Old 03-01-2011, 08:56 PM   #1
first one
first one's Avatar
Drives: SSRS - black, GFX, SSX wheels
Battery tender problem
So I get the spring itch today, yea, it's only 45 degrees, but the sun is shining, the snow is all gone and the recent rain the other day had just washed all the salt off the roads. I carefully uncovered my car, took the battery tender off and excitedly hopped in my camaro and fired that mother up.....dead! Say what, but I had a battery tender on it for the last couple of months.
I hooked the battery tender up through the engine compartment. Maybe I should have hooked it up through the trunk. Last year, I didn't have a tender on it and it started just fine in the spring. Originally I purchased a Schumacker and it would give me a check battery error and wouldn't charge, so I purchaed a cheaper one, yeah bad idea I know, and it seemed to be charging fine, no errors. Does any know what might have happened or what I should do next year?
Oh, and I did jump my car and went for a drive. It's almost like driving it for the first time again after being stored all winter.
first one is offline   Reply With Quote
Old 03-02-2011, 02:21 AM   #2
dragon22
Drives: 2010 Camaro 2SS/RS SIM
I firmly believe a battery tender should be hooked directly to the battery. We hardwire them for people with BMW's, Mercedes and others with batteries in the trunk.
Anytime I have tried to test a battery/charging system at the remote boost points, my handheld machine gets upset and tells me to test directly at the battery.
These remote posts are fine for boosting...most of the time...but tenders and testing, at the battery. IMHO.
dragon22 is offline   Reply With Quote
Old 03-02-2011, 01:11 PM   #3
first one
first one's Avatar
Thanks AAC (Justin??). That makes sense as to why my battery was dead. I have read some posts where guys were charging from the remote posts and never heard there was a problem with doing this. My charger has a pigtail adapter with permanent connectors that can replace the current alligator clips. I think I will mount this to the battery permanently and fish it through somewhere maybe the spare tire drain hole and keep it there so I won't see a dead battery next spring after hibernation.
Old 03-02-2011, 01:32 PM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
Well I have to say that the actual Battery Tender brand has had no problems being hooked up to the jump points on mine for over a year now. The car has been non-op for varying lengths of time (up to a full month) and started every time. No indicator light issues and always correctly progresses thru the charging sequence changing to float mode with correct light indicators displayed along the way....
EDIT: Forgot to say that I am NOT using clamp type connections, it is bolted at each point. Also, you can see when you connect it right away whether it likes it and begins the charging cycle...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Electrical problem or engine i dont know. please help me! xpanda305x Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 05-22-2010 03:50 PM
bcm or battery problem and dic xpanda305x Camaro DIY & HOW-TO instructions & discussions 4 05-21-2010 07:13 PM
Trunk mounted battery replacement sting808 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 01-11-2010 06:42 AM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
Chevrolet Volt Urthman General Automotive + Other Cars Discussion 160 09-29-2008 09:17 PM
