Old 02-24-2011, 11:53 PM   #1
silver_bullet
Drives: 2011 Camaro V6 Silver
Exclamation HELP!!! problems with colorshift halo install
i'm in the middle of installing the colorshift halos on my non rs. i connected both halos and they light up blue only and the remote won't work (yes there is a battery that works inside and the indicator light goes on when a button is pushed). any suggestions? aac is closed right now and i want to b able to put my car back together tonight
silver_bullet is offline   Reply With Quote
Old 02-25-2011, 08:59 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Sorry....don't have an answer to your question but while you have you lights open you should put in some HID projectors.
http://www.camaro5.com/forums/showthread.php?t=120440
Build Journal
DIY : Install Performance Swaybars in 2010 Camaro Nine Ball Camaro DIY & HOW-TO instructions & discussions 17 09-14-2015 01:36 AM
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
AAC Dual Color Blue/White Halo Install on a 1SS Non-RS RAY-RAY Camaro DIY & HOW-TO instructions & discussions 7 05-29-2013 10:54 PM
how to install fog halo lights ? sub zero Cosmetics and Lighting Modification Discussions 4 01-15-2011 12:26 AM
color halo install effect rareslick Camaro DIY & HOW-TO instructions & discussions 6 07-04-2010 11:13 PM
