove the drain bolt and snap!!!!
I guess I was trying to loosen it by turning it the wrong direction. My brother in law says he thinks he can get the rest out. Of course napa doesn't stock the thing so I have to call the dealership tomorrow to get a replacement.
2013 Ashen Grey Metallic 1SS/1LE, NPP, Camera
(1 of 43 produced)
gatorlover is offline   Reply With Quote
Old 02-20-2011, 11:30 AM   #2
Shredder
Shredder's Avatar
Drives: 2011 RJT 2LT
Send a message via AIM to Shredder
You should buy the magnetic one from goldplug.com
Shredder
Shredder is offline   Reply With Quote
Old 02-20-2011, 11:33 AM   #3
gatorlover
gatorlover's Avatar
Good Idea. Problem is this is my daily driver and I need to get at least the one from the dealer to get back on the road........
(1 of 43 produced)
Old 02-20-2011, 11:47 AM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
holy crap,, you must have really been pullin hard to bust that bolt off,,
lefty loosy,, righty tighty,,lol
Old 02-20-2011, 11:48 AM   #5
Merc
In The Circle
Merc's Avatar
Old 02-20-2011, 11:52 AM   #6
gatorlover
gatorlover's Avatar
I really didn't pull that hard on it though. I was under the car from the front and was pulling the rachet towards the front of the car. I guess i got turned around because I was upside down on my back.
(1 of 43 produced)
Old 02-20-2011, 12:10 PM   #7
camaro1
camaro1's Avatar
that is the same drain plug used on all gen3 ,4 engines and trucks from 1999,, autozone, advance auto, someone should have one in stock on their HELP rack
Old 02-20-2011, 12:12 PM   #8
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
This will be technique used:
Oil pan drain bolts are pretty generic; someone will chime in with the correct size soon...
Metric, but I'm not sure which size (M12-1.75 thread or M14-1.75 thread??)
RiCorvette is offline   Reply With Quote
Old 02-20-2011, 12:14 PM   #9
camaro1
camaro1's Avatar
that is the same drain plug used on all gen3 ,4 engines and trucks from 1999,, autozone, advance auto, someone should have one in stock on their HELP rack,, if they say they dont list one for a 2010 camaro,, tell them to look it up for a 2002 silverado 5.3 engine,, and ill bet they have one!
i believe it is a m12x1.75
Old 02-20-2011, 12:31 PM   #10
Russell James
Russell James's Avatar
On the remaining broken piece in there, tap it a few times with a center punch straight in the center of the bolt. That will help release the threads. Since the head is gone, the only thing holding it in is the bind in the threads, a couple sharp hits should loosen it. Then take a tiny chisel and tap it counter clock wise.
Autozone has nice magnetic plugs. Ask them to look up their magnetic plug for a couple year old Corvette.
Old 02-20-2011, 12:36 PM   #11
gatorlover
gatorlover's Avatar
That was correct!!! Autozone has the silverado one in stock!!! Thanks for the help!
(1 of 43 produced)
Old 02-20-2011, 01:23 PM   #12
gatorlover
gatorlover's Avatar
Well, I've got the replacement and some bolt extractors. Should be able to get the old one out now.
(1 of 43 produced)
Old 02-20-2011, 03:54 PM   #13
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
http://www.quickoildrainvalve.com/Pr...uctCode=F107NA
Never have to worry about doing this again.
Old 02-20-2011, 04:10 PM   #14
Johnny1
Drives: Would only drive GM
Must be a pretty common plug. I put a magnetic one in my 3.7 I5 2007 Canyon a couple years ago and it was the same one.
Johnny1 is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
A NEW generation of oil, for ALL GM cars Sir Nuke 5th Gen Camaro SS LS LT General Discussions 48 11-03-2010 10:33 PM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
