Old 02-20-2011, 06:47 PM   #1
JHL88
JHL88's Avatar
Drives: 02 z06
those with barton shifters COME IN
did the install today took me a little over 3 hours to do. everything was fine, test drove it before final installing the ball and the mid piece of the shifter. well, when i went to test drive it again after everything was hard installed i had horrible vibrations and tranny noise through all the gears (minus reverse) AND neutral. man was i pissed bc it was a beast to do because A - i didnt have a lift, i did it on ramps, and B - i couldnt lower the transmission any.
well anyway took off the console plate to make sure all the jam nuts were on good and they were both on the shaft and the ball. (i figured that wasnt the problem hence the transmission noise) even dispite the vibrations it still shifted into all gears without a problem.
my question is the shifter plate that the 2 bolts go through that were on the stock shifter(looks like a shim), do we reuse that as well?? because i didn't see it on the instructions. it just said to reuse the 2 bolts. and did anyone else have similar issues with these barton shifters?
1997 RS wrecked
1998 Z28 sold
10 SS sold
2002 torch redc5z06 - sold :(
'13 z71 4x4 - DD
www.fquick.com/JHL88
JHL88 is offline   Reply With Quote
Old 02-20-2011, 06:58 PM   #2
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
No, you don't reuse this. I still have some vibration/noise, mostly in 2nd and at WOT. Things to try:
1) Make sure the boot (underneath the car) is on good.
2) Teflon tape in where the (top) shift stick attaches to the shifter assembly, and where you screw the knob on.
3) Dynamat (sound deadening material - available at any car stereo store or Amazon) wrapped around the link rod between the shifter and the tranny.
Old 02-20-2011, 07:30 PM   #3
Kurtisp
Kurtisp's Avatar
Drives: 2010 Camaro 2SS/RS Inferno Orange
i have the same problem....my next step is to try silicon on the thread and sound deadening....i've read somewhere that its the threads on the shifter itself thats rattling ? i may be wrong
Kurtisp is offline   Reply With Quote
Old 02-20-2011, 07:41 PM   #4
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Is it a grinding?? Or do you just hear the transmission?? Sounds like you either A need more sound deadening material, or B. Need to go back to stock because its just to loud for you. My straight pipes and long tubes cover most of my exhaust noise, but you will definitely have more tranny noise with the afterrmarket shifters as they are designed for performance in mind verses "luxury"....
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 02-20-2011, 08:06 PM   #5
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
No problems with my shifter.
Cam 427 is offline   Reply With Quote
Old 02-20-2011, 08:06 PM   #6
Strokedhog
Strokedhog's Avatar
Drives: 2010 2SS M6 Black
MInes been in for a year and no problems with vibration or noise. I have the pistol grip and its all tight. Dont have the instructions in front of me but I lubed the pins before install and had no issues
Halltech Intake, Barton Short Throw, Solo Mach X, Solo High Flow Cats, Billet Prototypes Catch Can, V Max Ported TB, 20% Tints, SLP Skip Shift Eliminator, Heritage Grill, BMR Suspension: Toe Rods and Trailing Arms with Poly Bushings, Pro Version Rear Cradle and Rear Differential Bushings, Front and Rear Sway Bars with End Links. Megan Racing Front Struts, and Rear Shocks
Strokedhog is offline   Reply With Quote
Old 02-20-2011, 08:47 PM   #7
JHL88
JHL88's Avatar
Drives: 02 z06
no grinding, but a lot of tranny noise and clinging. it seems as if something is loose like metal vibrating against metal, but its from underneath and is not from the upper half of the shifter. i put some teflon tape on the threads of the ball and the shifter itself and no luck with that. its pretty bad though i would say, like i wouldn't be able to hear the radio well at a practical level. ill have to wait till the morning to troubleshoot this pig
1997 RS wrecked
1998 Z28 sold
10 SS sold
'13 z71 4x4 - DD
Old 02-20-2011, 09:13 PM   #8
shinzon
Night Fury
shinzon's Avatar
Drives: 2014 ZL1
There is just no way around more noise in an after market shifter.
If there is PLEASE let us all know.
In all sincerity if ANYONE has installed a good name shifter ( Hurst/Barton/MGW etc. ) and has had the same or less tranny noise than stock I would pay to fly you out, buy you dinner, and let you kick my dog. Then you can install the same thing on SS.
2014 Black ZL1 - Toothless -
Previous Lovers :2014 1LE , 2010 2SS RS,2004 GTO, 2000 Camaro SS x 2
shinzon is offline   Reply With Quote
Old 02-20-2011, 10:15 PM   #9
tonetone
Drives: 2010 Camaro 2SS IOM M/T
I installed my Barton shifter and used the factory knob. No noise. About 8 months later I installed an aftermarket knob and could'nt take the noise. I reinstalled factory knob.
tonetone is offline   Reply With Quote
Old 02-20-2011, 11:08 PM   #10
Alfieboy
Madman
Alfieboy's Avatar
Drives: 2017 1SS
just installed over weekend...no banging or clanking ..more click or thus when going in gear,
mush more precise...although my son says he now hears a slight suction noise..very very very faint..maybe the boot..but Im extremely pleased with the 6sp shifter and the black SS ball.!
Alfieboy is offline   Reply With Quote
Old 02-21-2011, 08:42 AM   #11
JHL88
JHL88's Avatar
Drives: 02 z06
found out my problem... the rubber boot was loose and getting caught on the driveshaft. put it back on took it for a drive and works perfect
1997 RS wrecked
1998 Z28 sold
10 SS sold
'13 z71 4x4 - DD
Old 02-21-2011, 09:04 AM   #12
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Some have had prob reinstalling the boot. Mines quiet as could be for a short throw.
chevy 3 is offline   Reply With Quote
Old 02-21-2011, 09:09 AM   #13
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Yep, I've seen a video of the install and the guy doing the video stresses to make sure you get the boot on right and shows you exactly how to do it.
Old 02-21-2011, 09:14 AM   #14
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
Have had mine for almost a year and it is great. Very, very little noise. As good as it gets for aftermarket and I love it.
2010 2-Tone is offline   Reply With Quote
The Radar / Laser MEGA thread raqball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 116 01-29-2017 12:04 AM
Barton Industries engraved SS shift knob kit for 2010 Camaro 6 spd manual for sale topgun1 Interior Parts & Accessories 7 11-09-2010 08:21 PM
Barton Industries = Integrity and Professionalism robertway V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 09-07-2010 08:46 AM
BARTON Shifters at Camaro5 Fest Barton Industries 2010 Camaro5 Fest (I) 34 04-20-2010 07:37 PM
MGW vs Barton? StrangeMan V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 02-16-2010 10:20 PM
