Old 02-08-2009, 09:43 PM   #1
SLIMJIM
Drives: 2002 Camaro SS M6
COMPUTER AIDED GEAR SHIFTING??
Will the new camaro's have CAGS like the 93-02? I haven't seen it mentioned.
SLIMJIM is offline   Reply With Quote
Old 02-08-2009, 10:07 PM   #2
kanys
kanys's Avatar
Drives: 2010 Camaro
I thought almost all regular cars have it to some degree, but I have not driven a newer manual. So I would say yes, tho I have been known to be wrong...
kanys is offline   Reply With Quote
Old 02-08-2009, 10:08 PM   #3
camaro5's Avatar
Drives: X-15 Velocipede
LS3 SS will.
Use a $20 CAGS eliminator from JEGS to defeat it, if desired.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 02-08-2009, 10:11 PM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
+1. There's a guy I used to know with a 4thgen(or was it a Corvette??) that bought one of those. Forgot where he got it from, though...
I always chuckle at the thought that just stepping on the pedal a little harder will shut it off, too.
Old 02-08-2009, 10:17 PM   #5
camaro5's Avatar
I know what you mean. My thought is I just don't want it surprising me ever, by restricting my shifter movement.
You're right though, I've heard many people say they never got "aided" even after years of driving.
You can get them many places, Summit Auto racing, and it includes a weather-tight plug to seal the tranny solenoid connector for future use.
STANDARD DISCLAIMER
Old 02-08-2009, 10:26 PM   #6
Never2LowChevy
Banned
Drives: bagged 4 door dually on 22s
What does the CAGS do exactly? I havnt driven a newer car with a manual.
Never2LowChevy is offline   Reply With Quote
Old 02-08-2009, 10:29 PM   #7
camaro5's Avatar
Roughly, it says the engine is warm, the throttle is 25% or less, in 1st gear.
Energize solenoid in tranny blocking 2nd and 3rd gears.
Driver forced to shift from 1st to 4th.
STANDARD DISCLAIMER
Old 02-08-2009, 10:30 PM   #8
LDGn63
LDGn63's Avatar
Drives: WNABEE
CAGS = MANDATORY 1st to 4th shift when easy driving...
SOLUTION = STAND ON THE GAS! (or get the eliminator)
LDGn63 is offline   Reply With Quote
Old 02-08-2009, 10:47 PM   #9
Mr. Wyndham
You know, it just hit me...although I don't own a manual (but I've driven one), I'd do that anyways.
When driving easy (ie. cruising around town), I wouldn't want to shift 4 or 5 times. And I already went from 1st right to 3rd in my friends car as regular practice....huh...
Old 02-08-2009, 11:26 PM   #10
nonsensez9
Drives: 05 mustang gt
I can see skipping second, but third too? from 25% throttle in first to go straight to fourth is a bit of a jump. I mean, the car will be going like 5mph when shifting to 4th. I don't ever hit 4th until at least 40mph. ah well, I won't knock it until I try it
nonsensez9 is offline   Reply With Quote
Old 02-09-2009, 06:44 AM   #11
garfin
Resident Disciple
garfin's Avatar
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold)
I did mine in '99 with a 5-pack of 2.2 OHM resistors from Radio Shack. The pack cost $0.99 at the time and only 1 is needed. Undid the harness, plugged it in and taped it back up.
So far so good!
http://clarkes96ss.cz28.com/SSFAQ.html#cags
http://www.fastz.com/z06/CAGS.html
Best regardSS,
Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD
garfin is offline   Reply With Quote
Old 02-09-2009, 06:48 AM   #12
spd98
Drives: had a goat
It's easy to work around or get rid of it. The car will pull 4th in that condition with no problem.
spd98 is offline   Reply With Quote
Old 02-09-2009, 07:24 AM   #13
fastball
Banned
Drives: 2017 Camaro 2SS 6MT
So far so good!
Best regardSS,
Elie
Yes, I have heard that the resistor trick works well, and for super cheap.
fastball is offline   Reply With Quote
Fifth Gear - Dodge Challenger SRT8 ihc95 General Automotive + Other Cars Discussion 27 10-01-2008 04:57 PM
blew second gear. carguy_z28 4th Generation Camaros 5 09-18-2008 12:14 AM
