Old 03-06-2011, 11:46 AM   #1
Callaway Chris
Callaway Chris's Avatar
Drives: Callaway Corvette
Who has been successful at completely disabling DRLs?
Anyone have a harness mod? Prefer a plug-and-play mod.
What have you found to work?
In the Corvette, every time I start the car, I flip the switch back and that cancels the DRLs. Is the Camaro 2SS RS the same?
...how to eliminate DRLs
Callaway Chris is offline   Reply With Quote
Old 03-06-2011, 11:55 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
I did, Made a relay harness to do the work, don't have to do any thing lights come back on with the dark, and go off as soon as it gets light, This is on a non RS car, Have to think on how to do it on a RS car.
Old 03-07-2011, 02:32 AM   #3
thebrainhart
thebrainhart's Avatar
Drives: '10 Camaro 2SS/RS CGM LS3 A6
Daytime Running Lights, or auto headlights?
If DRLs, just take the bulb out...
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
Some ProCharger, Alky, CompCams, Brian Tooley, Holley, Livernois, K&N, Ridetech, DSS, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, Weld, M&H, Mickey Thompson, RKSport, Elite, Garys, Defenderworx, Anvil, etc.
thebrainhart is offline   Reply With Quote
Old 03-07-2011, 09:54 AM   #4
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Yes it's the same.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 03-07-2011, 10:18 AM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
So when are you going to make something for us? Still looking for a plug-n-play option.
Build Journal
Old 03-07-2011, 10:24 AM   #6
GG3745
GG3745's Avatar
Drives: 2010 SS RS CAMARO
SAME
GG3745
GG3745 is offline   Reply With Quote
Old 03-07-2011, 10:25 AM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
There's your answer... ^^^^^
I got a harness from FwyFlyer that swaps the DRL w/ Halos... works great... then got some Plasma DRL bulbs from AAC so the DRLs match the headlights when on at night.
Halos are my new DRLs now...
Old 03-07-2011, 10:41 AM   #8
IROCanSS
Drives: 89 IROC 350
Taking the bulb out will look terrible. I snipped the wire and ran it to a switch and feed power from the halos. Now I can run the halos and the fog lights(shut it, I know they aren't fogs but whatever) and also have full control over them with the switch. The DRL never come on because I cut the feed wire. I despise DRLs.
DIY-Wired DRLs with switch to have full control over DRLs IROCanSS Cosmetics and Lighting Modification Discussions 33 04-13-2015 09:27 PM
DRLs that match headlights? TaylorRyanSS Cosmetics and Lighting Modification Discussions 5 03-12-2010 08:52 AM
Running foglights and halos simultaneously? novajess1972 5th Gen Camaro SS LS LT General Discussions 56 02-24-2010 10:34 AM
K I have a weird problem with my 2ss 2010CamaroOutlaw 5th Gen Camaro SS LS LT General Discussions 45 10-25-2009 11:35 AM
Where are the DRL's? Captain Awesome Cosmetics and Lighting Modification Discussions 42 11-19-2008 01:26 AM
