Old 03-01-2011, 08:35 PM   #1
Carl6811
Drives: 2011 CGM RS/2SS, 07 Pont. GXP
Stupid question re: differential fluid change
Ok, here is a dumb question, but better to be sure than to be sorry!......When removing the plugs to both drain and fill the carrier, do you use the 3/8 ratchet drive? it seems to be a little loose, is it actually a 10mm square drive?.....thanks for your help in advance!
Carl6811 is offline   Reply With Quote
Old 03-01-2011, 08:36 PM   #2
FFPM73
Firefighter/Paramedic
FFPM73's Avatar
Drives: RJT 2SS/RS M6 LS-3
Yes, use a 3/8 ratchet with the small extension. It will come off without any problems.
FFPM73
FFPM73 is offline   Reply With Quote
Old 03-01-2011, 09:17 PM   #3
Nomad
Nomad's Avatar
Drives: '11 2SS/RS RJT M6
3/8" worked for me when I did mine. Make sure you take off the upper fill plug in case it's seized (it's just good policy).
Vararam CAI, Elite Engineering Catch Can, Separate Clutch Fluid Reservoir, Ghost Armor Full Protection Package, Chromed Turn Signal Bulbs, RPI Stealth Splash Guards, Skip Shift Eliminator, Defenderworx Chrome Bowtie Inserts, Pfadt Trailing Arms, Camaro Decal Store CGM Hood Spears with "376ci" custom text, Billet Depot/Drake Underhood Polished Caps, CGM Lug Nut Decals, Pedders Front Radius Rod Inserts, JacFab Front License Plate Bracket
Nomad is offline   Reply With Quote
Old 03-02-2011, 10:08 PM   #4
Carl6811
Thanks!!!.......I feel much more confident now...........lol.....
Diff Fluid question adub Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 9 09-03-2010 09:07 AM
clay bar ? Kycamaross Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 43 07-22-2010 09:42 PM
V6 M6 transmission fluid change help camaro guy Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 03-31-2010 02:00 PM
Fluid change appointment Screaminz2002 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 03-31-2010 01:26 PM
Order Change Question... pizza_jim Camaro Price | Ordering | Tracking | Dealers Discussions 2 02-28-2009 08:11 AM
