Old 02-24-2011, 12:24 AM   #1
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Coolant Level
What is your coolant level when your Camaro is cold and hot? I checked my coolant level for the first time a couple days ago and it was only at the 1st hole on the coolant dipstick (cold). At hot operating temperature, the level was only at the 2nd hole. The owner's manual says this is normal but I find it strange since there is alot more measurement holes on the dipstick. BTW, I don't have any noticeable coolant leaks anywhere.
Is your coolant level as low as mine too?
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 11-03-2011, 06:47 AM   #2
Marchino
Marchino's Avatar
Drives: 2010 Camaro 2SS/RS
Hello,
I have notice the same thing. When the engine is cold the level is at the very minimum (I barely see it) and it goes up when the engine is hot. I do not have any leaks and the radiator fans work well when the engine is hot. If we would want to precisely follow the manual we should put some coolant in but I do not think that it is neccessary as I think everything works fine.
I would like to know someone else's opinion on this matter.
Ciao
Marco
Marchino is offline   Reply With Quote
Old 01-18-2012, 01:34 AM   #3
LimaCharlie
Does anyone have input on this? It seems like I have a very slow coolant leak even though I see no leaks anywhere. I add about 1 cup of coolant every 4 months to the recovery tank just to keep the coolant level on the dipstick within range.
Old 09-09-2012, 09:30 AM   #4
redleader
redleader
Drives: 2010
Same here on my V6 Auto.
What Coolant should we top-up with? Just water ?
redleader is offline   Reply With Quote
Old 09-09-2012, 09:38 AM   #5
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
If you add water get distilled water and not out of the faucet, too many chemicals in water you get from the faucet that can corrode aluminum.
I usually keep a jug of the premix 50/50 antifreeze that is Dexcool compatible to add to my vehicles.
The Bird is the word!
Oil Level on Dip Stick traip93 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 18 11-06-2016 09:20 AM
Gran Turismo 5 November 24th, 2010 Nezacant Gaming Lounge 562 04-21-2011 10:23 PM
Need help finding source of coolant leak Swoop Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 02-18-2010 09:08 PM
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 10:38 PM
INTENSE Camaro Level 2 Performance Package Todd @ INTENSE V8 Bolt-Ons & Tunes 0 10-27-2009 03:40 PM
